Post Reply
Thread Rating:
  • 4 Vote(s) - 3 Average
  • 1
  • 2
  • 3
  • 4
  • 5
BMW E46 N42 engine Timing chain
17-02-2017, 10:22 AM (This post was last modified: 17-02-2017 01:29 PM by zippy320.)
Post: #1
Hi Guys!
How often am I supposed to change the timing chain ? I spoke to a Dealership and they told me that it should be changed every 100 000kms , My cars mileage is now at 233 333 Exactly . The chain was changed at at 120 000 or around there .
Also the new redesigned chain tensioner was used at the time of the change . Should I change this again ? does it loose its tension over time?
Also when changing the chain , what should be changed with it in order to prevent future issues ?
Also , how big of a job is this , to change the chain?
I am getting two faults
2781 Camshaft sensor inlet ( I replaced this with a new one , fault still there )
27BB Camshaft control outlet vanos ( I took this out and cleaned it up )
My fuel consumption has gone up a little , and I noticed a little less low end power , and sometimes the car rattles a bit . But most times not at all . Sometimes it does make a funny noise at startup .
I was told that when these faults occur then it is the timing chain , either it needs to be replaced , the tensioner needs to be replaced or the timing is out .
Thanks guys for all input .
Just an Update , When I did the valve stem seals at SMG , I had asked them about the rails and guides and they told me that its all in good condition , this was last year sometime.
Current Cars
16 BMW F30 320i B48 LCI Automatic
02 BMW E46 318i N42 LCI Automatic
93 Mercedes Benz W124 E320 4 Door LCI Automatic
88 BMW E30 320I M20 LCI Automatic
Old cars
Hmm
17-02-2017, 11:30 AM (This post was last modified: 17-02-2017 11:33 AM by spikester666.)
Post: #2
RE: BMW E46 N42 engine Timing chain
Ignore my post, thought you had the 8 valve 318i.
Current Ride: 2009 BMW E82 120D Motorsport
PAST
2004 BMW E46 325ci F/L
2007 Seat Ibiza 6L 1.6 sport
2000 BMW E46 318i Pre F/L
1998 BMW E36 318is
Find all posts by this user
The following 1 user Likes spikester666's post:
zippy320
Post Reply
User(s) browsing this thread:
1 Guest(s)
