Post Reply
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Fender rolling tool
10-01-2017, 03:31 PM
Post: #21
RE: Fender rolling tool
Where are you located. I need my fenders rolled.
Sent from my SM-G900H using Tapatalk
Find all posts by this user
10-01-2017, 06:17 PM (This post was last modified: 10-01-2017 06:52 PM by Gizmo@GARAGE46.)
Post: #22
(10-01-2017 03:28 PM)KPAKKIRI Wrote:  does this tool flare the fenders?? My E36 M3 already has the fenders rolled. I think I need to flare them up a little.
Fender flares are actual extensions of the fenders, its material that you adding to fender to make it wider. The fender rolling tool rolls the inner edge of the stock fender to give you clearance for wider tyres or running lower offset wheels.
These are fender flares.
[Image: image__56664.1402013317.1280.853-1.jpg]
(10-01-2017 03:31 PM)Andrew M325iS Wrote:  Where are you located. I need my fenders rolled.
Brackenhurst Alberton, send me a pm for the full address.
2 pics of what it looks like. Will take pics in the use of it when I do the next set of fenders.
[Image: 20170110_183935.jpg]
[Image: 20170110_183944.jpg]
1993 E36 328i Sedan
2005 E46 330i Touring
10-01-2017, 10:31 PM (This post was last modified: 10-01-2017 10:31 PM by 335i MTX.)
Post: #23
Apologies if this seems like I'm hijacking your thread. I've got a set of 20's. No spacers required and wheels fit perfectly on lci e90. Rear tyres are 275/30/20. They rub a bit only on the fender lining / mudguard and not the fender itself. How would one fix this problem other than running a 25 profile?
10-01-2017, 11:02 PM
Post: #24
No problem on the hijack CoolShake
Current Rides
2006 E92 335i(196kw/439nm @ KAR 22/10/2016)
2003 VW Polo 1.6 Comfortline
EX Rides
2003 330i M 6 Spd
1997 VW Microbus 2.6i
2000 Corolla RSi 6 spd
1998 318i MS II
2000 200 STI
2000 540i A/T
2002 325i Sportspack
1998 Corolla RSi
1997 Corolla RSi
1999 VW GTI
1990 325i MEX
1993 Conquest RSi T/C 16
1992 GLI T/C 16
11-01-2017, 12:50 AM
Post: #25
(10-01-2017 11:02 PM)YUBEN@TheFanatics Wrote:  No problem on the hijack CoolShake
Shot bru. But worth mentioning that rolling fenders would be pointless if it's the fender linings that are affected and not the actual fender.
11-01-2017, 07:16 AM (This post was last modified: 11-01-2017 07:33 AM by Gizmo@GARAGE46.)
Post: #26
Fender linings are made of plastic and won't cut through your tyre sidewall. The metal fender has a sharp edge on the inside that does cut through sidewalls, this tool flattens that sharp edge and gives you a few more millimeters of space for wider tyres. This is common practice for e30, e36, e46 and many more owners who need more room. Its a strong possibility that e90 is different where fender linings get in the way instead of the fender like everything else. In your case you have too little wheel offset.
(10-01-2017 10:31 PM)335i MTX Wrote:  Apologies if this seems like I'm hijacking your thread. I've got a set of 20's. No spacers required and wheels fit perfectly on lci e90. Rear tyres are 275/30/20. They rub a bit only on the fender lining / mudguard and not the fender itself. How would one fix this problem other than running a 25 profile?
You muppet! Std E90 tyre circumference 1965mm, your 20 inch tyre 2080mm. Your tyre is too tall! Use a tyre calculator.
1993 E36 328i Sedan
11-01-2017, 09:01 AM
Post: #27
(11-01-2017 07:16 AM)Gizmo Wrote:  You muppet! Std E90 tyre circumference 1965mm, your 20 inch tyre 2080mm. Your tyre is too tall! Use a tyre calculator.
Here you go:
http://www.bmwfanatics.co.za/showthread.php?tid=64633
Current :
2002 E46 M3 Saving a M3
1990 E30 325i
2007 Volvo S40 2.0D
1990 Mazda Mx5 1.6
Has beens:
1990 Mazda Mx5 1.6
1984 Jaguar Xjs 5.3L V12
Mini Clubman GTS
1996 E36 328i
2000 E46 330i
1983 Datsun 280ZX
1974 VW Beetle 1.6
2005 E90 320d
2007 Nissan 350Z
2003 Subaru Blobeye STi
11-01-2017, 09:24 AM
Post: #28
Your problem is that the tyre is oversized, that size tyre is what I would run on my E60, you could remove the fender lining ( does the rear have a plastic lining?)
No, no, he didn’t slam you, he didn’t bump you, he didn’t nudge you… he *rubbed* you. And rubbin, son, is racin’. – Harry Hogge, Days of Thunder
Current Rides
[Image: car_on_fire_zps312a906a.jpg]
[Image: 166384.png]
[Image: 595162.png]
1996 200 Si Camry
11-01-2017, 09:30 AM
Post: #29
The tyre store advised that I go with a 30 profile. I should have followed my better judgment and insisted on 25 because I was going 2" up from 18" with a 35 profile. I should rather advertise the tyres so that I can replace with 25 profile or go with 265/30/20?
11-01-2017, 10:33 AM
Post: #30
My stock rims on my 335 were narrow and wides. 225/35/19 front and 255/30/19 rear. The 35 and 30 are aspect ratio/% of the width of the tyre (eg 225 x 35% = 78.75cm and 255 X30% = 76.5cm). So if you have real wide tyres in the rear, the tyre profile (sidewall) will be bigger. EG 225/35/19 the sidewall would be smaller than 275/35/19 and therefore the total diameter (outside diameter, not rim diatmeter) of the tyre too.
Also would bigger tyres/rims mean less torque eg 20" over 18"? Or would it be so small its irrelevant?
Current - E46 2002 M3 stock(ish)
Current - E92 2008 335i N54 FBO
Current - Skateboard for when N54 doesn't feel like working.
Ex - E46 2004 325ci
Ex - E36 1996 318is
Ex - Ford Escort
11-01-2017, 10:56 AM
Post: #31
(09-01-2017 11:51 AM)Psypher13 Wrote:  Hey bud
How did the rolling go at Powerflow?
Post a few pix for us to view please if possible
Ok so went to PowerFlow Fordsburg on Saturday, spoke to Ramon very helpful and pleasant dude. They don't roll fenders there, they shave them instead as its less prone to cracking. iirc I think they charge around R500...
Lifted the car to realize its not the fender that's touching, but my rear bumper :-(
All I did was changed from Toyo Proxes T1 Sport 255/35/19 to Falken FK453 255/35/19
Cry
[Image: Ci12.jpg]
[Image: Ci1.jpg]
[Image: Divio_BMWFanatics.jpg]
325Ci | ///M3
11-01-2017, 11:19 AM
Post: #32
Noob Question: Can the e46 M3 Rear fenders be rolled or must they be shaved ? I noticed that the E46 M3 rear fenders inner lip is quite thick.
///M POWER - Yes, money can't buy happiness, But it's more comfortably to cry in a BMW than to cry on a bicycle.
11-01-2017, 02:36 PM
Post: #33
(11-01-2017 09:30 AM)335i MTX Wrote:  The tyre store advised that I go with a 30 profile. I should have followed my better judgment and insisted on 25 because I was going 2" up from 18" with a 35 profile. I should rather advertise the tyres so that I can replace with 25 profile or go with 265/30/20?
What is the width of the rims, both back and front? My initial guestimate would be to use 225/30/20 (8j - 8.5j) and 245/30/20 (9j-9.5j) on ther rear which is 3% bigger than stock, but still 2.7% smaller than what you have.
Did you notice that using the 275/30 tyre raised your car by about 19mm at the rear
Current Rides
[Image: 166384.png]
[Image: 595162.png]
1996 200 Si Camry
11-01-2017, 05:07 PM
Post: #34
Cry
[Image: Ci12.jpg]
[Image: Ci1.jpg]
Ahh swank one...
At least you know what's up and can fix.
How are the falken compared to the Toyo t1
And price wise?
Current: BMW 335i e92 7 Speed DCT Auto - Black Saphire
(Vargas 2+, VTT inlets, BMS dci, CPE CP+BOV, jb4, BMS OCC, Wagner IC, n20 3.5bar sensor, BMS Water Meth, Custom Backend Flash)
Current: BMW 320i e90 Sport = White
Cartel
Ex: BMW 320i e92 - Black Saphire
Ex: Audi TT Coupe 2.0 TFSI - Greenish Blue
Ex: VW Polo TDI - White
Ex: Mazda Astina 2.0 - Pearl Black
Ex: BMW 335i e90 - Sparkling Graphite
Ex: BMW 320i e90 pre facelift - Black Saphire
Ex: VW Golf 5 GTi - Red
Ex: Honda Civic Type R - Black
Ex: BMW 325i e36 - Red
15-01-2017, 04:24 PM
Post: #35
[Image: img-20170112-wa0004_3023785119.jpg]
[Image: img-20170112-wa0005_659775519.jpg]
Current Rides
EX Rides
2003 330i M 6 Spd
1998 318i MS II
2000 200 STI
2000 540i A/T
1998 Corolla RSi
1997 Corolla RSi
1999 VW GTI
1990 325i MEX
1992 GLI T/C 16
15-01-2017, 04:25 PM
Post: #36
Thanks guys. The fenders were expertly rolled by Auto Lounge. I would highly recommend them for your fender rolling needsClapper
Current Rides
EX Rides
2003 330i M 6 Spd
1998 318i MS II
2000 200 STI
2000 540i A/T
1998 Corolla RSi
1997 Corolla RSi
1999 VW GTI
1990 325i MEX
1992 GLI T/C 16
[-] The following 2 users say Thank You to YUBEN@TheFanatics for this post:
Iry-gp (02-01-2017), steffarmer5 (01-16-2017)
Post Reply
User(s) browsing this thread:
1 Guest(s)
