Aksh said:Hi Gents , Thinking of changing my runflats to normal tyres , as runflats are too costly , what are your views on changing to normal tyres .
Also will the computer board pick up an error if changed ???
Aksh (2008 320i M Sport)
Philip Foglar said:Aksh said:Hi Gents , Thinking of changing my runflats to normal tyres , as runflats are too costly , what are your views on changing to normal tyres .
Some questions:
What size wheels/tyres does your car have? Narrow/wides?
Do you have a space-saver or at least a mobility kit?
Is your car still under motorplan?
Reason for asking - price of 225/45R17 non-RFT's is quite cheap, but wide size is still hellish expensive and almost the same as the equivalent size RFT. At least that's what I noticed. So rather pay the extra bit for the safety advantage of RFT's.
Also, if you change to non-RFT's, best to let your insurance know and acknowledge in writing... :thumbs:
Aksh said:Philip Foglar said:Aksh said:Hi Gents , Thinking of changing my runflats to normal tyres , as runflats are too costly , what are your views on changing to normal tyres .
Some questions:
Thanks Philip:thumbs:
(W & N) Front 225/40/R18s and Back 255/35/18.
Car still under motorplan 90000 Km on the clock.
People normally say Runflats are a harder ride and often wears out quicker than normal tyres.
Whats you view
pimpassdaddy said:Aksh said:Philip Foglar said:Aksh said:Hi Gents , Thinking of changing my runflats to normal tyres , as runflats are too costly , what are your views on changing to normal tyres .
Some questions:
Whats you view
If you go normal, this will void your motorplan if I'm correct.
Jakkals323i said:sport suspension + rft's.... pretty hard yes i can vouch for that..![]()
Philip Foglar said:pimpassdaddy said:Aksh said:Philip Foglar said:Aksh said:Hi Gents , Thinking of changing my runflats to normal tyres , as runflats are too costly , what are your views on changing to normal tyres .
Some questions:
Whats you view
Not entirely true, provided the tyres are BMW Approved with the star symbol - from what I understood from the agents is that you could fit a non-RFT BMW Approved tyre like a Bridgestone or Continental for example. But chances are you are going to be paying not much less than the RFT's.
18" unfortunately is one of the more expensive sizes, 17" is at least a bit softer on the pocket, especially the front tyres...
In terms of wear, I think this mostly depends on driving style - have heard that RFT's do tend to wear a bit quicker than normal tyres, but to what extent I cannot say. For example, Pirelli P Zero RFT's are often suggested to wear out very quickly! My father in law has them on his Z4 3.0i SMG and uses the car on a daily basis - also not scared to use the power. His tyres have done over 30k km and still have plenty tread left, even on the rears! Does he do burn-outs or frequent robot launches? Of course not!
Basically, RFT's have improved over the years and are a valuable safety feature as far as I am concerned - costly, but still mostly comparable to same size normal tyres of the same brand. Ditching RFT's for a more budget orientated tyre is where this skews the situation.
Edit: I see that you have an M Sport, so suspension is pretty hard - non-RFT's will offer a nicer ride of course, so still worth considering from the handling/comfort point of view...
Jakkals323i said:Runflats is better from a safety perspective to not get stuck next to the road..
Yes runflats is a bit harder than normal tyres but wear is the same i would say as it's still a normal tyre only the sidewalls are reinforced.
I have RFT's on my car... replaced them already + have the mobility kit in the boot cause if it's safe to pull over i will still use the kit to seal the puncture and inflate the wheel so that i don't damage the sidewall and that i can get it repaired if possible.
Hope that helps :thumbs:
Aksh said:Philip Foglar said:pimpassdaddy said:Aksh said:Philip Foglar said:Some questions:
Whats you view
Philip , please explain more ( Sorry Im not clued up, only 19 and got my 1st bimmer E90 last year , still lot to learn):thumbdo::fencelook: , as Im not clued up on the suspension part involving runflats , do I need to reset my suspension if putting runflats.
My dad has a E90 exclusive , and he did change to normal tyres , and he didnt do anything to his suspension , well his is not a sports pack and hes running normal tyres.
Buddy Whats the difference in using normal tyres on sports suspension , and a normal suspension.Please help :thumbs:
Jakkals323i said:Aksh said:Philip Foglar said:pimpassdaddy said:Aksh said:Thanks Philip:thumbs:
Whats you view
I think all he wants to say is that your suspension etc is made for runflats and why the standard on the e90's... sportpack has a sport suspension... sport suspension = harder ride already as it's lowered.
so if you have runflats with the sport suspension the ride is harder than what it would be with normal tyres.
No reset or anything required on your suspension if you do go normal tyres. If there's anything unclear we are all here to help:thumbs:
Philip Foglar said:Of course the new F30 does have new 3rd generation RFT's which are also a slight larger overall diameter compared to the E90, plus the suspension design is a lot better in terms of making the best of the new RFT technology - even the Sport suspension is silky smooth, smoother than my non-Sport suspension Exclusive E90 for instance!
Philip Foglar said:Yep, the F30 is very "light" on its feet compared to the E90 - also think maybe active steering is added or standard, so especially at town speeds the steering is very responsive and light!! :thumbs:
