Thread Rating:
  • 1 Vote(s) - 5 Average
  • 1
  • 2
  • 3
  • 4
  • 5
F25 X3 2013 recommended oil
10-07-2018, 07:37 PM,
#1
Hi guys,
So I'm self servicing my X3. Currently on 110k Kms.
I need to find out what's the recommended oil that I need to use and what else do I need to look at?
I'm also replacing the rear brake pads which seems pretty straight forward.
Any help will be much appreciated.
Thanks guys.
Website
11-07-2018, 04:18 AM,
#2
RE: F25 X3 2013 recommended oil
what engine is it Mr Roots?
Current rides
1995 E36 325i [Unfinished Monalisa]
2004 E46 330D M-sport [167wkw 556nm]
Ex Rides
1998 160i Conquest Rs
2012 Yamaha FZ6R - Stock
11-07-2018, 06:04 AM, (This post was last modified: 11-07-2018, 06:09 AM by FerdiBotha.)
#3
Shell Helix Ultra 5W-40 is very good. This oil is LL01, not LL04 as recommended by BMW, but many fanatics (including myself) have used it without any issue.
You could also go for Liqui Moly Top Tec 4100/4200/4605. Their properties differ slightly, but are all BMW approved and LL04. Liqui Moly oil is fairly expensive, though.
I’m currently using Liqui Moly Top Tec 4605 in my E90 330d LCI.
I’m of the opinion that 10k km service intervals are more important than what oil you are using, provided that the oil is the correct spec etc. I won’t be putting R150/5l Midas oil in my car, though.
Current:
[Image: b9c18a57-ca4d-430a-99f0-9f988a1b65a4_4874188881.jpeg]
Daily: Corsa Utility 1.4 Sport
SO: F20 120d
Previous:
E46 320d
Yamaha R1
Suzuki GSX-R 400
The following 1 user Likes FerdiBotha's post:
streetglow
11-07-2018, 07:55 AM,
#4
Buy the oil and pads from BMW and diy
Current:
M135i F20 Estoril Blue 6MT - Weekend Warrior
Opel Corsa Utility 1.4 Sport - Daily
SO:
320d F30 MSport Alpine White 8sp A/T
Gone but not forgotten:
Peugeot 207 HDi 1.6 HDi
Honda Civic Type R FN2 NHB
My Build Thread: M135i
11-07-2018, 10:18 AM,
#5
(11-07-2018, 06:04 AM)FerdiBotha Wrote: Shell Helix Ultra 5W-40 is very good. This oil is LL01, not LL04 as recommended by BMW, but many fanatics (including myself) have used it without any issue.
As far as I'm aware,
LL01 for Petrol Engines
LL04 for Diesel Engines
should be fine.
11-07-2018, 10:57 AM,
#6
(11-07-2018, 04:18 AM)Nikhil Wrote: what engine is it Mr Roots?
It's the 2.0 L Diesel bud!
Sent from my SM-G950F using Tapatalk
Website
11-07-2018, 11:11 AM,
#7
should be fine.
correct
12-07-2018, 10:56 AM,
#8
shell helix ultra 5w40 is perfectThumbs
Current rides
Ex Rides
12-07-2018, 03:35 PM,
#9
Thank you Nik. How does one put this car into service mode?
Website
12-07-2018, 04:53 PM,
#10
What do do mean service mode? Are you talking about the service indicator? Do want to reset it?
12-07-2018, 06:35 PM,
#11
No apparently if you push the calipers back you screw up the gearing. So the car needs to be in service mode apparently... I've never done brakes on it. So I don't know. I guess I need to ask how do you change rear brakes pads without messing with the positioning and electronics of the electric handbrake?
Website
04-08-2018, 07:06 PM,
#12
Consider servicing your ZF auto transmission also, 110k km is ideal.
We have a special running for new oil and sump/filter assembly for R3000 incl VAT.
Also get your transfercase and diff oils replaced, we can do that also for you.
27-10-2018, 10:29 PM,
#13
(04-08-2018, 07:06 PM)ZF Services South Africa Wrote: Consider servicing your ZF auto transmission also, 110k km is ideal.
Hi
Do you supply the oil for transfer case and diff oils ?
28-10-2018, 07:59 AM,
#14
Hi
ZF will supply transfer case oil, diff oil you need to source your own.
/o(O)(O) \ (lllllllll)(lllllllll) / (O)(O)o\
29-10-2018, 08:48 AM,
#15
Correct, ZF can do the transmission oil service as well as the transfercase.
Unfortunately we don't stock the various types of diff oils but if you buy from BMW we will gladly drain and refill with fresh oil again.
Nico
Users browsing this thread:
1 Guest(s)
Return to Top
