F30 320i Sport Smoke on startup
VinnyJ
This morning when started my car there was some white smoke that came out from the exhaust. Is this normal, when i drive or rev the car while sitting in traffic there is no smoke at all. Bear in mind i last used the car Tuesday evening. Car only has 36000km.
Anyone had this happen on their F30?
Gbmw
No, but u a twat for not driving the car :rollsmile:
How heavy was the smoke bud and how long she smoke for ?
VinnyJ
Lol wassup Mr Neo... hows my wife and kids???
Eish man i was in botswana and on tuesday when i left the airport there was no smoke. Car sat from from Tuesday night and used it again this morning. Smoke was quite heavy.... and smoke is just on the initial start, thereafter nothing. have not contacted BMW as yet, but guy at work tells me he has the same issue on his ISF when it stands for a while... over fuel???
Iceman007
Turbo. My dealer where I go have replaced a few turbos on the F30 320i already. BMW is full of shit. The mechanics first have to take off the pipes and check for oil residue and take photos on the intake and exhaua side of the turbo. Then send it to BMW. Then also has to go on the computer to check for mods(chip software) etc. Then wait for approval from BMW.
Ralf*
I will go with oil smoke, if it was white.
After standing for a while, there might be some seepage of oil from the valve-stem seals, which found its way into the cylinder barrels, and on first ignition, this oil is burnt off.
you might also find that under deceleration against compression, that there is a bit of white smoke
from my apprenticeship days some rule-of-thumb
1)Smoking whilst under acceleration = piston rings
2)Smoking whilst under deceleration against compression = valve stem seals
as long as there isn't continous smoke, and as long as oil consumption is minimal, and as long as there is no noticable powerloss, then don't worry....JUST YET
some more "clued-up" BMW mechanical purists (read LZ/Alexander/Gizmo( might have a better answer, but thats IMHO
RR001
Banned
What year model is your car?
From 2013 onwards there was quiet a few changes made
VinnyJ
its a 2012...
Thanks man. Which dealer do you use? I haven't noticed any smoke again since that day. weird. Car runs like a dream, no power loss. No excessive oil use, and fuel consumption is normal.
dsrolle
I now have exactly this same problem. The dealer first told me nothing was wrong, then replaced the "turbo cover" which did not work now they have to order some pipe for "below the turbos".
VinnyJ
I have had that same pipe replaced... believe me it does not solve the problem. My car still smoking on start. Which dealer is this? Clearwater?
Sent from my SM-N9005 using Tapatalk
dsrolle
No. I live in Nassau Bahamas. Mine is a 2013 320i
LPM320
Had the same pipe replaced on a f30 320i, and it solved the problem. Car was much better to drive thereafter as well.
///Dees
I just experienced the same problem now. My car stood for 4 days and upon startup there was a huge puff of white smoke. Mine is a 2013 320i with 80k km on the clock.
dsrolle
Mine is going back next week to have the "turbo pipe" changed.
Justdrew
///M3 - ZN said:
its the turbo .
i had mine replaced with the dealership , no issues .:coolShake:
Which dealership did you use?
I have a 2012 f30 320i 84000km's on the clock.Took the car 3 times to Club Motors in Ranburg with no luck, they replaced some turbo pipes and cleaned the turbo, claimed the car was fix, but still smoked there after.
Tried South East Auto in Germiston, car stayed with them for a week - they ordered a manufold , they replace the manifold- started the car on Saturday morning - car smoked like before.Called them on Monday to complain, the service advisor told me to drive it for a week, apparently there was still oil in the exhaust - need to burn out.Well, I'm confused, car smoked slightly this morning on cold start.
Any advise on which dealership to try next?
