Gents (and ladies),
I've noticed a turbine like sound and have sourced it to my engine fan. The sound gets progressively more turbine/induction like as the revs increase, which makes sense. The problem is that the shock towers, bonnet and fenders get very, very hot. Both the engine fan and aux fan are working. The temperature needle is at 90 degrees and I know it's working because I neglected to fasten my expansion cap a while ago and the needle went to the red :facepalm:. Apart from that it never exceeds 90 degrees.
It does not happen that often (have noticed it on hot days and when towing in town) but I am concerned due to above mentioned body panels getting hot enough to cook an egg.
Seemingly the temperature gauge and fans work. The engine fan has a slight resistance to it as it should be with viscous fans and the electric aux fan spins freely. The water pump was replaced a while ago as a preventative measure. The coolant level is normal.
I don't know if the thermostat is working properly. Would a faulty thermostat cause the gauge to go beyond 90 degrees?
Any other thoughts?
Edit: on our 316i when I compress either radiator hose (when cold) I can hear the thermostat clicking (probably not the thermostat opening or closing but just the "lid" thingy wiggling) and feel it on the other hose. It does not happen on the 323i.
Edit 2: with "90 degrees" I mean the temperature needle is at 12 'o clock, which may actually be 90 degrees Celsius, too
Any other thoughts?
