Post Reply
Thread Rating:
  • 1 Vote(s) - 1 Average
  • 1
  • 2
  • 3
  • 4
  • 5
E90 Issue after tappet cover gasket repair
17-07-2017, 11:01 AM
Post: #1
Hi Gents
Last week my wifes e90 323i had an oil leak, took to the mechanic and he said it was a leaking tappet cover gasket.
The repair was done and I drove the car home, about 600m. Did not notice any issues. That was Thursday.
On Saturday we decided to use her car and started it up, the car began to shake bad, idle was bad, tried to rev the car a little and it revved badly.
No CEL came on. Any ideas what the issue could be? I will be taking the car back. Any suggestions on the issue
Thank you
AKASH
Masstronix E90 335i AT Sportpack (JB4, DP, DCI. Race flash 275wkw @652NM at KAR)
E90 323i Sportpack
Find all posts by this user
17-07-2017, 11:02 AM
Post: #2
RE: E90 Issue after tappet cover gasket repair
Best to have codes read bud.
PMs don’t work, so if I don’t reply I’m not being rude.
17-07-2017, 11:04 AM
Post: #3
Check the ignition coils, may not be tightly fitted. Had exactly the same issue when I did my valve cover gasket.
[Image: designation_5632946002.jpg]
17-07-2017, 11:05 AM
Post: #4
(17-07-2017 11:04 AM)NtandoN Wrote:  Check the ignition coils, may not be tightly fitted. Had exactly the same issue when I did my valve cover gasket.
That was my guess, going to remove the cover and check them out
AKASH
E90 323i Sportpack
17-07-2017, 12:13 PM
Post: #5
Coils suspect
"Sheer Driving Pleasure" E90 323i LCI (Innovation Package)
"The Best Or Nothing" Mercedes Benz C180 BE Avantgarde
17-07-2017, 02:02 PM
Post: #6
(17-07-2017 12:13 PM)CK4LIFE Wrote:  Coils suspect
I had no issues with the coils previously. They however would have been removed and put back after the repair.
AKASH
E90 323i Sportpack
17-07-2017, 04:41 PM
Post: #7
Had the same issue this weekend, stop the engine and re-started, miss and shaking was gone. about 1500k ish I had my valvetronic replaced.
car will be heading to the mach on Thursday only.
Let us know what you found out OP please.
My Ride - e90 325i M-Sport
ex - 2004 e46 325ci
ex - 2004 golf MK4 GTI
ex - 1992 Golf MK2 GTS
ex - 1984 Mitishubi Colt Galant
17-07-2017, 04:53 PM
Post: #8
Had exactly the same issues with my neighbour's 2005 E90 323i after tappet cover gasket replacement. According to the codes it was the solenoid valves. After replacement no better. Eventually the owner took the car to Helderview BMW where it spent about two weeks. They could not find the problem. Cost him R5k but when he got the car back it was running fine (although they could not say what was wrong, they did replace a spring or something on the vanos system which they claim was a common problem)?? He got rid of the car soon after that.
17-07-2017, 05:21 PM
Post: #9
Thanks guys anyone in the midrand area that can help read the codes on he car
AKASH
E90 323i Sportpack
29-07-2017, 07:14 PM
Post: #10
Update
So Phypher13 came over today to help read the codes. Turned out to be the outlet vanos solenoid. We pulled both solenoids and gave them a clean. Fitted them back in, cleared the codes. First time startup no issues. I drove the car to gym and back home, no problem.
Thanks to my brother Shyane for coming to the rescue.
Thank you to DannyBoyOpc for also offering assistance while Shyane was away.
AKASH
E90 323i Sportpack
The following 1 user Likes akash's post:
Steph745
29-07-2017, 08:41 PM
Post: #11
Always a pleasure brother
CoolShake
Current: BMW 335i e92 7 Speed DCT Auto - Black Saphire
(Vargas 2+ Turbo, VTT inlets, K&N DCI, Rennzport CP+Tail BOV, jb4, BMS OCC, Wagner IC, n20 3.5bar sensor, ER Stage 3 LPFP, BMS Water Meth, Custom Backend Flash)
Current: BMW 320i e90 Sport = White
Cartel
Ex: BMW 320i e92 - Black Saphire
Ex: Audi TT Coupe 2.0 TFSI - Greenish Blue
Ex: VW Polo TDI - White
Ex: Mazda Astina 2.0 - Pearl Black
Ex: BMW 335i e90 - Sparkling Graphite
Ex: BMW 320i e90 pre facelift - Black Saphire
Ex: VW Golf 5 GTi - Red
Ex: Honda Civic Type R - Black
Ex: BMW 325i e36 - Red
Post Reply
User(s) browsing this thread:
1 Guest(s)
