E46 320 - Cooling system disaster
Prev
Administrator
Last week the cooling system on the E46 320 decided it had enough of its life and imploded. Luckily it was around the corner from home so after waiting for it to cool down sufficiently, it limped home.
Suspect that the water pump ceased and here's the results
Also noticed the radiator top hose was discolored and I suspect close to failure
So I have stripped most of the parts off the car. Just need to get the oil transmission cooler free from the radiator mount and then the radiator can come off
Prev
Administrator
Parts list for the work
Radiator
Water pump
Water pump pulley
Viscous
Fan blade
Fan shroud
Serpentine belt
Radiator top hose
Anti Freeze
Will also replace the 2 belt tensioners whilst at it and considering changing to an electric fan but need to do more research on that.
Sankekur
Might be a good idea to also replace the expansion tank and lower radiator hose, as you will be removing them in any case.
I have to say that is a pretty spectacular viscous fan and waterpump failure, glad you where close to home when it happened.
Is it still the original waterpump?
It might be worthwhile to swap to the electric fan used on the manual e46's....pretty potent fan.
Oh and remember to replace the coolant only with a 50/50 mix of BMW coolant and distilled water.
Andrew
I would also look at replacing the transmission oil cooler .... The membranes inside are extremely fragile and the last thing you need is your fresh coolant running through the gearbox. If I recall a new one costs around R800
Prev
Administrator
Thanks Sankekur. Will add the expansion tank and lower radiator hose to the shopping list :thumbs::cry:
Unfortunately it is not the original water pump. It was changed some 18 months ago with an aftermarket pump. Won't be making that foolish mistake again :fishwack:
Prev
Administrator
Thanks Andrew. Will look at that option as well
Sankekur
Hmmm. That is rather shocking, seeing as it looks (from the pic at least) that the whole shaft sheared off.
Have you removed the pump from the block yet? Is there damage on the inside?
Do you know what brand pump it is or where it was bought (not witch hunting, would just be interesting to know)
Prev
Administrator
The shaft did shear off on the outside but inside where the metal impeller is all good. I removed the water pump last night with Kish2604 help. Don't know what brand but it was bought at a well known local spares shop that supposedly specialises in BMW parts. Needless to say I won't ever buy anything from that shop again.
sash
BMW has the cooler at 1500, you can slightly cheaper ones from places like Silverton radiators .
S
S1NGH 001
Sorry Prev :thumbdo:
It's gonna be a heavy bill, I overhauled the cooling system on my E39 a year back, give me a shout if you need any assistance :thumbs:
Jamaine
Yor bru that's heavy sorry to hear need any help give me a shout im good at passing tools :rollsmile:
Prev
Administrator
Got a BEHR radiator from Silverton for R1596 incl.
From BMW: prices excl VAT
Water pump R1355.26
Water pump pulley R428.43
Serpentine belt R425.85
Top radiator hose R555.59
Lower radiator hose R448.19
Expansion Tank R1281.48
Fan blade R850.08
Fan clutch aka viscous R2323.79
Fan Shroud R401.24
BMW anti freeze R61.94
:argh::cry: time to apply for another bond at the bank
samman325
Sorry to hear about the explosion under your bonnet. Same thing happened to my brother as well on his 330i.
I have a fan blade thats available (think its original bmw but can confirm if you interested).
I opted to use the fan blade traditionally found on the e36 325tds which has the outer rim as well holding the blades intact.
Prev
Administrator
Thanks Bud. Will let you know on that.
At this point I have only purchased the following items
Radiator
Water pump
water pump pulley
serpentine belt
top radiator hose
anti freeze
Going to reuse the bottom radiator hose and expansion tank for now as those still appear good. Will change them down the line not to far from now.
Strongly considering installing a BEHR electric fan at R2300 as apposed to the BMW supplied fan clutch, blade and shroud for R3450 or BMW supplied electric fan for R6300 :argh:
Prev
Administrator
KyleNaidoo said:
similar thing happened to my 320i, but on new years day :cry:
Shout if you need help :thumbs:
Thanks bud. Most of the old stuff is off. Just need to pop the expansion tank off (easier said than done) and then the old radiator can come off. Then all the other stuff can go on.
Prev
Administrator
Heven said:
Hmmm. Tuned in. Please take plenty of pics.
Haven't taken any pics of the removal process but will take of the fitment process. That area has a lot of dirt, oil and grease build up from the time when the cam over gasket was leaking and the power steering oil tank sweating. so hands are way too filthy to take pics. Does any know how to stop the power steering tank sweat?
Will be getting a few bottles of degreaser and giving the area a good cleaning.
Prev
Administrator
BTW BMW has a core charge on the water pump if do not return the old pump to them. Apparently the recondition the old pumps. Now although the pump that failed this time was an aftermarket pump, luckily I still had the OEM pump that was previously removed. BMW will be shocked to see what that looks like as it has been standing outside for past 18 months :biglol:
