Proper Oil for my e36 m3 coupe
Prego
I wonder if anyone can sugest a good oil and plugs to use in my e36 m3 coupe.Its got 107000km on clock and i wanted to have it serviced with proper stuff
Fordkoppie
TWS is too thick for the s50 engine.
Get something like Shell or castrol synthetic 15w40.
I would opt for edge 15w40 or Magnatec (i know that is what Sav recommends)
Prego
Thanks guys need to keep her running like a proper ///M
Technician
agreed...
from personal experience, i've tried different oils on my track car and you cant go wrong with Magnatec.
McFly
Castrol Magnatec will never let you down. For your plugs try NGK BKR6EIX. You should get better performance from them.
ClassicB
No offence, but those are the wrong plugs for a E36 M3.
Technician
Plugs for the 3.0lt-
NGK: PKR7A (alternative- DCPR8EVX)
Bosch: Y 5 DDC
i could be wrong but thats from the catologues.
anyone know if this is right?
Prini said:
Plugs, get from dealer.(Dont mess around with wrong plugs on a m3)
Why do you say this Prin? have you had a bad experience?
kabal said:
the correct plug is NGK BKR6EK
is that not the coupe from overseas (1999-2000) (the 3.2lt)
ours coupe was a 3.0lt (1992-1996)
from catalogue:
Model- M SERIES, Type- M3 COUPE, Capacity- 3200, Year- 1999->2000, Cylinder- 6, Engine- S50 B30C, Gap- 0.9, Standard BKR6EK
Model- M SERIES, Type- M3 E36, Capacity- 3000, Year- 1992->1995, Cylinder- 6, Engine- S50 B30, Gap- 0.8 , Standard- PKR7A, Alternative- DCPR8EVX
kabal
I think I might have been looking on the US NGK catalogue, different engine.... so yes, the correct plug is actually PKR7A :)
Peejay
Events Organiser
So what is the correct oil for M3s? Hate to start a debate about it but MiniMike did recomend TWS for my car.
calypso
The more places you look, the more answers you will get.
The dealer will say 10w60, because that is the M oil, though this only changed after 2000, which the e36 predates by quite abit. Most find that is just abit too thick, unless your really gonna hammer it out and get some really high oil temps.
Also remember the heavier the oil, the harder it is for the engine to push it around, so too thick oil can cost you some HP.
Peejay
Events Organiser
The thing is that I have been looking around. A lot of the Guys in the US use 000W50 or 0W40 some even use 0W30. While we use TWS in our cars here.
