Single Vanos rattle kit
BMW 6-cylinder engines M50TU, M52, US S50, S52, 1992-1999
3-series E36 93-97, 5-series E34 93-95 / E39 96-98, 7-series E38 95-98, Z3 Roadster 2.8 E36 96-98, EU Z3 Coupe 2.8 E36 96-98, US M3 E36 94-99, US Z3 M E36 98-99
vanos seals have to be replaced when doing the rattle repair for more info see single vanos seal :) for more info on why this rattle even exists CLICK
here is the single vanos rattle repair procedure i would also show this the your mechanic so he can do the job well...
I have these for sale:
Double vanos rattle repair kit
18mm modified socket - 1/2” drive
17mm modified socket - 1/2” drive
soft vise jaw liners
the rest is available from BMW or your local hardware store all the parts needed are listed in the procedure above :rollsmile:
if you have a pre march 95 production car you probably dont have the spring diaphragm bmw introduced to deduce vanos rattle it is recommended you get this from bmw when you do the procedure to get the best results... here is the diaphragm replacement :)
current prices on this batch is:
Single vanos rattle repair kit R375
18mm modified socket - 1/2" drive R65
17mm modified socket - 1/2" drive R65
soft vise jaw liners R190
