Post Reply
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
E90 Xenon headlight adjustment
09-11-2018, 04:19 PM
Post: #1
Hay guys, another stupid question from my side
I tend to get every second person passing me at night flashing at me, now either they all think my car is awesome and want to acknowledge it, witch may be the case(just joking) or my xenons are a little high.
Is there something simple I am missing that needs to be done or do I have to go on the hunt for a headlight module at the rear axle to correct the auto leveling?
Current Rides:
-2004 Ford Ranger 2500D
-2007 BMW 335i
-2015 KTM 1290 Superduke
-2008 Suzuki GSX650F
EX Rides:
- 1987 VW Citi Golf - RIP
- 1988 VW Fox
- 2009 NO Limit cg 125
- GoMoto Ballistic naked SI
- Suzuki DRZ400SM
- 2007 VW Polo 1.6 Comfortline
- 1991 MK2 Jetta CLI 20VT
- 2006 Audi A4 Avant S-Line
- 2013 Honda CBR1000RR - RIP
-2007 CBR 1000RR
-2007 Mazda 6 MPS
Find all posts by this user
09-11-2018, 05:20 PM
Post: #2
RE: E90 Xenon headlight adjustment
There are adjustment screws on the headlight, like any normal headlight... Just don't over adjust them and pop them out their Socket...
09-11-2018, 05:23 PM
Post: #3
I have the same issue, I would not tamper with the adjustment screws. What tend to happen is the light will still auto adjust and when the position cannot be found the lights move up and down while you drive
Current: BMW F32 420D Msport | BMW E90 320i Msport | Nissan Juke 1.6 - daily
Previous: BMW E46 320D sportpack, BMW E36 328IS, BMW E30 325IS, Alfa Romeo 2.0 TwinSpark, Opel Kadett 200is, Nissan Sentra 1.6 Twincam, Nissan 160U coupe, Many Toyata's, Ford Sierra XR6, Ford Escort MK1
10-11-2018, 06:37 AM
Post: #4
Yes this is what I am afraid off, with halogens i would just adjust on the screws but with the xenon headlights I know they have a leveling sensor on the rear axle usually.
Another thing, do you guys know if the FRM also control these as I know there are some other issues with mine.
Current Rides:
-2007 BMW 335i
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
10-11-2018, 08:15 AM
Post: #5
When you're parked in your garage is there a clear cutoff of the lights? I mean anything could happen maybe the bixenon shutter is stuck open or faulty? Who knows.
___
Current:
2011 E70 LCI X5 40d XDrive
2009 E90 330d lci MSport
- Xcede SW + Xflow DP & Exhaust
- N54 Intercooler
- XHP Gearbox Flash
2003 E46 330d
EX:
2007 Polo 1.4 trendline
2006 E90 320d
2007 E90 320d msport Promotec + DP
2012 E70 LCI X5 3.0d XDrive
2009 Jeep Wrangler Saraha Unlimited
10-11-2018, 08:55 AM (This post was last modified: 10-11-2018 08:56 AM by boost3d.)
Post: #6
The level sensor is on your front, left control arm... Check to see if it's still in good condition
10-11-2018, 11:25 AM
Post: #7
Flash them back, and then flicker your bright lights Fencelook
Current: E92 325i M LCI
Current: Audi A4 B8.5 1.8T
Ex: E90 323i Exclusive LCI
Ex: E90 320i Individual LCI
[Image: naman_5196753591_3577692508.png]
10-11-2018, 12:56 PM
Post: #8
(10-11-2018 08:15 AM)DieselFan Wrote:  When you're parked in your garage is there a clear cutoff of the lights? I mean anything could happen maybe the bixenon shutter is stuck open or faulty? Who knows.
I will have look at this, if they have shutters as well then this might be the problem
(10-11-2018 08:55 AM)boost3d Wrote:  The level sensor is on your front, left control arm... Check to see if it's still in good condition
Thanx for this, will have a look
(10-11-2018 11:25 AM)SubLoaded Wrote:  Flash them back, and then flicker your bright lights Fencelook
I usually do just to confirm I am not on my brights, usually does the trickSkit
Current Rides:
-2007 BMW 335i
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
10-11-2018, 01:01 PM
Post: #9
My E90 LCI has OEM Xenons fitted.
Although the are self-leveling they were still shining too low. A friend of mines were shining too high.
I adjusted both cars’ lights at the leveling screw and they are perfect.
The self-leveling only operates within a certain range, so if your light adjustment is way off the lights will never be able to level themselves to the point where they’re spot on.
Current:
[Image: b9c18a57-ca4d-430a-99f0-9f988a1b65a4_4874188881.jpeg]
Daily: Corsa Utility 1.4 Sport
SO: F20 120d
Previous:
E46 320d
Yamaha R1
Suzuki GSX-R 400
10-11-2018, 01:31 PM
Post: #10
Ty
When I get home next week I will check everything out first to see if it is operating as should, if that is the case then I will try adjust them with the screw.
Current Rides:
-2007 BMW 335i
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
10-11-2018, 02:07 PM
Post: #11
Mine were facing the ground pretty much. little adjustment in an underground parking from about 20m away from a wall and all is good!
[Image: sig_7745297653.jpg]
Build Thread:
E89 Z4 35i Build Thread
Current:
2009 E89 Z4 35i sDrive DCT
Previous:
2004 E46 330i
2005 Volvo S60 2.0t
2008 Yamaha R6
2004 E46 330D
1994 E36 M3 German spec
2009 Yamaha R6
2002 E39 525i
1996 E36 325i convertible
1997 E36 325i
2004 Yamaha R6
1998 E36 328i Individual
1984 E30 323i 2 door
1998 Mazda Astina
1987 Golf II GTI
1988 Golf II CSL
11-11-2018, 09:30 AM
Post: #12
When you start the car with the lights on, does it auto level immediately for you?
11-11-2018, 09:40 AM
Post: #13
(11-11-2018 09:30 AM)zizo911 Wrote:  When you start the car with the lights on, does it auto level immediately for you?
hay man, yes it does auto level, just a little high
Current Rides:
-2007 BMW 335i
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
13-11-2018, 07:35 PM
Post: #14
Definitely you need to adjust the manual adjusters about 20 yards from a wall or something that you are able to see where they shine adjust them using the pattern on the wall so you know what it’s doing. When I got my last car that was the first thing I did to it. Mine were shining on the ground. Now they are perfect as they can be. I can see well and don’t get flashed for being too bright.
Post Reply
User(s) browsing this thread:
1 Guest(s)
