Koni STR.T
This is the perfect upgrade for standard shocks they are designed to work well with standard and lowering springs... if you on a budget but still want better handling without a harsh ride these are for you :rollsmile:
Features:
> Unsurpassed price/performance ratio thanks to customised synthesis of quality, technical know-how and impressive performance.
> Perfect road holding and optimum handling
> combine perfectly with blue KONI SPORT springs and other lowering springs
> Individually tailored – just the right STR.T Damper for every type of vehicle directly from the factory.
other Koni products
current price:
e39 touring STR.T R 3400 front
touring price seems higher because its not so common :( also no rears available in the STR.T
frikkieh
Interest is directly proportional to the price I see. :rollsmile:
These are more in every man's league.
I will give you a shout when the time comes :thumbs:
no fronts for the e34 540 but the rears are R 2210 a set i will also give you a quote on the adjustable sports shocks because you can get fronts for this car :)
you can combine the STR.T with the Sport as long as you dont set the Sport too hard...
P Smit
Moranor, I suppose the STR.T shocks are not height, damping or rebound adjustable, or are they? Are you the agent for Koni?
nope they are set at the factory at about the same level as a Sport shock at soft
yip am an agent :rollsmile:
i would suggest you go with Sport or the coilover system on you car considering where you going with it :) they will give you way better results...
Riaan335
moranor@axis said:
today's price on:
e90 335i STR.T
front- R In development
rear- R 1975 Pair
Thanks. Any idea how long the development would take?
I think I'm not gonna be able to live witht the sport shocks.
First option would be STR.T
Riaan335 said:
moranor@axis said:
today's price on:
e90 335i STR.T
rear- R 1975 Pair
I think I'm not gonna be able to live with the sport shocks.
i will find out about development... the sport shocks can be adjusted soft so thats not really a reason to take STR.T over Sport, but cost is :)
Riaan335
Yea yea, I don't want to say it out loud.
I'm actually very tempted to try the sports. Depending on how long the development on the STR.T's will take, I might just get the sport rather
