435i akrapovic link pipe with mpe
30-01-2017, 10:07 AM
Post: #1
Hey guys
I recently traded in my 135i for a 435i, I added the mpe and mppk and I am looking into adding the akrapovic link pipe that will replace the mid pipe and resonator. See image below. I have enquire at BMW if the pipe will be compatible with the mpe, but its looks as though it should be from the images. akrapovic is bmw approved and thus I get to keep my motorplan. My question is has anyone removed their resonator/middle box on a 435i or similar. As you can see in the picture, its a very small box. What were the results? My goal is to increase the volume of the exhaust. I had a similar setup on my 135i which was loud and awesome. see here:http://www.bmwfanatics.co.za/showthread.php?tid=48763 there was very slight drone at certain RPM's and gears, but nothing bad and the increase in sound was well worth it. From what I have read, the dual pipes of the link pipe eliminates the drone you would get compared to a straight pipe from cat to back box. Any opinions etc are welcome. ![]() ![]() 435i Msport - ppk - mpe
30-01-2017, 09:44 PM
Post: #2
RE: 435i akrapovic link pipe with mpe
Really interested to see the responses and what you find as I would like to use the same setup on my 435.
19-06-2017, 04:02 PM
(This post was last modified: 19-06-2017 04:02 PM by BrandonF1.)
Post: #3
Hey guys
So just some feedback. I decided to remove the resonator. So, in summary I have the oem cat, then a striaght pipe to the BMW MPE. It sounds great, zero drone, its louder and more throaty and i got a slight improvement in my fuel economy. I used power pipes and they did a great job. Here is a clip: https://www.facebook.com/135346859850122...330494761/ 435i Msport - ppk - mpe
19-06-2017, 11:11 PM
Post: #4
(19-06-2017 04:02 PM)BrandonF1 Wrote: Hey guys that sounds hot ![]() ![]() and this is still with the stock downpipe? imagine with a decat |
20-06-2017, 08:28 PM
(This post was last modified: 20-06-2017 08:28 PM by Dees_13.)
Post: #5
Sounds great.
So have you cut the resonator out and welded another piece in place to make it a straight pipe? Or have you replaced the entire mid pipe with a new piece? I've done a decat with the oem mid pipe into the mpe. I'm scared of a drone if I change the mid pipe Current:
2015 Chevrolet Utility 2015 335i M Sport - 248kw 460nm EX: 2014 320i M Sport 2013 320d M Sport 2006 Subaru Impreza STI - 12.5s / 257kw 508nm 2013 435i M Sport - 221kw 400nm 2011 Golf 6 GTI DSG - 12.9s / 214kw 465nm 2012 VW Jetta 6 1.4TSi 2011 Audi 2.0T Sportback |
20-06-2017, 08:34 PM
Post: #6
That sounds sick.. So it is basically a straight pipe from the stock converter to the backbox? I like the throaty sound.. And this is just revving, must sound sick on the road.
Looks like Power Pipes there in Fordsburg? Next to the rail tracks? Current:
'14 F30 ![]() '16 F30 318i LCI Manual, Alpine White III, Black Leather ![]() ![]() Mods: Optic Blue Lamin-X fogs, VPS light shields, CF Splitters, Mirrors, Ducktail spoiler, Aluminium interior trim upgrades... Retired BMWs: '12 F30 320d '12 F20 118i '09 E90 LCI 320i M-Sport '07 E90 320i Excl '91 E30 325iS Evo I |
03-07-2017, 04:37 PM
Post: #7
(20-06-2017 08:34 PM)cOlDFuSiOn Wrote: That sounds sick.. So it is basically a straight pipe from the stock converter to the backbox? I like the throaty sound.. And this is just revving, must sound sick on the road.Correct straight pipe from cat to back box, that's the one. very throaty, but makes more crackling similar to the a45 when the pipes are cold but engine is warm, then your typical 435i 'farts'. Overall, very happy. 435i Msport - ppk - mpe
The following 1 user Likes BrandonF1's post: cOlDFuSiOn |
03-07-2017, 04:52 PM
Post: #8
(03-07-2017 04:37 PM)BrandonF1 Wrote:(20-06-2017 08:34 PM)cOlDFuSiOn Wrote: That sounds sick.. So it is basically a straight pipe from the stock converter to the backbox? I like the throaty sound.. And this is just revving, must sound sick on the road.Correct straight pipe from cat to back box, that's the one. very throaty, but makes more crackling similar to the a45 when the pipes are cold but engine is warm, then your typical 435i 'farts'. Overall, very happy. Thanks for the reply and info, will be keeping this in mind. Current:
« Next Oldest | Next Newest »
User(s) browsing this thread:
1 Guest(s)
1 Guest(s)
