Decat Done at Liatros Catalytic Recycling
Liatros@Liatros recycling
Hi Everyone,
We have started decatting facility in house.
If anyone has catalytic converter failure or car in limp mode please contact us.
We charge a fix rate of R500 while exhaust shops are charging way more.
Only decatting certain models at the moment please contact for more information and bookings.
We also decat other makes of cars.
011 450 0317
081 552 9454 Rami
083 500 0639 Luis
Whatsapp Available
[email protected]
Unit 23 Sunnyrock Business Park
3 Sunrock Close
Sunnyrock - Edenvale
1401
SubLoaded
Resident Derailer
Assuming you guys keep the cats after this?
Is this price for Primary and Secondary Cats?
Sspower
hi ,
how much do you charge to actualy remove the cat housing (meaning the casing that holds the cat and put a straightpipe) as per picture below?? for a e90 325i
Hi,
It is for the secondary cat.
We do keep the cats correct.
Regards
Rami
Sspower said:
hi ,
Hi,
At the moment we only do catalytics that are under driver door and not manifold or engine.
Will let you know once we do software and sensor delete.
Thank you
Regards
Rami
