Post Reply
Thread Rating:
  • 16 Vote(s) - 2.25 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Rough Rider 325i
25-04-2015, 01:41 PM
Post: #1
Rough Rider 325i
Hi ppl
So got the car that I have been looking for and got it for cheap
Its a 92 e36 325i non vanos
[Image: image_2896464047.jpeg]
[Image: image_1_653206384.jpeg]
[Image: image_2_8041748986.jpeg]
[Image: image_3_8535927827.jpeg]
[Image: image_4_112072573.jpeg]
I am still not really sure with which direction this car will go, I originally was looking for a drifter, but I might just like the street car feel
Performance Mods
CAI
Elec Fan
ECU Chip
6-2-1 headers
Freeflow single pipe with 2 boxes
under drive pulleys
alum flywheel
3.46 rear diff
Remove Clutch delay Valve
m50B30 conversion
Supporting mods for the m50B30
Rebore Throttle Body
Port and Polish
Bigger Valves and swirled
Slight skim on block
m5430 bottom end
Balanced Crank
Regrind Cams
Suspension for drifting setup
New Tie Rods
e46 wishbones with e46 wishbone 60mm bushes
Modded Hubs 20mm shorter
4mm rack spacers
25mm wheel spacers
Coil overs
Bigger Front swaybars
Poly Bushes
Front Strut Brace
Rear Strut Brace
X Brace
e36 z3 steering rack
I also want to try drop some weight on this fatty will keep the updates coming
sorry for the shitty pics
Find all posts by this user
25-04-2015, 03:02 PM
Post: #2
Rough Rider 325i
Welcome. All the luck on your future plans.
The following 1 user Likes Imraan's post:
Captain_Stealth
25-04-2015, 04:49 PM
Post: #3
RE: Rough Rider 325i
Welcome man. Best of luck with the build!!
If I remember correctly I don't think the Non-vanos E36's had a Clutch delay valve. Could be wrong though?
Looking forward to the updates!
Live Now Pay Later
The following 1 user Likes J-Peter's post:
Captain_Stealth
25-04-2015, 04:58 PM
Post: #4
(25-04-2015 04:49 PM)J-Peter 325 Wrote:  Welcome man. Best of luck with the build!!
Actually I think u right cdv was from 96+
I think
26-04-2015, 12:11 PM
Post: #5
Gratz on the new ride.
Keep us updated with your modz, pics etc, that's if it aint to much trouble. It might just benefit those wanting to do the same.
Come over to the "Dark Side", we have cookies there!
The following 2 users Like ballisticz466's post:
Captain_Stealth, travys
26-04-2015, 03:32 PM
Post: #6
(26-04-2015 12:11 PM)ballisticz466 Wrote:  Gratz on the new ride.
+1
Subbed
Inlove M50tuB25
The following 1 user Likes danieljames's post:
Captain_Stealth
26-04-2015, 07:25 PM (This post was last modified: 26-04-2015 07:30 PM by Captain_Stealth.)
Post: #7
Took my wife out for a bit of a Hooning session. And I am so addicted to this car. Best money I have ever spent lol
One of my previous cars that I had was a civic dohc vtec and I missed that car so much until I got this. NO HONDA will ever compare to a cheap and fast beemer !!!
Unfortunately I dont have time yet to start tinkering with the car, but the plan is to keep the cosmetic appearance the same and do performance mods instead
I am gonna try get it to the dyno this week to see what kind of numbers its putting down.
Unfortunately it doesnt have the stock exhaust system because of some hack job as I wanted to do a 63mm single pipe with 2 boxes and compare the difference in performance gains.
After these small little issues have been resolved I want to start with the weight saving
I will already be saving quite a bit with the above exhaust system and I want to do some weight saving.
Found this info which I am still deciding what to remove
[Image: bmwe36weight2_379501259.jpg]
Unfortunately this car will not be worth restoring as it needs ALOT of cosmetic work, hence why I am creating a hoon missile
btw here is my exhaust thread
http://www.bmwfanatics.co.za/showthread.php?tid=65594
27-04-2015, 06:31 PM
Post: #8
How to repair the sunroof
Here is a how on how to repair your sunroof
Step 1. Clean the area
Step 2. Stick it with box tape
Done Crazylaugh
[Image: image (1)_1132196509.jpeg]
[Image: image_8265275713.jpeg]
[Image: image (2)_628562779.jpeg]
I plan on doing a sunroof delete soon, so stay tuned
01-05-2015, 08:41 AM
Post: #9
Ouch Sorry
Hope you get this car in a better shape soon. it is really sad to see a car in this kind of shape.
02-05-2015, 03:37 PM
Post: #10
(01-05-2015 08:41 AM)Gordvisr Wrote:  Ouch Sorry
I know its a bit of a wreck but for what I want it for its perfect
Took it to the dyno today Bluebiggrin
[Image: image_1_203066905.jpeg]
[Image: image_8706716392.jpeg]
So the Numbers were
87.9wkw @ 5722rpm
160Nm @ 3801rpm
Not sure what what a Healthy 325i should be pushing but I am pretty happy with the output even with its leaky exhaust lol
This was at the KAR dyno in Kempton which is a bit stingy on numbers
If anyone could let me know what stock e36 325i's are pushing on the wheels that would be great
The following 1 user Likes Captain_Stealth's post:
Nikhil
07-05-2015, 04:25 PM
Post: #11
looking good mr stealth...
Can already tell that you will enjoy that car...good luck with your plansCoolShake
[Image: P7PwjzYLiIUxDG8okuJvf56H0akeDc-WA71BeR32...48-h180-rw]
E92 335i 6mt
E36 vert 325i S50b30 swapped
E36 sedan 316i M50b25 swapped
E30 Hok
The following 1 user Likes ver328i's post:
Jay-Dee
09-05-2015, 12:08 AM (This post was last modified: 09-05-2015 12:12 AM by Iceman007.)
Post: #12
I really dont get it. I got an idea for you. Go test drive an e36 328i or e46 330i and then ask yourself why spend money on mods when you can rather get an upgrade for the same value and less effort.
If you wanna build a track or drifting car, then by all means go for it. But for a daily and speed there are much better ways to go
Just my 2c. And those e36 325i are slow but reliable. Im not trying to shoot you down just trying to tell you there are better options to go for.
[Image: small2_zpse3adb13c.jpg]
[Image: 217041.png]
E46 2003 325i Sold
E90 LCI 2009 325i Trade in
F30 2013 320d upgraded
F30 2016 330d current
09-05-2015, 10:52 PM
Post: #13
(09-05-2015 12:08 AM)Iceman007 Wrote:  I really dont get it. I got an idea for you. Go test drive an e36 328i or e46 330i and then ask yourself why spend money on mods when you can rather get an upgrade for the same value and less effort.
By all means I agree with you but I never said this will be my daily.
Just a funcar, I have another car that I use for a daily
The following 2 users Like Captain_Stealth's post:
Nikhil, Revs
11-06-2015, 01:13 PM (This post was last modified: 11-06-2015 01:15 PM by Brucet.)
Post: #14
Iceman - while I agree with you to a certain extent it also depends what this car cost.
My e36 328 race car cost me half of what similar other vehicles cost mainly because I was stubborn and didnt listen to a lot of the "expert (from forums) advice" and did everything myself. Yes I couldve started with a better base but in my case, my build was/is still cheaper by a long way than it would have been if i started with that better base like you mention. (By at least half)
Half the fun in a project like this is the actual building of the race/play car and with the replacement value of e36 323/25 and 328 motors you could actually just do a bolt on turbo conversion and run low boost until it blows up, then you just buy another motor (have a mate who ran his road car for 5 years on one motor like that).
Having said that if you are the type that just pays for it to get done then start with a better base because either way you are going to have to cough it up.
The following 2 users Like Brucet's post:
Captain_Stealth, zulu
11-06-2015, 03:03 PM (This post was last modified: 11-06-2015 03:05 PM by Captain_Stealth.)
Post: #15
To be honest I bought this car as a drift missile
Its cheap fast and nasty!!!
I have made some progress with the build but I havent updated as I feel this build would be better on a drifting forum
If I had to buy a "clean" e36 then I would comments like you ruined a mint example.
Brucet
11-06-2015, 03:13 PM (This post was last modified: 11-06-2015 03:15 PM by Dewald Basson.)
Post: #16
(11-06-2015 03:03 PM)Captain_Stealth Wrote:  To be honest I bought this car as a drift missile
Share you stuff I rate it is cool. Amateur drift cars have character because they show use & abuse. It is not a showcar it is drift car, like this orange machine in the pic Rollsmile
[Image: bmw_e46_drift_by_kolegu-d4wod0z.jpg]
Don't worry about the other peoples opinions and bla bla bla bla bla. Do what you want, just don't drift on public roads.
The following 2 users Like Dewald Basson's post:
Brucet, heavyd89
11-06-2015, 05:25 PM
Post: #17
If u do update your build on a different tjread/forum....Please drop a link around here as there's always info to be gained. Good luck boet.
Inlove M50tuB25
Jay-Dee
11-06-2015, 06:59 PM
Post: #18
hmmm...
I surprised there is interest in this build here, I will post pics soon just too lazy but this arrived in the post today
I am currently busy with some interior work. When I am done I will post pics
but as promised here is my latest part
[Image: image_8267032578.jpeg]
danieljames, Dewald Basson
23-06-2015, 09:08 AM
Post: #19
Hey Captain,
Keep us posted on your build, we dont care what its used for....we like to see how other guys are building their cars, or well....at least I am interested.
Keep it up - then another question....what is the above part for? Silly question...I know.
23-06-2015, 09:13 AM
Post: #20
(23-06-2015 09:08 AM)JayDrft Wrote:  Hey Captain,
WithStu
Current rides
1995 E36 325i [Unfinished Monalisa]
2004 E46 330D M-sport [167wkw 556nm]
2012 Yamaha FZ6R - Stock
Ex Ride
1998 160i Conquest Rs
Post Reply
User(s) browsing this thread:
1 Guest(s)
