Post Reply
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
E65 Forward Bump At Stop
14-01-2019, 05:41 PM
Post: #1
Hi Guys,
Has anyone else experienced a slight forward bump/lurch when coming to a stop? Seems to only happen intermittently. You glide up to a stop and as you come to a dead stop she bumps forward slightly.
Initially the diagnosis was that the universal flex ("Guibo") joint needed replacing. All the symptoms of a worn flex joint appeared to point to this being the problem. A new part was brought in from Germany and fitted to replace the old one that did look a bit worn. Sadly, however, the problem persists.
I have noticed that in D and S it does this but if I switch to M the lurching never happens when coming to stop. Could it be a transmission issue or perhaps the torque converter is on it's way out?
Any suggestions on own experiences will be appreciated.
Find all posts by this user
14-01-2019, 06:44 PM
Post: #2
RE: E65 Forward Bump At Stop
Not familiar with this type of issue. Sounds like a transmission issue based on your description. Maybe a trans reset will sort it out.
Disconnect the negative battery cable for 5min and see if it has any affect.
14-01-2019, 09:01 PM
Post: #3
Sounds like the gearbox to me as well..
Current:
'14 F30 335i MSport Alpine White III, Coral Red, Sat Nav, iDrive touch, PDC + reverse cam, Harman Kardon, N55 222.4wkw | 413wnm STOCK
'16 F30 318i LCI Manual, Alpine White III, Black Leather
[Image: banner final_1261154562_8282635603.png]
[Image: m_fanatic2_8387882621.jpg]
Mods: Optic Blue Lamin-X fogs, VPS light shields, CF Splitters, Mirrors, Ducktail spoiler, Aluminium interior trim upgrades...
Retired BMWs:
'12 F30 320d
'12 F20 118i
'09 E90 LCI 320i M-Sport
'07 E90 320i Excl
'91 E30 325iS Evo I
14-01-2019, 09:57 PM
Post: #4
Probably something to do with the torque converter engaging/disengaging at a guess
15-01-2019, 01:47 AM
Post: #5
Common issue on the early E65s. Gearbox service and reset would be my suggestion, but Google is your friend.
Sent from my SM-G930F using Tapatalk
E34 540iA - Gletscherblau.
[Image: 7236253502_871632509e.jpg]
16-01-2019, 07:36 AM
Post: #6
Strongly suspect its your gearbox. Look into a service at ZF. Alternatively give them a ring and discuss your symptoms, they're a great bunch!
Gareth
Current:
'10 F01 750i (Hotrod)
101,000kms
'95 e38 740i (The GuzzlerII)
315,000kms and still going strong!!!
For Sale: For Sale:
Past Beemers:
'05 e60 530d Exclusive - 160,000kms - Sold '15
'04 e46 320i Exclusive (The Lady) - 230,000kms - Sold '17
'02 e46 320d Exclusive (The Sipper) - 290,000kms - Sold '13
'98 e38 740i (The Guzzler) - 320,000kms - Sold '10
'02 e39 525i Sportpack - 75,000kms - Sold '09
'04 e46 318i Exclusive - Sold '06
'94 e34 530i - 386,000kms - 2x Gearboxes - Sold '04
'89 e28 528i - 146,000kms - Sold '07
'83 e12 535i - 200,000kms - Sold '07
16-01-2019, 08:24 AM
Post: #7
If i remember correctly, one of the issues reported on the ZF boxes was a harsh change to first gear, but that was in manual and sport mode. In drive it doesn't go to first, but i also read that in drive the torque convertor doesn't lock up fully between 1st and 2nd, so it essentially takes off in first and changes to second so quick without you feeling it.
When i add the XHP software on my car, where you can see the actual gear the car is in, I see the above.
I think depending on your mileage, you might want to visit ZF. Do not under any circumstances reset adaptations. ZF only resets adaptations after a full rebuild and do recommend doing at any other point in time.
No, no, he didn’t slam you, he didn’t bump you, he didn’t nudge you… he *rubbed* you. And rubbin, son, is racin’. – Harry Hogge, Days of Thunder
Current Rides
2007 530d MSport (DP, 76mm exhaust, RK Motion tune, OEM M6 wheels)
2012 X1 2.0D MSport
1996 200 Si Camry
[Image: photo from sashchern_5592516823.jpg]
The following 1 user Likes sash's post:
Budleigh
01-02-2019, 06:51 AM
Post: #8
I used to have this on my E39 540i auto with the five speed ZF. If i switched off the aircon it would not do it or the other way around. I think what helped was doing the gearbox reset according to Google or disconnect the battery for about 10 minutes. I would try it first before going to ZF. Also had a very similar problem on my first 3l d X5 (2003 model with five speed auto gearbox). On this car i would brake early and then sort of creep up to the stop the last few metres and then gently stop. The gearbox eventually started learning this and it solved the problem after a while. Just my 2c's
Post Reply
User(s) browsing this thread:
1 Guest(s)
