Post Reply
Thread Rating:
  • 4 Vote(s) - 1.25 Average
  • 1
  • 2
  • 3
  • 4
  • 5
BMW E90 330i 2005 model Liqui Moly oil recomendations
14-06-2017, 05:00 PM (This post was last modified: 14-06-2017 05:02 PM by kurtg.)
Post: #1
Search BMW E90 330i 2005 model Liqui Moly oil recomendations
Good day,
Vehicle has been run on Castrol Magnatec for last couple of years.
BMW recommended oil BMW Twin Power Turbo SAE 5w-30, BMW Longlife-01
Which Liqui Moly oil can be recommend to replace the OEM oil.
Thanks in advance!
K
Find all posts by this user
14-06-2017, 05:04 PM
Post: #2
RE: BMW E90 330i 2005 model Liqui Moly oil recomendations
You can get the LM oil from Sean@axisengineered . Send him a pm and get there pricing.
The following 1 user Likes FiRi@Rennzport's post:
kurtg
14-06-2017, 05:56 PM
Post: #3
Moved to Oil Related discussions
Current Rides
2006 Audi A4 Avant 1.8T 5 M/T FRC TUNED
2006 Audi A3 Sportsback 2.0T S-Tronic Ambition FRC ECU & S-TRONIC TUNED
(Ex BMW'S 2006 335i, 2003 330i, 2002 325i 2000 540i, 1998 318i MS, 1992 325i MEX)
(NON BMW'S 2003 POLO 1.6, 2000 200 STI, 2000 RSI 20V, 1999 GTI, 1998 RSI 20V)
(1997 RSI 20V 1997 MICROBUS 1992 GLI T/C, 1986 GLI T/C)
The following 1 user Likes YUBEN's post:
kurtg
14-06-2017, 07:14 PM
Post: #4
Liqui Moly top Tec 5W30
AKASH
Masstronix E90 335i AT Sportpack (JB4, DP, DCI. Race flash 275wkw @652NM at KAR)
E90 323i Sportpack
The following 1 user Likes akash's post:
kurtg
15-06-2017, 11:36 AM
Post: #5
(14-06-2017 05:00 PM)kurtg Wrote:  Good day,
Thanks in advance!
K
I think most guys use LM 4100 5w40 which a LL01 oil.
Why don't you want to use the OEM oil ?
The following 1 user Likes Fuzz's post:
kurtg
15-06-2017, 11:51 AM
Post: #6
[Image: lm3701.jpg]
1993 E36 328i Sedan
2005 E46 330i Touring
Old BMWs never die, they just get faster!
The following 1 user Likes Gizmo's post:
kurtg
15-06-2017, 12:16 PM
Post: #7
Quick question@Gizmo
What is the difference\benefit of going to 5W40..instead of factory (5w30)
On a stock petrol I6 motor e46)
15-06-2017, 12:19 PM
Post: #8
Howdy Mr Gliem and welcome on the boards...
Top Tec 4100, 5W40 is what goes in all our 6 cylinders except the M3...
LM oil is so good I would even cook with it ...
'04 ///M3 Phoenixgelb/Kiwi. Yes, the color grows on one, but so does cancer Wink
'98 E36 323i Moreagrün/White. The sweetest old machine on the block.
Previous
'84 944, Supercharged
'06 Polo TDi, 121kw on the wheels until the headgasket went south...
'05 Fiesta, cause the damn Porsche was soooo reliable
And some other uninspiring moments...
The following 1 user Likes flyitlikearental's post:
kurtg
15-06-2017, 12:25 PM
Post: #9
Some reading:
http://www.zoniv.com/5w30-vs-5w40/
5W30 Motor Oil
5w30 is one of the two most commonly used types of motor oils for various reasons. First, it works surprisingly well with a broad selection of vehicles with different engine types. Second, the oil also covers a diverse range of possible temperatures, but is ideal for warmer temperatures. For the most part, the oil works smoothly regardless of the vehicle and the temperature.
5W40 Motor Oil
Although 5w40 is not as common as 5w30, it certainly does have quite many admirable features that optimize the health of your engine, some of which include:
Protecting the engine from deposit and sludge buildup and damage
Ensuring the engine revs to life quickly in colder environments and the oil circulates efficiently in freezing temperatures
Getting to moving parts of the engine fast
The 5w40 acts like a 5-rated single grade oil when it’s cold, but it does not become thin any more than 40-rated single grade oil when it’s hot.
5W30 vs. 5W40
When it comes to choosing between 5w30 and 5w40, many people prefer the former. This is because the 5w30 motor oil has a smooth effect on the oil pump and also a more suitable flow through the engine when hot. However, both these motor oils work great for providing faster lubrication to engine parts when you start the car.
5W30 vs. 5W40
So, if we dig in into technicalities, the number ‘5’ in both oils represents the same viscosity when the engine is cold (startup temperature), but in case of 5w30, the ’30’ represents a lower viscosity when the engine is operating at high temperatures as compared 5w40, which has a higher viscosity.
Takeaway
If you are racking your brain to choose between 5w30 and 5w40, we recommend you go with 5w30. However, if it is too expensive or not available for use, you can always go with the 5w40, which is just as good and will not cause any damage to the engine parts.
The following 1 user Likes Straight six's post:
kurtg
15-06-2017, 12:27 PM
Post: #10
(15-06-2017 12:16 PM)Straight six Wrote:  Quick question@Gizmo
Oil temps get higher at reef level so 5w40 is best. 5w30 is fine for coast, if you track the car at the coast then better to go 5w40.
1993 E36 328i Sedan
kurtg
15-06-2017, 12:34 PM
Post: #11
I'm at the coast and only go to Killarney as a spectator
So i'm good with W30 (OEM Oil)Ty
Gizmo
17-06-2017, 08:36 AM
Post: #12
Thanks for the info gents, much appreciated!CoolShake
19-06-2017, 01:54 PM (This post was last modified: 19-06-2017 02:23 PM by Fuzz.)
Post: #13
Having posted the VOA, BMW's Twin Power 5w30 would be my pick.
Loads of Boron and Moly to reduce friction as well a lots of Calcium and ZDDP to control acids and deposits, combined with Shell's new advanced group 4 fully synthetic GTL base, for the price seems hard to beat. Not forgetting a TBN of over 9 (LM 4100 is only 7,5 mg KOH/g) and a ultra low TAN due to the GTL base means you can go further with less worries.
An ultra robust additive pack with a high tec base will mean a longer lasting and cleaner engine.
If you want something with a slightly higher VI and HTHS but the exact same tech regarding the base, you cant go wrong with Shell Ultra 5w40. Ultra has a Total Base Number (TBN), this is additives added to the base oil to fight sludge, corrosion and acid deposits, of over 10mg KOH/g. Shell Ultra's 5w40 additive pack is near identical to the BMW Twin Power 5w30 but with slightly more calcium and zddp.
Not forgetting Shell Ultra 5w40 can be found for less that R380 for a 5L
Don't overlook Total Quartz 9000 5w40 either. Used oil analysis has shown this oil to knock the socks off tests especially in VW engines. Its a BMW LL 01 and Porsche A40 approved oil and goes for a great price around R350 per 5L. It is a group 3+ synthetic technology aka hydro-synthesized petroleum base oil and not a group 4 fully synthetic, but it makes up for that in one heck of an additive pack with crazy amounts of zinc and calcium. Used to run this is my 370z (weekend ride and occasional track day car) and track Golf (30+ hours of racing around Killarney recorded without opening the engine).
Nikhil
Post Reply
User(s) browsing this thread:
1 Guest(s)
