Post Reply
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
NEED ADVICE ON E90 320I
13-10-2018, 08:46 AM
Post: #1
Hi guys, after kick starting starting my car I encounter some electronic problems. My head lights stay on, dash board lights off and my windows don't want to close. Even the indicator lights don't work.
Does anyone have an idea what might be the problem. Thanks in advance for your positive feedback.
Sent from my SM-G920F using Tapatalk
Find all posts by this user
13-10-2018, 08:50 AM
Post: #2
RE: NEED ADVICE ON E90 320I
Your FRM Module could be faulty.
You can contact Gert (Ratslaaf on the forum) from OBDWorx.
Current:
[Image: b9c18a57-ca4d-430a-99f0-9f988a1b65a4_4874188881.jpeg]
Daily: Corsa Utility 1.4 Sport
SO: F20 120d
Previous:
E46 320d
Yamaha R1
Suzuki GSX-R 400
13-10-2018, 08:55 AM
Post: #3
By kick starting you mean using jumper cables to jumpstart the battery? Or old fashioned way of pushing the car and kickstart in 1st or 2nd gear?
I assume the battery was flat hence you had to kickstart it?
My advise is to address the reason why you had to kickstart the car in the first place. How old is the battery? Battery not charging. Has it happened before...
Also disconnect the negative battery cable for a few minutes and reconnect it. Make sure its properly tightened and see if that resolve the issue.
Worse case is the FRM is damaged. But start with the battery test then alternator voltage etc.
13-10-2018, 09:13 AM
Post: #4
Thanks for the advice. It was kickstarted by pushing it. I did disconnect the negative last night for few seconds. The car started self after that but the problem was still there.
13-10-2018, 09:21 AM
Post: #5
Frm is cooked... Contact Gert and go from there..
Sent from my SM-G965F using Tapatalk
Current: Danger Ranger
Ex E92 335i DCT
400m @ 11.516 @ 203kmh
Backed up at MSA event!
60-130mph - 8.3 seconds
Dragtimes.com
Time is the best teacher.. Unfortunately it kills all its students Bangdesk
13-10-2018, 09:42 AM
Post: #6
Thanks Kish, how can I get hold of Gert
(13-10-2018 09:21 AM)Kish2604 Wrote:  Frm is cooked... Contact Gert and go from there..
15-10-2018, 12:36 PM
Post: #7
Thank you Guys, I did replace the FRM and everything is back to normal. I really appreciate your advice.
Post Reply
User(s) browsing this thread:
1 Guest(s)
