Post Reply
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
30FF - Boost leak Testing
09-10-2018, 11:27 AM
Post: #1
star 30FF - Boost leak Testing
Good Day Gents
As the subject describes I have been getting the 30FF Charge air pressure too low code for the past few months, I have replaced every single vacuum line except the one running to the rear wastegate with silicone lines, I have replaced the Chargepipe with a aluminium charge pipe and tial blow off valve, I have replaced the couplers to the stock intercooler with silicone reducers to eliminate the o ring and c-clip design
I am still getting a 30FF in 3rd gear (Basically when overtaking) now I know It might be the Wastegates meaning new turbos or the boost solenoids, but before I splash out money I want to see if there is someone in Pretoria or Close to pretoria that can do a leak test for me on the intake tract as well as the vacuum system
(Daniel v. Loggerenberg)
Current: 2007 BMW 335i | MHD Tune Stage1+ | Powerbrake RS Series High-Carbon slotted discs |CP with Tial BOV | 2nd Cat Delete | Freeflow resonators | Stage 2 Racing Clutch | 110mm SS Exhaust Tips | DCI | Halogen to Xenon Conversion |
Ex. Rides
2006 BMW 323i (Traded for Current)
1989 BMW 328i
[Image: signature_6973212836.jpg]
09-10-2018, 12:42 PM
Post: #2
Chat to Afzil... His helped many a guys here. Based isln Norwood. 061 185 9933
Sent from my CLT-L29 using Tapatalk
[Image: signature_2082411609.jpg] - - - - - - - - - - [Image: 120d avatar_6603350746.jpg]
[Image: bmw-official-events-signature_8286350658.jpg]
Find all posts by this user
10-10-2018, 08:32 AM
Post: #3
RE: 30FF - Boost leak Testing
Cannot get hold of Afzil, his phone has been off since yesterday, other suggestions? I am pulling apart everything today to check all connections and o-rings as well as tighten clamps on the intercooler
Ex. Rides
1989 BMW 328i
10-10-2018, 08:56 AM
Post: #4
Is the car tuned/modded?
10-10-2018, 01:46 PM (This post was last modified: 10-10-2018 01:50 PM by Little Goliath (Daniel).)
Post: #5
(10-10-2018 08:56 AM)Twinz Wrote:  Is the car tuned/modded?
Yes CP with Tial BOV, MHD stage 1 did this before mods and tune though, can a loose rear inlet cause a 30ff code? I am thinking my rear inlet is loose from installing/uninstalling the DCI's for a few other repairs, When I let off the throttle I hear a second very distinct sound from the right side of the car almost like a blowoff noise? directly after the BOV blowoff noise
I put rubber reducers with normal clamps on the intercooler to rule out a leak there, I ziptide each and every silicone vacuum line, I tested boost solenoids by hooking both turbos to one and it did the same, hooked it up to other one still same error, deleted vacuum reservoirs to rule out cracks in them
I am at my wits end
Ex. Rides
1989 BMW 328i
10-10-2018, 01:57 PM
Post: #6
Log the car so one can see if there is an issue. You can attach a csv file in your post.
11-10-2018, 01:15 AM
Post: #7
(10-10-2018 01:57 PM)Twinz Wrote:  Log the car so one can see if there is an issue. You can attach a csv file in your post.
I went to a friend with a lift tonight, the rear inlet is completely off, we did a smoke test to check for leaks and found none (After reattaching the inlet with the longest screw driver I have seen in my life, what he did find however is that the wastegates are very loose so we will be pulling the turbos this weekend and adjust them as well as replace all the gaskets and seals, will also be installing decatted downpipes while we are dropping the subframe
Thank you all for the help will log the car before we do anything and again after for any fanatics with the same problem in the future
Ex. Rides
1989 BMW 328i
11-10-2018, 05:47 AM
Post: #8
Glad you found the root cause of the problem
11-10-2018, 08:50 AM
Post: #9
Thumbs
11-10-2018, 02:28 PM
Post: #10
Just a heads up to anyone thinking of pulling turbos, the gaskets and o-rings are hard to come by after phoning around the whole day here is the cheapest way I found to get everything
Waterpipe o-rings – 11427558936 X8 - Seal Centre - R78.40 – R9.8
Exhaust Manifold Gasket – 11627558906 X6 - Bemows - R303 - R51
Oilfeed pipe oring - 11427558936 11 2x2mm X4 - Seal Centre - R39.20 – R9.8
Returnpipe Gasket – 11422246091 X2 - BMW - R310 – R155
CAT Gasket – 18307553601 X2 - BMW - R524 - R262
Flanch Gasket – 18307553603 X2 - RE-USE OLD ONE
Boostpipe O-ring – 13717568030 X2 - BMW - R188 – R94
Airpipe Gasket Ring - 13717568029 X1 - BMW - R187.04 - R187
Anti Freeze X2 - BMW - R127 - R254
Ex. Rides
1989 BMW 328i
Post Reply
User(s) browsing this thread:
1 Guest(s)
