Help!! M43 Mixing oil and water
sazwex
I have a 1999 E46 318i with an M43 engine. What started out as just a small leak in the radiator has turned into a nightmare!!:cry: To cut to the chase, we warped the cylinder head quite badly and opted on importing a good 2nd hand head from the UK. It was fitted and after running quite smoothly for a few mins; 5-10 we noticed steam from the exhaust and the oil had mixed with coolant and we thought to skim it some, which we did. Fixed it back on with yet another new gasket and again in the same time frame steaming exhaust and a mix of oil and coolant.:argh: It passed a pressure test. Quite a load of cash :argh:and several opinions later:blab:, a cracked block, gasket quality and torquing of head bolts were all ruled out. Any ideas what what could be wrong here?:biglol:
bmw328
Cracked aliminium block or if its cast iron, might be rusted at the top of the ports were the head and headgasket meet, causing it not to seal as it should Had such an issue with my 7 series.
PS, The old E30, E36 M40 engine block is the same as the M43, everything can be swopped! I'll recommend u also redo the engine after it's overheated that much. Bmw piston & rings normaly don't last long after overheat! (Start to smoke)
Peejay
Events Organiser
Doomsdaya said:
Will this fit an e36 328i or is only meant for M3 ?
moranor@axis said:
Heven said:
Charlie Brown said:
To my knowledge - no oil cooler on the M43tu motor. Cracked block maybe ?
Plus 1.
Maybe a second hand engine might be a better idea?
no why it has an engine oil cooler... only the e46 M3 comes with one...
Yes M3s do have engine oil coolers. But also most newer BMW have automatic gear box oil cooler built into the radiators.
Heven said:
moranor@axis said:
Heven said:
Plus 1.
dont know much about auto boxes :yuck:
but if the oil in the coolant is coming from the gearbox then that does not explain the steam out the exhaust...
sazwex
Wow! Thanks guys!:bravo: I am overwhelmed. :ty: and I really don't know what to touch first. For starters, it has an auto box. I don't see an oil cooler or heat exchanger so I figure it doesn't have one. If the problem was on the transmission oil cooler, how would that affect the engine oil? A replacement engine sounds like a great escape but I would like to know what is wrong with this engine before I pursue that option. The mechs ruled out a cracked block because the pistons are intact. Saying heat that would crack the block would surely melt the pistons :idea:dunno oh and its coolant in the engine oil not the other way around
Pfw28
Just another 2c, but did anyone check the top of the block for flatness? May also need a skim. :fencelook:
Peejay
Events Organiser
This could be a possiblity?
What block is it? Cast iron or aluminum?
sazwex
Opted to import an engine. As the old engine was built for Japan and the replacement unit is ex-South Africa, we faced a small challenge with something the mechs refer to as a secondary air pump :flyfun::argh: The SA engine doesn't provide for it so we left it out to protect any warranties and I drove it out some 300km and the darn car jus wasn't performing and check engine light was on 350km out at a top speed of 110kph and what do you know?? Suddenly the light goes out and I'm easily getting speeds in excess of 180kph :joy:
I don't know what kicked in but I can safely say I am have with the performance now:rollsmile: and thank you all for coming to help! any one looking for M43 engine spares? :fencelook:
