Post Reply
Thread Rating:
  • 1 Vote(s) - 5 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Use of MLS head Gaket
12-01-2018, 12:34 PM
Post: #1
Hallo All
New to Multi Layer Steel head gaskets, I Started up My kadett and oil was mixing with water and the other way around, then removed head, cleaned up everything and tried again, this time water and gas mix. I have not used any compounds or sealer, head was skimmed and reconned, is there anything i can do diffrently ? I suspect it leaks on the block side. And if so any recommendations ?
Current :
2009 BMW 125i
1994 Kadett 200iS
1974 Beetle
EX :
1995 BMW 328i
Find all posts by this user
12-01-2018, 06:59 PM
Post: #2
RE: Use of MLS head Gaket
mls gasket is designed for performance applications, if you are running a stock car and the above is the issue the mls might mask the problem not fix it
did you reuse the head bolts on the car when reassembling it
Current rides
1995 E36 325i [Power Flow exhaust + Uniq+ ]
2004 E46 330D M-sport [167wkw 556nm]
Ex Ride
1998 160i Conquest Rs
CthulhuAll Hail Cthulhu Cthulhu
13-01-2018, 06:53 AM (This post was last modified: 13-01-2018 06:54 AM by Gordvisr.)
Post: #3
Busy with a turbo application, used new head bolts.
https://www.bmwfanatics.co.za/showthread.php?tid=79837
a link to the build thread
Current :
2009 BMW 125i
1994 Kadett 200iS
1974 Beetle
EX :
1995 BMW 328i
13-01-2018, 01:16 PM
Post: #4
aaaah ok I see, was the surface of the block skimmed aswell? is the blow by / oil and water mixing in the same spot does it differ?
the overseas E36 community has very mixed reviews about mls gaskets more negative than positive in most cases. most guys eventually opt for a crush ring gasket after going grey with trying to resolve the issues experienced with the mls
Current rides
Ex Ride
The following 1 user Likes Nikhil's post:
Gordvisr
13-01-2018, 04:57 PM (This post was last modified: 13-01-2018 04:59 PM by Gordvisr.)
Post: #5
Nope the surface on the block was not skimmed, i will try the crushed ring gasket and a few other things and if all else fails, remove the motor and strip it down to send in the block, seriously hope i do not have to.
first it was mixing oil and water ( Oil in the water bottle ) and water to oil ( water to sump ) stripped down cleaned everything, that is sorted now but water goes to gas chamber and gas goes to water bottle.
Current :
2009 BMW 125i
1994 Kadett 200iS
1974 Beetle
EX :
1995 BMW 328i
13-01-2018, 06:16 PM
Post: #6
that sounds like a headache of note. keep us updated on the troubleshooting and how you've managed to resolve itThumbs
Current rides
Ex Ride
14-01-2018, 07:11 AM
Post: #7
Will do and thank you for your input.
Current :
2009 BMW 125i
1994 Kadett 200iS
1974 Beetle
EX :
1995 BMW 328i
14-01-2018, 01:19 PM
Post: #8
So After some input from Fellow Fanatics and pointed me in some directions i investigated a bit and found some more info on these gaskets.
Some MLS gaskets come with coatings , some not. Alternatevily Copper gasket sealer is used together with these gaskets to help seal it properly, so i will find me some and give it a go. Thanks to DannyOPC too.
https://www.bangshift.com/forum/forum/ba...s-sealants
Current :
2009 BMW 125i
1994 Kadett 200iS
1974 Beetle
EX :
1995 BMW 328i
The following 1 user Likes Gordvisr's post:
Nikhil
14-01-2018, 02:51 PM
Post: #9
Awesome let's hope that fixes it Thumbs
Current rides
Ex Ride
Post Reply
User(s) browsing this thread:
1 Guest(s)
