On the e36 and e46 the rear trailing arm bush is a known weak point and fail often
further more they deflect sideways under load causing unwanted Toe changes, an unstable rear end as well as increase tire wear
Axis RTAB limiters address this by closing up the gap in the housing controlling Toe without negatively affecting control arm movement
made of bearing grade self lubricating polymer these will never need replacing and allow the arm to move very smoothly
combined with a high quality rubber bushing this is a complete solution:
Extended bushing life
Extended tire life
smooth control arm movement
Better performance with more consistent grip under load
as with all Axis products Lifetime warranty and customer support
Extended tire life
