Post Reply
Thread Rating:
  • 2 Vote(s) - 1 Average
  • 1
  • 2
  • 3
  • 4
  • 5
vibration under acceleration
12-08-2018, 06:18 PM
Post: #1
thumbdown vibration under acceleration
Hi All, I recently purchased an F10 530d and I've been experiencing vibration under acceleration above 80kph, when letting off the accelerator, it dissipates.
There is also a small vibration persistently at ~110 - 124kph.
I haven't had the wheel alignment and balancing checked, but I doubt it is that. The vibration is harder, the harder I accelerate.
Any idea what it could be?
HIS: E34 535i 1991 M30, F10 530d 2011 N57
[Image: signature_333363036.jpg]
Find all posts by this user
12-08-2018, 06:21 PM
Post: #2
RE: vibration under acceleration
Could it be the diff? As it is related to engine speed as you say. Does it knock at all?
Current:
'14 F30 335i MSport Alpine White III, Coral Red, Sat Nav, iDrive touch, PDC + reverse cam, Harman Kardon, N55 222.4wkw | 413wnm STOCK
'16 F30 318i LCI Manual, Alpine White III, Black Leather
[Image: banner final_1261154562_8282635603.png]
[Image: m_fanatic2_8387882621.jpg]
Mods: Optic Blue Lamin-X fogs, VPS light shields, CF Splitters, Mirrors, Ducktail spoiler, Aluminium interior trim upgrades...
Retired BMWs:
'12 F30 320d
'12 F20 118i
'09 E90 LCI 320i M-Sport
'07 E90 320i Excl
'91 E30 325iS Evo I
12-08-2018, 06:33 PM
Post: #3
Same problem here.
E90 325i.
One mech told me its the diff.
Need a few more opinions still. Diff is big money.
I've walked the walk...
Now I talk the talk...
Post: #4
(12-08-2018 06:21 PM)cOlDFuSiOn Wrote:  Could it be the diff? As it is related to engine speed as you say. Does it knock at all?
Hi, no knocking sounds at all. In fact, the ride otherwise is quite smooth.
12-08-2018, 06:50 PM
Post: #5
This might sound like a silly question, but are the Tyres on the correct way?
I had this issue a few years back and it turned out that my rear Tyres were fitted inside out Bangdesk
Can you feel the vibration on the steering wheel?
[Image: image.jpg]
The following 1 user Likes S1NGH 911's post:
Ricky318i
12-08-2018, 06:53 PM
Post: #6
I had the opposite issue. Was fine under acceleration but when i let off the gas above 120km it would start shuddering.
After months of headache replacing suspension parts and wheel refurb it was still there.
Bought another set of wheels and tyres problem gone.
Try another set before you do anything else. I could have saved lots of money and time.
Current:
2017 Golf 7R DSG
EX Rides: 2010 e92 335i Rennzport Tuned, 2007 Golf 5 GTI DSG, 1991 e30 318i Vert, 1996 Jetta VR6 EXEC, 2002 Mini Cooper S, 2005 e46 320i Individual, 2007 E90 325i Msport, 1990 E30 318i, 1996 Golf 1, 2005 E82 130i Msport, 2011 E90 LCi 330d Msport, 1998 e36 323i motorsport, 2004 E46 M3 Vert, 2010 Audi A4 2.0T, 1998 E36 323i Motorsport
The following 1 user Likes Karsh330d's post:
Ricky318i
Post: #7
(12-08-2018 06:50 PM)S1NGH 911 Wrote:  This might sound like a silly question, but are the Tyres on the correct way?
Not a stupid question. I have learnt the hard way that one cannot expect good workmanship as a given these days. Confused1
I will check the wheels and have them balanced and wheel alignment done as well. Another check to do is to check the lug nuts and torque them.
12-08-2018, 06:55 PM
Post: #8
You might want to get the control arms checked out as well, if loose/worn they can also caused a vibration
[Image: image.jpg]
Ricky318i
12-08-2018, 09:36 PM
Post: #9
Could maybe be engine mounts?
The following 1 user Likes yush1's post:
Ricky318i
12-08-2018, 11:54 PM
Post: #10
(12-08-2018 06:33 PM)husaindindar Wrote:  Same problem here.
E90 325i.
Bearing/s might have gone in the diff, had a noisy diff like that, replaced the bearings, diff was quiet but I also found the rear universal on the prop is gone, hardly any movement left, right, up and down, knew that would be the source of the vibration but I wanted to test to be 100% sure for future reference, fitted the diff, no noise, only the vibration, removed rear part of prop, replaced u-joint, vibration gone, I would say 1st check the condition of the u-joint at the rear and repair if necessary before forking out on a diff repair/replacement.
Sent from Cape Town
13-08-2018, 12:00 AM
Post: #11
Place the car in drive, hold your foot on the brake and let the revs climb to about 2-3000rpm briefly holding the car in position. If you hear any vibrations or grinding or resonance its a mount, CV, control arm.
If you are doing the speed the vibration occurs at, pop the car into neutral, if the vibration disappears its in the drivetrain, check the prop, universals, gearbox mount and diff carriers.
To check your engine mounts, pop the bonnet, let your lady or a friend blip the throttle and take note of the engine movement, anything more than 2-3cm up and down would be engine mounts.
All of the above are weak components on BMW vehicles - Did engine mounts and gearbox mounts on mine at 74 000km and again at 100 000km. Control arms twice in 40 000km (ended up Polying the second set) and two front CV's (xdrive) for vibration on acceleration.
BMW X1 23d Xdrive - 190kw & 440nm
My Off-Road Journal
15-08-2018, 11:18 AM
Post: #12
Had the same problem in my 535D and turned out to be wheel alignment so don't be to quick to rule it out and its a cheap thing to check...
15-08-2018, 11:44 AM
Post: #13
is this vibration on the steering or can it be felt through the chassis?
Current rides
1995 E36 325i [Unfinished Monalisa]
2004 E46 330D M-sport [167wkw 556nm]
2012 Yamaha FZ6R - Stock
Ex Ride
1998 160i Conquest Rs
15-08-2018, 12:28 PM
Post: #14
Check inner CV Joints. I had that on a vehicle of mine, and was told by many different people that it might have been tyres, alignment, engine mounts, etc. Ended up taking it to a Propshaft centre and they diagnosed the Inner CV, refurbed it and it was all good.
I did not replace it as I could only get the part from the agents, and they wanted a fortune, and told me they don't supply just the CV joint, but the entire steering column... So was way tooo expensive. But the refurb did the work..
15-08-2018, 12:33 PM
Post: #15
Gents, I doubt we will hear back from the OP as the vehicle is being returned to the dealership he bought it from for much bigger faults.
My Off-Road Journal
15-08-2018, 12:34 PM
Post: #16
(15-08-2018 11:44 AM)Nikhil Wrote:  is this vibration on the steering or can it be felt through the chassis?
+1
Current : 2004 E46 330i MtechII A/T
Stainless Exhaust | Decat | Coilovers
21-08-2018, 02:53 PM (This post was last modified: 21-08-2018 02:59 PM by Ricky318i.)
Post: #17
(15-08-2018 11:18 AM)tank288 Wrote:  Had the same problem in my 535D and turned out to be wheel alignment so don't be to quick to rule it out and its a cheap thing to check...
I' having the wheel alignment done over the weekend.
(15-08-2018 12:33 PM)SMRTARSX1 Wrote:  Gents, I doubt we will hear back from the OP as the vehicle is being returned to the dealership he bought it from for much bigger faults.
LoL... OP isn't returning the vehicle to the dealership due to other bigger problems.
I will have the wheel alignment and balancing done. That is what OP will be doing.
+1
On my E34 i had a similar vibration due to a worn centre support bearing. I'll have all those components checked.
21-08-2018, 03:46 PM
Post: #18
+1
Did you diagnose the Yellow Drive Train error?
[Image: image.jpg]
21-08-2018, 03:51 PM
Post: #19
+1
Hi yes, it is a fault on the charge air temperature sensor. Upon checking the sensor, I found one wired connection to the plug loose.
I'm repairing the wiring tomorrow.
No EGR errors as I've read on other forums.
The following 1 user Likes Ricky318i's post:
S1NGH 911
Post Reply
User(s) browsing this thread:
1 Guest(s)
