Post Reply
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
E90 buzzing through speakers
12-10-2018, 03:41 PM (This post was last modified: 12-10-2018 03:47 PM by trinomic.)
Post: #1
Hi guys,
I've tried searching but getting mixed results.
My car is a 2011 320d. Standard sound system. The moment the radio is turned on this high pitched buzzing starts. Its gone as soon as the radio is turned off. This is with the car tuned on or off.
From what I've seen on other posts its either a bad ground cable, a faulty fuse behind the head unit, software update required or the unit itself needs to be replaced.
Has anyone else resolved this without taking the car to BMW?
Find all posts by this user
12-10-2018, 05:13 PM
Post: #2
RE: E90 buzzing through speakers
Do you perhaps have an aftermarket amp installed in the car?
12-10-2018, 07:07 PM
Post: #3
(12-10-2018 03:41 PM)trinomic Wrote:  Hi guys,
Hey man this is generally a loose connection at the back of the radio, most cases the aerial cable, pull the radio out, re-seat everything and you should be good to go.
Okay bye
BMW E90 330D - Xcede De-Cat + Xcede Software Rollsmile
12-10-2018, 10:30 PM (This post was last modified: 12-10-2018 10:32 PM by trinomic.)
Post: #4
(12-10-2018 05:13 PM)zaheer Wrote:  Do you perhaps have an aftermarket amp installed in the car?
Nothing extra added, sounds like an amp with bad earth would though, except the pitch doesnt change at all when accelerating.
(12-10-2018 07:07 PM)Hot_Bobbys Wrote:  Hey man this is generally a loose connection at the back of the radio, most cases the aerial cable, pull the radio out, re-seat everything and you should be good to go.
Okay bye
Thanks a lot man, will give this a try.
14-10-2018, 06:54 PM
Post: #5
Hi
Do you have kids, if so just make sure no coins were put in the cd slot.
This happened to me about 3 weeks ago and exact same.
got it sorted for R750.00
CURRENT 2011 BMW 320d MPACK - DAMN TARMAC RIPPER
CURRENT 2010 AUDI A6 - SPACE WAGON - 2.0T
Ex 2006 VW JETTA 5 FSI 2.0T BWA DSG
Ex 1993 Jetta 3 Clx - 2l ADY
Ex 1992 Honda Dohc - Screamer Of Note
EX 2008 - E90 - 325i White - Sport Pack
Ex 2000 - Toyota Rxi 20VT
Ex 2007 - Toyota Run X Trd
Ex 1997 - Honda Civic Vtec
Eish thats all i can say
Post Reply
User(s) browsing this thread:
1 Guest(s)
