M
Mike1
Good Morning Fanatics
In the past week I have had the pleasure of working on a car that not only brings excitement to the soul of many a man, but also a car which brings with it huge amounts of power, style and performance.
This car needs no introduction, no precise punctuation and would rather spend its day eating small children and spiral its driver backwards into a wall in a cloud of smoke, exhaust fumes and joy.
This car is the BMW Z4 M Coupe.
This detail took me to "Agter-Paarl" for two days, providing a Definitive Detail for the client, a fellow fanatic on this forum who had just taken delivery of his new car.
Having not seen the car prior to the detail, I was not sure what i was in for with the exception of the owner stating it has "some swirl marks I want removed". :biglol:
Day 1: Calming the beast.
So to begin with, I arrived at possibly the most beautiful location I have ever worked in at 8am on Monday morning excited to work on this beast.
This is the weather and view I arrived to:
After unpacking my equipment and setting up it was time for me to pull the Z4 outside for the first time. I was greeted by a rather dirty BMW, with exquisite rimmage and a view which was simply breath-taking.
Looking closer you can see the car was covered in quite a healthy layer of dust, grime and dirt.
To begin I started with a wash, foaming the car down with Chemical Guys Maxi Suds (love the way this product smells) and whilst this soaked I cleaned the mag wheels with a light concentrate of APC and Chemical Guys Tar and Bug remover. The arches were scrubbed with APC alone and a variety of brushes.
The car was hosed off with my Bosch High Pressure Sprayer and then re-washed with Maxi Suds by hand and then re-hosed.
With the sun coming up I could already start noticing the damage inflected to the paintwork. I suddenly became very nervous and concerned... You will see why in a few moments.
As per my Definitive Detail I then started with Claying the paintwork using an Automagic Fine Clay. Much to my surprise the paintwork contained virtually no contamination with the exception of one or two star spots.
Here is the clay bay after the entire car was clayed:
For the final time, the car hosed down and dried leaving me with the following:
At this point you may be wondering why I became nervous about the paintwork. The reason is that I have never had to tackle BMW paint that was in this condition. I have absolutely no idea what the previous owner washed this car with (a scouring pad perhaps or a broom?) but the paintwork was in absolute ruin.
Fine swirling, RDS, Holograms and more were present on the paintwork along with some very deep scratches on the roof and rear spoiler. Even more concerning was the lack of gloss and wetness in the paint. In some places the clear-coat was so affected that it appeared close to matte!
With this in mind I pulled the BMW inside and set to work.
I began by taping off a small section of the bonnet to do some testing which resulted in 4 passes of Chemical Guys Pro Cut 2 on a Heavy Cut Hex Pad followed by two passes of Pro Polish and a final pass of Ultimate Compound on a finishing pad.
Correction on the car took me 7 hours which was surprisingly good considering the condition of the paintwork. I think what may have helped was my recently updated music playlist on my phone and the magnificent view.
Throughout the correction phase I did 50/50's of various panels pulling the car into the sunlight for a few pictures. Who wants to see the power of a Rotary Polisher at 1600RPM?
The main reason for achieving such fantastic correction is due to a very popular polishing technique called the "Zenith Point" method. This method relies on various polishing speeds to break down and refine the paintwork.
Essentially this method relies on a constant buildup of RPM on the polisher reaching a maximum RPM (The Zenith Point) and then slowing down in stages top refine.
I went for the following adaption of this method:
Spreading polish - Speed 1 (633RPM)
Working Polish/Abrasive - Speed 2.5 (900RPM)
Zenith Point - Speed 3 to 4 (1400 to 1600RPM)
The Zenith Point generates quite a bit of heat so it was essential to keep the Rotary moving at all time. At this RPM with this heat the polish is able to break down from being abrasive to a finer polishing particle which provides a smoother, glossier and more detailed finish with exceptional gloss and clarity.
Refining - Speed 2 (+- 700RPM)
Finishing - Speed 1 (633RPM)
I think the results were exceptional with the paintwork returning to its former glory.
One of the problems with cutting and polishing etc. is that the actual abrasive causes lots of "dusting" leaving a fine layer of powdery dust all over the car, in the door gaps and over the detailer. :biglol:
With Compounding, polishing and refining complete I decided to pull the car outside for a final paint inspection before calling it a day. It is good I did this as the following day had no sunlight and was quite cloudy.
Starting inside the improvement was already noticeable.
However outside the results were simply astounding with almost Full Correction on every panel.
Notice the mammoth improvement in the glossiness and shine of the paintwork?
http://[email protected]/image/BMW%20Fanatics/BMW%20Z4%20M%20Coupe/SAM_0877.jpg/img]
With the first day complete the sun setting and me feeling somewhat exhausted it was time to call it a day leaving you with this picture.
[img]http://[email protected]/image/BMW%20Fanatics/BMW%20Z4%20M%20Coupe/SAM_0886.jpg
Day 2 Coming up next!
