Post Reply
Thread Rating:
  • 4 Vote(s) - 2 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Coolant leaking
18-06-2017, 09:47 PM
Post: #1
Coolant leaking
Hi guys,
My 2011 335i keep on blowing radiators or hoses.
Can anyone show me in the right direction please.
Find all posts by this user
19-06-2017, 11:12 AM
Post: #2
RE: Coolant leaking
did you get your system pressure tested and a combustion gas test.
could be radiator cap is not working correctly OR you have crack in the head
19-06-2017, 05:05 PM (This post was last modified: 19-06-2017 05:06 PM by francoisellis28.)
Post: #3
RE: Coolant leaking
(19-06-2017 11:12 AM)Dhp507 Wrote:  did you get your system pressure tested and a combustion gas test.
Hi, the motor got about 38000km on. Was fitted by ceadar bmw. Don't think it will have a cracked head. Getting it pressure tested tomorrow.
I was on a overseas forum where they said somthing about the software, don't know if this is true or not.
19-06-2017, 08:24 PM
Post: #4
RE: Coolant leaking
The damage you refer to sounds like you getting excessive pressure into your system.
Radiator cap is a relief valve. .....an vents at a set pressure point. Read under the cap......should be three nos
Second item I proposed is if u have a hairline crack from head to water jacket. This will cause combustion gases to leak into the cooling system.
20-06-2017, 07:45 AM
Post: #5
RE: Coolant leaking
Hi,
would suggest you get a chemical test to check for compression gases in the cooling system like Dhp507 suggested.
Regards
John Lodder
Service Manager
Leo Haese Pretoria BMW
012 366 3000
john@leohaese.co.za
21-06-2017, 04:55 PM (This post was last modified: 21-06-2017 05:02 PM by francoisellis28.)
Post: #6
RE: Coolant leaking
(20-06-2017 07:45 AM)John@Leo Haese Pretoria BMW Wrote:  Hi,
Regards
Thank you so much, how much will that set me back.
See my radiator is leaking now again now BMW SA doesn't want to replace a warranty on a warranty. Fighting with them. They said I was suppose to take the car in the check why is it blowing the radiators. But all of the cost is on me. The motor is only got 38 000km on fitted by cedar BMW under motorplan. Since the new motor had endless crap.
22-06-2017, 01:45 PM
Post: #7
RE: Coolant leaking
Regards
Hi,
I think the last test we did at Reptec/Silverton radiators was about R500-700 there about, just call your local decent radiator place. We don't do it as the chemical as a shelf life by when you need to use it.
John Lodder
Service Manager
012 366 3000
john@leohaese.co.za
22-06-2017, 01:55 PM
Post: #8
RE: Coolant leaking
I paid 250 plus VAT
22-06-2017, 02:15 PM
Post: #9
RE: Coolant leaking
(22-06-2017 01:55 PM)Dhp507 Wrote:  I paid 250 plus VAT
Hi, where did you go to get it tested.
22-06-2017, 05:48 PM
Post: #10
RE: Coolant leaking
That is a good price.
John Lodder
Service Manager
012 366 3000
john@leohaese.co.za
22-06-2017, 06:31 PM
Post: #11
RE: Coolant leaking
I tend to agree with most replies, combustion gasses are generally what causes this. Does it give you any warning, ie, temp gauge going up past normal, if so, under what conditions?
23-06-2017, 08:42 AM
Post: #12
RE: Coolant leaking
(22-06-2017 06:31 PM)billbt Wrote:  I tend to agree with most replies, combustion gasses are generally what causes this. Does it give you any warning, ie, temp gauge going up past normal, if so, under what conditions?
Normal driving it sits at 107-112
Post Reply
User(s) browsing this thread:
1 Guest(s)
