Post Reply
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
New 3 Series (G20) Goes Official
02-10-2018, 12:02 PM (This post was last modified: 02-10-2018 12:05 PM by CocoPops.)
Post: #1
330I / 330I XDRIVE
On sale March 2019
2019 330i starts at $40,200 + $995 Destination in U.S.
2019 330i xDrive starts at $42,250 + $995 Destination in U.S.
new 2.0-liter, inline 4-cylinder
255 hp from 5,000 - 6,500 rpm (7 hp increase over F30)
295 lb-ft from 1,550 - 4,400 rpm (37 lb-ft increase over F30)
0-60 mph in 5.6 seconds
M340I XDRIVE M PERFORMANCE
M340i and M340i xDrive models will be available
On sale Spring 2019
Inline 6 Cylinder Turbo
382 hp / 369 lb-ft.
0–60 mph in 4.2 seconds
330E
330e will arrive early 2020
EXTERIOR / INTERIOR
2.9 inches longer than F30
0.6 inches wider than F30
0.5 inches taller than F30
1.6 inch longer wheelbase than F30
1.7 inches wider front track than F30
0.8 inches wider rear track than F30
Trunk capacity: 17.0 cubic feet (1.2 cu ft more than F30)
Hofmeister kink now integrated into the C-pillar, giving the rear doors “freestanding” glass edge
New colors: Portimao Blue metallic and Vermont Bronze metallic
New optional Vernasca leather upholstery in five colors with decorative quilting and seam patterns
Sport Line (Standard)
High-gloss Shadow Line trim for window surrounds, kidney grille bars and trim elements for the air intakes and rear apron. Interior trim strips in high-gloss black and sports seats for the driver and front passenger
Luxury Line
Chrome kidney grille, front air intakes and rear apron. Vernasca leather interior trim, Sensatec instrument panel and door trim, and fine wood interior trim strips in high-gloss Ash grey brown
M Sport
Variable Sport Steering
Standard M Sport Suspension or optional Adaptive M Suspensions
M Sport front bumper, side skirts and rear bumper. High-gloss Shadow Line kidney grille bars, air intake trim and rear diffuser in Dark Shadow. Sorts seats with M-specific upholstery, M leather steering wheel, anthracite-colored BMW Individual headliner and interior trim strips in Aluminum Tetragon
CHASSIS / SUSPENSION / AERO
Body-in-white lighter by 44 lbs.
Body structure lighter by 16.5 lbs.
Aluminum hood and front fenders saves another 33 lbs.
Overall body rigidity up 25%; as much as 50% in certain areas
Suspension spring rates increased by 20 percent without loss of comfort
Lift-related dampers use for first time in a BMW model (featured on both regular and M Performance suspension)
Reduces body movement perceptibly smoothing out vibrations caused by bumpy road surfaces and dynamic cornering. The system adds extra hydraulic damping at the front axle and a compression limiting system at the rear. It is continuously variable and adjusts the damper firmness progressively according to the changing spring travel. This prevents excessive body dive when driving over large bumps and so avoids uncomfortable, nervous damping response.
Ride comfort and acoustics both improved
Aluminum swivel bearings and control arms for the front axle, aluminum wheel mounts and a new generation of wheel bearings for the rear axle significantly reduce unsprung mass
Front spring struts and engine sub-frame now made of aluminum
Drag coefficient (Cd) of 0.26, a reduction of .03 Cd over F30 3 Series
Active air flap control extends across the BMW kidney grille and lower air intake
ADAPTIVE M SUSPENSION
Both the sportiest and most comfortable suspension available
Now with new valves and optimized control algorithm, which now also enables load-dependent control of the damping forces
ADAPTIVE mode is now available and adjusts car's responses to the driving style and, depending on the equipment specified, to the route profile. The control system responds to accelerator and steering inputs and the position of the selector lever to make the powertrain and suspension characteristics sportier or more comfort-oriented. The map data supplied by the optional Navigation system Professional is also used to prepare the car for an upcoming junction or bend.
STEERING
Servotronic speed-sensitive power assistance is standard
Variable sport steering is part of the M Sport suspension and Adaptive M Sport suspension
M SPORT BRAKES
Four piston fixed calipers at the front
Single-piston floating calipers at the rear
M SPORT BRAKES
M SPORT DIFFERENTIAL
Option for the BMW 330i in combination with M Sport suspension or Adaptive M suspension
Electronically controlled, fully variable locking
TRANSMISSION
8-speed Steptronic transmission as standard
Wider gear spread (from 7.8 to 8.2)
New control unit and further enhanced gearshift dynamics.
Shorter gearing for the lower ratios
Even quicker shift times
Launch Control function
Shift paddles
Automatically adapts its shift strategy according to the route and driving situation (i.e. uses data from the navigation system and from Active Cruise Control system’s radar sensor), thereby avoiding unnecessary gear changes when negotiating a series of fast corners and, when approaching a vehicle ahead, for example, to shift down early in order to use the engine braking to scrub off speed
Improved Auto Start Stop and Coasting functions
xDrive splits drive torque between the front and rear wheels more efficiently and can direct all torque to rear wheels
xDrive system weight has been reduced and its oil supply system optimized
LIGHTING
Full-LED headlights are standard
Optional LED headlights with extended features and U-shaped daytime driving lights
Optional Adaptive LED headlights with BMW Laserlight with their hexagonal DRL rings and blue, L-shaped elements
High Beam Assistant option available with Optional LED headlights and Optional Adaptive LED headlights
Optional ambient lighting with lighting of lines running along the instrument panel and door paneling. Six light colors and eleven combinations of brightness, light distribution and color scheme for all light sources in the interior can be selected from the iDrive menu. Dynamic interior light function emits pulsating light signals in specific situations
COMFORT ACCESS
Car will automatically unlock when the radio remote control is detected in its immediate vicinity and lock again when it moves out of range
Hands-free opening and closing of the trunk lid
New movement sensor in key monitors if key is being carried (and therefore is always transmitting) or has been put down on a table, for example, allowing it to switch into standby mode with the transmit function deactivated
AUDIO
Standard audio with ten speakers and 205 watts
Optional Harman Kardon (offered as part of the optional Entertainment package) with 16 speakers and and 464 watts
DRIVER ASSISTANCE SYSTEMS
Standard Collision and Pedestrian Warning with City Braking function
Optional Cruise Control with braking function
Optional Active Cruise Control system with Stop & Go function
Optional Driving Assistant system (includes Lane Departure Warning, Lane Change Warning, Rear Collision Prevention and Cross-Traffic Alert)
Optional Driving Assistant Professional
includes all features of Driving Assistant and the Active Cruise Control with Stop & Go function
Steering and Lane Keeping Assistant
Evasion Aid
Priority warning and Wrong-way warning systems
Cross-Traffic Alert
Optional Park Distance Control (PDC)
OptionalParking Assistant Plus with Back-Up Assistant
Automatically selects parallel or perpendicular spaces and maneuvers into them by taking care of steering, accelerating, braking and automatic transmission shifting
Automatically maneuvers out of parallel parking spaces
Park View, Panorama View and 3D Top View used to create a 360° image of the vehicle and its surroundings
Remote 3D View gives drivers ability to call up a three-dimensional live image of their vehicle and its immediate vicinity on their smartphone
Back-Up Assistant helps the driver to exit parking spots or maneuver when space is limited
HEAD-UP DISPLAY
Optional Head-Up Display
Projection area 70% larger than F30 3 Series
Enhanced graphics and additional display readings
Information includes car’s speed, speed limits and overtaking restrictions, Check Control messages, status indicators and warnings from the assistance systems, detailed route guidance and turn instructions, and telephone and entertainment lists
Also displays distance warning as part of the Active Cruise Control system
BMW INTELLIGENT PERSONAL ASSISTANT
Intelligent, digital character that responds to the prompt “Hey BMW”
Range of functions and skills available will be constantly expanded as part of regular updates
Learns routines, habits, preferences and applies them in the appropriate context – e.g. for the seat heating or the places they drive to frequently using the navigation system (“Take me home”). It is familiar with the vehicle’s functions and is able to operate them as required. Saying “Hey BMW, I’m cold” will prompt the BMW Intelligent Personal Assistant to adjust the temperature inside the car accordingly.
Intelligent learning: the assistant learns more about the driver with every command given, every question asked and every setting selected
Can explain how car functions work (e.g. "How does the High Beam Assistant work?"), provide current status information (e.g. "Is the oil level okay?") and help answer questions (e.g. "What warning messages do I have?").
Knows the driver’s favorite settings, and can even activate a combination of them to enhance well-being. For instance, “Hey BMW, I feel tired” triggers a vitality program that adjusts the lighting mood, music and temperature, among other things, in order to make the driver feel more awake.
BMW DIGITAL KEY
Near Field Communication (NFC) technology allows car to be locked and unlocked from a smartphone (without need for car key)
Holding smartphone up to the door handle opens the car
Placing phone in wireless charging or smartphone tray allows starting of engine
Digital Key can be shared with up to five other people
BMW Digital Key available for all NFC-capable Samsung Galaxy smartphones running Android 8.0 and above
BMW IDRIVE DISPLAY AND CONTROL
Standard BMW Live Cockpit features iDrive 6.0 with an 8.8-inch digital touchscreen Control Display and a 5.7- inch digital instrument color display
Optional BMW Live Cockpit Professional
12.3-inch high-resolution digital instrument cluster display
10.25-inch digital touch screen Control Display
Adaptive navigation system,
Hard drive- based multimedia system with 20 GB of memory, Touch Controller, two USB ports for data transfer, Apple CarPlay and WiFi interface
[Image: showthread.php?t=1540476#lg=591&slide=14]
[Image: The%20all%20new%202019%20BMW%203%20Serie...crop=edges]
[Image: P90323766_highRes_the-all-new-bmw-3-se.j...crop=edges]
[Image: P90323767_highRes_the-all-new-bmw-3-se.j...crop=edges]
[Image: P90323768_highRes_the-all-new-bmw-3-se.j...crop=edges]
[Image: P90323769_highRes_the-all-new-bmw-3-se.j...crop=edges]
[Image: P90323770_highRes_the-all-new-bmw-3-se.j...crop=edges]
M Performance Parts:
BMW Power.
Find all posts by this user
The following 8 users Like CocoPops's post:
beemerman, danieltau, Dirtydeedsman, JodyD, Riaad, sanesh21, SubLoaded, YUBEN
02-10-2018, 12:48 PM
Post: #2
RE: New 3 Series (G20) Goes Official
It looks ok, baby 5, will wait for coupe to see what they do with that
02-10-2018, 01:06 PM
Post: #3
i like it, lets hope the 330d and 340i are still part of the line up.
[Image: nick sig2_1674483441.jpg]
02-10-2018, 01:15 PM
Post: #4
Not bad, rear looks a bit Lexus to me.
[Image: my m5_3866542591.jpg]
The senior King - Simply, the best!!!
You are missed.......
The following 1 user Likes graan13's post:
Nick
02-10-2018, 02:29 PM
Post: #5
Live Pics:
[Image: 2019-BMW-3-Series-exterior-interior-1.jpg]
[Image: 2019-BMW-3-Series-exterior-interior-3.jpg]
[Image: 2019-BMW-3-Series-exterior-interior-6.jpg]
[Image: 2019-BMW-3-Series-exterior-interior-7.jpg]
BMW Power.
The following 2 users Like CocoPops's post:
Dirtydeedsman, Tareeq
02-10-2018, 02:49 PM
Post: #6
Front looks Chinese, rear Japanese....will reserve judgement till viewed in the metal....
/o(O)(O) \ (lllllllll)(lllllllll) / (O)(O)o\
02-10-2018, 03:21 PM
Post: #7
All new BMW styling takes time to get used to. It grows on you.
02-10-2018, 03:23 PM
Post: #8
The side profile is unmistakably bimmer and the front as well. But the rear looks like a mix of lexus and audi.
I think it looks great and it's lighter than the previous generation which is awesome. I think it's a step in the right direction. Bravo
Current:
His - 2009 E82 135i coupe - Manual, N54, Sports pack, Sapphire Black
Hers - 2016 Ford Fiesta 1.0 EcoBoost - Manual, White
Previous:
2009 E90 320i - Manual, Sports pack, Sapphire Black
1998 E36 318is - Manual, Montreal Blue
02-10-2018, 03:36 PM
Post: #9
Lexus
MKVally
ex audi a3 1.8T - DP zhorst UniQ 18's and drop
ex bmw e46 330i - zhorst, 19's and coilies .
ex audi a3 2.0T dp zhorst and eurospeed map, 19's and coilies.
ex audi a5 2.0T DP and coilies and 20's
current BMW e90 M3 stock
02-10-2018, 03:41 PM
Post: #10
I wonder if there will be a M340e ... The Hybrids interest me most to be honest...
Current:
'14 F30 335i MSport Alpine White III, Coral Red, Sat Nav, iDrive touch, PDC + reverse cam, Harman Kardon, N55 222.4wkw | 413wnm STOCK
'16 F30 318i LCI Manual, Alpine White III, Black Leather
[Image: banner final_1261154562_8282635603.png]
[Image: m_fanatic2_8387882621.jpg]
Mods: Optic Blue Lamin-X fogs, VPS light shields, CF Splitters, Mirrors, Ducktail spoiler, Aluminium interior trim upgrades...
Retired BMWs:
'12 F30 320d
'12 F20 118i
'09 E90 LCI 320i M-Sport
'07 E90 320i Excl
'91 E30 325iS Evo I
02-10-2018, 04:21 PM
Post: #11
Some nice gimmicks here and there, I like the self centering wheel caps.
If you are interested in something, No matter what it is
Go at it full speed
Embrace it with both arms
Love it
Live it
Be it
Above all become passionate about it
02-10-2018, 06:54 PM
Post: #12
NOTICE:
1. Members please dont quote the whole post...its long already.
2. Cocopops can you just post the link to the options...the post is way to long an detract from this stunning launch thread.
The following 1 user Likes Twinz's post:
r0ckf1re
02-10-2018, 07:35 PM
Post: #13
Those Laserlights are tasty. Wonder how much it'll be though
02-10-2018, 09:43 PM
Post: #14
(02-10-2018 06:54 PM)Twinz Wrote:  NOTICE:
Hey,
Sure the details can be found here: https://g20.bimmerpost.com/forums/showth...?t=1540476
02-10-2018, 10:34 PM
Post: #15
I'm undecided. The side design is good, rear looks ok but the front with those cutouts in the lights...not a fan. Feels like they took more than a few pages from the current Lexus design playbook.
And then there's the interior...one word comes to mind and it's a word I used to associate with Audi interiors...antiseptic. IDrive 7 looks interesting and the pulsating lights in the door handles are functional but overall the the design is wholly unremarkable.
Baby 5er indeed...but personally I think it's a mixes bag. The new A4 is more edgy and the c-class much more posh. Not sure where the 3 slots in.
::Current::
F12 650i Vert
Black Sapphire Metallic | Dakota Black Sport Seats | EDC | Dynamic Drive | Adaptive Drive | Soft Close Doors | HUD | Surround View
03-10-2018, 09:21 AM (This post was last modified: 03-10-2018 09:27 AM by schalk320d.)
Post: #16
I think this car looks absolutely stunning from all angles and although I can see the resemblance to Lexus in the rear,I feel that Lexus should have waited a while and copied BMW instead,because the rear of this G20 looks tops Tiptoe
I saw a couple of people on various different platforms actually complain about this G20 being too much of a baby G30,which is an invalid concern IMO.The 5 series is a great car and has always been the better built and better specced car between the two,so why would BMW miss out on the opportunity to spoil the 3 series buyer with better materials,build quality and a better standard spec for a change?
Current:
e90 330d M-sport Auto
Opel Corsa Utility 1.4
Suzuki Tl1000
[Image: img_1954_7594118472.jpg]
Ex:
E46 320d Auto
E46 320d Manual
Kawasaki ZXR400
The following 1 user Likes schalk320d's post:
Dirtydeedsman
03-10-2018, 04:10 PM
Post: #17
New M340i:
Info:
Both M340i and M340i xDrive models will be available in U.S.
On sale Spring 2019
382 hp / 369 lb-ft.
[Image: G20-M340i-1.jpg?w=1447&h=553&fit...crop=edges]
[Image: G20-M340i-2.jpg?w=1447&h=553&fit...crop=edges]
[Image: G20-M340i-3.jpg?w=1447&h=553&fit...crop=edges]
[Image: G20-M340i-5.jpg?w=1447&h=553&fit...crop=edges]
BMW Power.
17-10-2018, 08:40 AM
Post: #18
It looks like a barge - I wonder if this size means they'll introduce something like a 1-series sedan (I believe this exists in china already).
Previously owned cars:
2003 Alfa Romeo 147 T-Spark (Navy blue and beige interior)
2006 Alfa Romeo 147 JTD 16v (Silver and beige interior)
Current:
2007 BMW Z4M Coupe (Silbergrau and Black Leather)
17-10-2018, 08:50 AM
Post: #19
Stunning piece of art, and has all the bells and whistles one could want. Just missing the coffee machine Chef
17-10-2018, 09:24 AM
Post: #20
Praise Love it , Can already see myself in one of these
[Image: bmw-official-events-signature_8286350658_4194756313.jpg]
Post Reply
User(s) browsing this thread:
1 Guest(s)
