Post Reply
Thread Rating:
  • 3 Vote(s) - 2.67 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Oil service on 2009 Merc c200k w204
11-01-2017, 01:17 PM
Post: #1
Any one have one and done the oil service? Im looking for a step by step and also want to know what oil merc uses? Looks like most recomend mobil 1 0w40
Find all posts by this user
11-01-2017, 01:22 PM
Post: #2
RE: Oil service on 2009 Merc c200k w204
Look on http://www.benzworld.org -- there are a lot of articles on oil there.
11-01-2017, 01:38 PM
Post: #3
(11-01-2017 01:17 PM)BiZKiT Wrote:  Any one have one and done the oil service? Im looking for a step by step and also want to know what oil merc uses? Looks like most recomend mobil 1 0w40
First thing to get is an oil pump/Oil Extractor 12V DC, from Adendorff machinery mart. you will need that to pump the old oil out through the dipstick hole/pipe.
Cartel
Current: 2014 F30 320d M sport with M performance power kit
Ex: 2011 C350 CDI
[-] The following 1 user says Thank You to lebofa for this post:
Maljan (01-17-2017)
11-01-2017, 03:40 PM
Post: #4
Get the oil from the agents. There are only two different ones from them. Diesel and petrol. Its cheap cheap. I'm not too sure on 204 but on 203 the whole sump cover needs to come off which is a pain. The oil filter housing might have the nut type of special tool type cover. Nut type then you will need a bug socket. Special tool type you can open with oil filter tool. Normal sump nut underneath. Then youtube how to reset service light. OIl filter can be purchased from gold wagon but I don't like those. I get from agents. Its not that much expensive. They don't come with sump washer so careful not to lose it. You can reuse the sump washer up to about 5 times until they eventually start leaking.
11-01-2017, 03:51 PM
Post: #5
(11-01-2017 03:40 PM)Waseem 333i Wrote:  Get the oil from the agents. There are only two different ones from them. Diesel and petrol. Its cheap cheap. I'm not too sure on 204 but on 203 the whole sump cover needs to come off which is a pain. The oil filter housing might have the nut type of special tool type cover. Nut type then you will need a bug socket. Special tool type you can open with oil filter tool. Normal sump nut underneath. Then youtube how to reset service light. OIl filter can be purchased from gold wagon but I don't like those. I get from agents. Its not that much expensive. They don't come with sump washer so careful not to lose it. You can reuse the sump washer up to about 5 times until they eventually start leaking.
YesNo
why will you want to go through all that trouble of removing the whole sump cover when you can just pump the oil out?
Cartel
Ex: 2011 C350 CDI
11-01-2017, 04:15 PM
Post: #6
Because draining the oil the old fashioned way gets more of it out
Sent by my cellphone
12-01-2017, 05:26 AM
Post: #7
So you need to pump the oil out it does not drain thru the sump plug?
12-01-2017, 09:32 AM
Post: #8
Damn
Will this be the same for a 2006 c230 V6 coupe
CURRENT 2011 BMW 320d MPACK - DAMN TARMAC RIPPER
CURRENT 2006 VW JETTA 5 FSI 2.0T BWA DSG
Ex 1993 Jetta 3 Clx - 2l ADY
Ex 1992 Honda Dohc - Screamer Of Note
EX 2008 - E90 - 325i White - Sport Pack
Ex 2000 - Toyota Rxi 20VT
Ex 2007 - Toyota Run X Trd
Ex 1997 - Honda Civic Vtec
Eish thats all i can say
12-01-2017, 10:37 AM
Post: #9
(12-01-2017 05:26 AM)BiZKiT Wrote:  So you need to pump the oil out it does not drain thru the sump plug?
It does drain through the sump plug. Dealerships use the pump method to save time from removing the sump guard and replacing the sump nut washer. As fanatics we prefer to get every last drop out even if it takes all day. Workshops need to shift out the cars.
17-01-2017, 06:04 PM
Post: #10
ok did it all today and it was a mission removing all the covers so I can understand what they pump it out. Cant believe how cheap they are with oil and parts!!! R600 for everything including new plug and washer.
17-01-2017, 08:32 PM (This post was last modified: 17-01-2017 09:06 PM by Maljan.)
Post: #11
Very nice toy, only R295. I want one. Those last few drops can stay in the sump.
[Image: HPUMPO-002.jpg]
http://www.adendorff.co.za/ProductDetail...ACTOR/3715
BTW, I was once told that modern Mercs doesn't have sump plugs. Good to know that they are there if you know how/where to look.
Sump washer is easy. Go to Autozone/Midas/whatever. They stock them and you just need to know the size. Take the old one with you. Or measure it. Or ask them, they might know. Even if they are not sure, you can get one of each in several sizes. They are cheap enough for that. It will cost you more in petrol to take the wrong ones back than what they cost you.
Present BMWs:
'89 735i Auto
'01 325i Manual
'02 530i Manual
Past BMWs:
'79 520 Manual, '97 328i Manual, '97 528i Auto, '98 318is Manual
18-01-2017, 07:53 PM
Post: #12
Yeah merc is very well priced on parts
Post Reply
User(s) browsing this thread:
1 Guest(s)
