Post Reply
Thread Rating:
  • 3 Vote(s) - 1.33 Average
  • 1
  • 2
  • 3
  • 4
  • 5
E90 M3 questions
19-06-2017, 09:27 PM
Post: #1
E90 M3 questions
Hi guys,
I have a few questions:
1. I've done 76k on my car, is it necessary to change brake fluid?
2. The diff is making a noise especially when you start up and drive a few km's. Should I replace with Rear Axle Fluid SAF-XJ +FM Booster (83 22 2 282 583)?
3. What's the best oil for the engine and how much should I buy?
Can all of the above be done by the local techie or who can I use on the East Rand?
Find all posts by this user
19-06-2017, 10:43 PM
Post: #2
RE: E90 M3 questions
1) If you brake fluid is dirty, which it probably will be, brakes must be bled and flushed for the change. Agents generally don't do a flush when you ask for brake fluid change
2) Not sure about diff
3) Liqui Moly 10w60 synthetic. Comes in purple can. Oil change, about 9-10litres
measure twice and cut once....
Post Reply
User(s) browsing this thread:
1 Guest(s)
