Post Reply
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
E63 M6 bearings
10-04-2018, 09:08 AM
Post: #1
E63 M6 bearings
Hi guys
Can someone advise which make of bearings are advisable to be put on these cars and whom in cape town i can contact to get this done.its a preventative measure for a car im purchasing.
Thanks in advance
'05 C55 AMG
x
'00 150i Ballade
'08 335i FRC
'06 Corsa Lite
'02 Chico
'04 M3 FRC
'03 Chico
'00 Chico
'07 330i
'06 S2000
'08 Type R
'97 M3
'92 Uno
'97 Vtec
Find all posts by this user
10-04-2018, 09:35 AM
Post: #2
RE: E63 M6 bearings
Oem bearings are normally the choice on this forum. king race , acl or vac is generally what the European guys go with
Current rides
1995 E36 325i [Power Flow exhaust + Uniq+ ]
2004 E46 330D M-sport [167wkw 556nm]
Ex Ride
1998 160i Conquest Rs
CthulhuAll Hail Cthulhu Cthulhu
The following 1 user Likes Nikhil's post:
thireshan
10-04-2018, 01:50 PM
Post: #3
RE: E63 M6 bearings
(10-04-2018 09:08 AM)thireshan Wrote:  Hi guys
Thanks in advance
BE Bearings with OEM rod bolts(new of course), finish and kla
2010 E92 ///M3 DCT LCi "Croxley Tuned" Ka-boom
2012 F25 X3 3.0d
Previous
2012 E90 320d Auto LCi - Stock
2008 E90 320i - Stock
1996 Astra 200tS - Durban Stock
1992 Kadett 16V Turbo - Very not stock
1992 Calibra 16V - Stock
1993 Calibra 16V - Stock
2006 Corsa UTE - Rockford Equipped
2004 Corsa 1.4+ Vat
The following 1 user Likes 922-ZN's post:
Peter@AEW
10-04-2018, 04:52 PM
Post: #4
RE: E63 M6 bearings
Thanks in advance
Like TUTU says:
BE Bearings if your budget allows as they have addressed some of the known issues.
Second option is Agents.
If you go the BE route get ARP rod bolts if not get OE bolts.
The truth is incontrovertible, malice may attack it, ignorance may deride it, but in the end, there it is. ~ Winston Churchill
peterkarvelas@gmail.com
The following 1 user Likes Peter@AEW's post:
922-ZN
10-04-2018, 04:54 PM
Post: #5
RE: E63 M6 bearings
Peter would you then run the car with these bearings with confidence for hundreds of thousands of km's?Or do another change after 100 000 or so? Also would you change to a thinner oil?
current: BMW E92 M3 (bearings could be fcukd)
10-04-2018, 05:06 PM (This post was last modified: 10-04-2018 05:15 PM by 922-ZN.)
Post: #6
RE: E63 M6 bearings
(10-04-2018 04:52 PM)Peter@AEW Wrote:  Like TUTU says:
Clamping tests have shown that ARPs tend to warp the shape of the rod, whilst they do offer the greatest clamping forces, I don't think this a great trade off.
OEM bolts have been shown to provide the most clamping force without distorting the rod
(10-04-2018 04:54 PM)individj Wrote:  Peter would you then run the car with these bearings with confidence for hundreds of thousands of km's?Or do another change after 100 000 or so? Also would you change to a thinner oil?
Just No, other than having a new crank made to increase clearances and tending to the detonation issues, changing bearings doesn't solve the problem, but caring for the motor PROPERLY, once bearings have been done, will extend the life of the engine.
It's a costly exercise for peace of mind, but worth every penny when you get behind the wheel IMO.
If I was racking up mileage on my car, I'd do bearings at shorter intervals, just to see what the wear is like, ie 100 000km, then 80 000km, then 60 000km and so forth, just to better understand, this obviously only with a beeeeeg budget
2012 F25 X3 3.0d
Previous
2004 Corsa 1.4+ Vat
10-04-2018, 05:09 PM
Post: #7
RE: E63 M6 bearings
Would run it to 200 000 Kms with those bearings.
Provided the engine is hot before being driven hard and oil changes happen every 10000Kms.
I might then use a 0W40 with Ceratec for added performance.
I am not advocating that others do the same merely my opinion if I were to drive one.
10-04-2018, 05:23 PM
Post: #8
RE: E63 M6 bearings
I like the idea, I just don't like the increased temps
2012 F25 X3 3.0d
Previous
2004 Corsa 1.4+ Vat
10-04-2018, 05:45 PM (This post was last modified: 10-04-2018 05:46 PM by BeemerFanatic.)
Post: #9
RE: E63 M6 bearings
From learning on this forum, Buying a second hand M car definitely needs new bearings no matter what's the mileage because you don't know how the car was treated, warmed up, oil services etc. also once done you need to take care of the car, warm up the engine, do regular oil changes
Also do a gearbox check / service. I just found out brakes on an M is like 30k
Wow makes me wonder if I will ever be able to afford any M car.
omg waiting
The following 1 user Likes BeemerFanatic's post:
Charlie Brown
10-04-2018, 07:03 PM
Post: #10
RE: E63 M6 bearings
(10-04-2018 05:45 PM)BeemerFanatic Wrote:  From learning on this forum, Buying a second hand M car definitely needs new bearings no matter what's the mileage because you don't know how the car was treated, warmed up, oil services etc. also once done you need to take care of the car, warm up the engine, do regular oil changes
omg waiting
True. If you treat it right, service regularly and don't hammer it from cold it helps.
A full OEM brake job on almost any performance car costs a lot of money. 350Z and STI both just below and just over that number for smaller discs and pads. There are alternatives like powerbrake etc. The last order of business before a car goes off plan should be brakes. Its why you see guys recommending that you take into account whether brakes will be required in the period before extending plan (If you are paying 30K for full cover and you are pretty much guaranteed at least a 36K brake job out of it, why would you not extend?)
Same for OEM suspensions.
You are right that first order of business for any car is service regardless of what history says and all preventative work done before even thinking of modding. Learned this the hard way!
[Image: rewYTSy.png]
11-04-2018, 12:22 AM
Post: #11
RE: E63 M6 bearings
Approximate pricings on the BE bearings and oem bearings and all the other needed stuff as mentioned above?
'05 C55 AMG
x
'00 150i Ballade
'08 335i FRC
'06 Corsa Lite
'02 Chico
'04 M3 FRC
'03 Chico
'00 Chico
'07 330i
'06 S2000
'08 Type R
'97 M3
'92 Uno
'97 Vtec
11-04-2018, 07:55 AM
Post: #12
RE: E63 M6 bearings
(11-04-2018 12:22 AM)thireshan Wrote:  Approximate pricings on the BE bearings and oem bearings and all the other needed stuff as mentioned above?
All in
Budget R30K for OE and R40k for BE.
11-04-2018, 08:48 AM
Post: #13
RE: E63 M6 bearings
All in
WithStu
2012 F25 X3 3.0d
Previous
2004 Corsa 1.4+ Vat
11-04-2018, 08:57 AM
Post: #14
RE: E63 M6 bearings
Ok..have they not changed the specs of the bearings for better clearance? Sorry i am not as technically minded as you guys but i am trying to get an idea. I read somewhere that measured OE bearings have changed over time & there is more clearance.
11-04-2018, 09:06 AM (This post was last modified: 11-04-2018 09:06 AM by 922-ZN.)
Post: #15
RE: E63 M6 bearings
They have changed the construction of the bearing on LCi models(eliminating lead and copper) not the structure, already the OEM bearings are too narrow for this motor
2012 F25 X3 3.0d
Previous
2004 Corsa 1.4+ Vat
11-04-2018, 09:42 AM
Post: #16
RE: E63 M6 bearings
i see Tune Tech are of the opinion that the stock bearings don't have enough clearance as in its too wide.
11-04-2018, 09:45 AM
Post: #17
RE: E63 M6 bearings
Nope they are too narrow
11-04-2018, 10:10 AM
Post: #18
RE: E63 M6 bearings
(11-04-2018 09:42 AM)individj Wrote:  i see Tune Tech are of the opinion that the stock bearings don't have enough clearance as in its too wide.
They are too wide for the crank, but as a whole, they are too narrow for the application, narrowing the oem bearing to increase clearance will be catastrophic.
2012 F25 X3 3.0d
Previous
2004 Corsa 1.4+ Vat
Peter@AEW
11-04-2018, 04:25 PM
Post: #19
RE: E63 M6 bearings
Man am I glad I don’t have an S65 anymore RoflRofl
Seriously, just stick to the OEM Bearings. They do last long if you don’t drive the car like a plonker. Think of it as a maintenance item and don’t agonise over it too much.
PMs don’t work, so if I don’t reply I’m not being rude.
The following 1 user Likes Ratslaaf's post:
922-ZN
16-04-2018, 06:10 PM
Post: #20
RE: E63 M6 bearings
I was of opinion that this bearing issue is just the natural aspirated M cars from e46 M upwards , but on Saturday I was at a friends workshop and there was a X6 M[twin turbo V8 ]with a bearing knock , they already done new turbos , then the knock , motor was stripped on the bench , needs new crank , when I enquired how much to repair , the parts-bill alone comes to r150 ooo , but this includes cautionary measures like new timing chain , spockets ,etc , and here I am waiting for the v8 m6's to become cheaper so I don't have to explain to everybody about the bearings is the reason why my cars are always idling for close on five minutes before I drive-off.
Post Reply
User(s) browsing this thread:
1 Guest(s)
