Post Reply
Thread Rating:
  • 6 Vote(s) - 2.83 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Fender rolling tool
10-01-2017, 03:31 PM
Post: #21
RE: Fender rolling tool
Where are you located. I need my fenders rolled.
Sent from my SM-G900H using Tapatalk
Find all posts by this user
10-01-2017, 06:17 PM (This post was last modified: 10-01-2017 06:52 PM by Gizmo.)
Post: #22
(10-01-2017 03:28 PM)KPAKKIRI Wrote:  does this tool flare the fenders?? My E36 M3 already has the fenders rolled. I think I need to flare them up a little.
Fender flares are actual extensions of the fenders, its material that you adding to fender to make it wider. The fender rolling tool rolls the inner edge of the stock fender to give you clearance for wider tyres or running lower offset wheels.
These are fender flares.
[Image: image__56664.1402013317.1280.853-1.jpg]
(10-01-2017 03:31 PM)Andrew M325iS Wrote:  Where are you located. I need my fenders rolled.
Brackenhurst Alberton, send me a pm for the full address.
2 pics of what it looks like. Will take pics in the use of it when I do the next set of fenders.
[Image: 20170110_183935.jpg]
[Image: 20170110_183944.jpg]
10-01-2017, 10:31 PM (This post was last modified: 10-01-2017 10:31 PM by 335i MTX.)
Post: #23
Apologies if this seems like I'm hijacking your thread. I've got a set of 20's. No spacers required and wheels fit perfectly on lci e90. Rear tyres are 275/30/20. They rub a bit only on the fender lining / mudguard and not the fender itself. How would one fix this problem other than running a 25 profile?
10-01-2017, 11:02 PM
Post: #24
No problem on the hijack CoolShake
Current Rides
2006 BMW X3 3.0D
2006 Audi A3 Sportsback 2.0T S-Tronic Ambition FRC ECU & S-TRONIC TUNED
(Ex BMW'S 2006 335i, 2003 330i, 2002 325i 2000 540i, 1998 318i MS, 1992 325i MEX)
(NON BMW'S 2006 A4 AVANT, 2003 POLO 1.6, 2000 200 STI, 2000 RSI 20V, 1999 GTI, 1998 RSI 20V)
(1997 RSI 20V 1997 MICROBUS 1992 GLI T/C, 1986 GLI T/C)
11-01-2017, 12:50 AM
Post: #25
(10-01-2017 11:02 PM)YUBEN@TheFanatics Wrote:  No problem on the hijack CoolShake
Shot bru. But worth mentioning that rolling fenders would be pointless if it's the fender linings that are affected and not the actual fender.
11-01-2017, 07:16 AM (This post was last modified: 11-01-2017 07:33 AM by Gizmo.)
Post: #26
Fender linings are made of plastic and won't cut through your tyre sidewall. The metal fender has a sharp edge on the inside that does cut through sidewalls, this tool flattens that sharp edge and gives you a few more millimeters of space for wider tyres. This is common practice for e30, e36, e46 and many more owners who need more room. Its a strong possibility that e90 is different where fender linings get in the way instead of the fender like everything else. In your case you have too little wheel offset.
(10-01-2017 10:31 PM)335i MTX Wrote:  Apologies if this seems like I'm hijacking your thread. I've got a set of 20's. No spacers required and wheels fit perfectly on lci e90. Rear tyres are 275/30/20. They rub a bit only on the fender lining / mudguard and not the fender itself. How would one fix this problem other than running a 25 profile?
You muppet! Std E90 tyre circumference 1965mm, your 20 inch tyre 2080mm. Your tyre is too tall! Use a tyre calculator.
11-01-2017, 09:01 AM
Post: #27
(11-01-2017 07:16 AM)Gizmo Wrote:  You muppet! Std E90 tyre circumference 1965mm, your 20 inch tyre 2080mm. Your tyre is too tall! Use a tyre calculator.
Here you go:
http://www.bmwfanatics.co.za/showthread.php?tid=64633
Game On Garage - YouTube channel
Current :
2007 Volvo S40 2.0D
1990 Mazda Mx5 1.6
2012 Lotus 7 1.6 4AGE 20V
2014 Toyota GT86 2.0
Has beens:
1990 Mazda Mx5 1.6
1984 Jaguar Xjs 5.3L V12
1988 Mini Clubman GTS
1996 E36 328i
2000 E46 330i
1983 Datsun 280ZX
1974 VW Beetle 1.6
2005 E90 320d
2007 Nissan 350Z
2003 Subaru Blobeye STi
2002 E46 M3
1990 E30 325i
1997 Nissan Skyline R33 RB25DET
2003 Subaru Forester 2.5 Xel
11-01-2017, 09:24 AM
Post: #28
Your problem is that the tyre is oversized, that size tyre is what I would run on my E60, you could remove the fender lining ( does the rear have a plastic lining?)
Current Rides
2007 530d MSport (DP, 76mm exhaust, RK Motion tune, OEM M6 wheels)
2012 X1 2.0D MSport
1996 200 Si Camry
[Image: photo from sashchern_5592516823.jpg]
11-01-2017, 09:30 AM
Post: #29
The tyre store advised that I go with a 30 profile. I should have followed my better judgment and insisted on 25 because I was going 2" up from 18" with a 35 profile. I should rather advertise the tyres so that I can replace with 25 profile or go with 265/30/20?
11-01-2017, 10:33 AM
Post: #30
My stock rims on my 335 were narrow and wides. 225/35/19 front and 255/30/19 rear. The 35 and 30 are aspect ratio/% of the width of the tyre (eg 225 x 35% = 78.75cm and 255 X30% = 76.5cm). So if you have real wide tyres in the rear, the tyre profile (sidewall) will be bigger. EG 225/35/19 the sidewall would be smaller than 275/35/19 and therefore the total diameter (outside diameter, not rim diatmeter) of the tyre too.
Also would bigger tyres/rims mean less torque eg 20" over 18"? Or would it be so small its irrelevant?
Current - F20 2018 M140i
Current - E92 2008 M3
Current - E46 2002 M3
Ex - E92 2008 335i N54 FBO
Ex - E46 2004 325ci
Ex - E36 1996 318is
Ex - Ford Escort
11-01-2017, 10:56 AM
Post: #31
(09-01-2017 11:51 AM)Psypher13 Wrote:  Hey bud
How did the rolling go at Powerflow?
Post a few pix for us to view please if possible
Ok so went to PowerFlow Fordsburg on Saturday, spoke to Ramon very helpful and pleasant dude. They don't roll fenders there, they shave them instead as its less prone to cracking. iirc I think they charge around R500...
Lifted the car to realize its not the fender that's touching, but my rear bumper :-(
All I did was changed from Toyo Proxes T1 Sport 255/35/19 to Falken FK453 255/35/19
Cry
[Image: Ci12.jpg]
[Image: Ci1.jpg]
[Image: Stretch-_Dajee.jpg]
325Ci | ///M3
StretchForever
11-01-2017, 11:19 AM
Post: #32
Noob Question: Can the e46 M3 Rear fenders be rolled or must they be shaved ? I noticed that the E46 M3 rear fenders inner lip is quite thick.
///M POWER - Yes, money can't buy happiness, But it's more comfortably to cry in a BMW than to cry on a bicycle.
11-01-2017, 02:36 PM
Post: #33
(11-01-2017 09:30 AM)335i MTX Wrote:  The tyre store advised that I go with a 30 profile. I should have followed my better judgment and insisted on 25 because I was going 2" up from 18" with a 35 profile. I should rather advertise the tyres so that I can replace with 25 profile or go with 265/30/20?
What is the width of the rims, both back and front? My initial guestimate would be to use 225/30/20 (8j - 8.5j) and 245/30/20 (9j-9.5j) on ther rear which is 3% bigger than stock, but still 2.7% smaller than what you have.
Did you notice that using the 275/30 tyre raised your car by about 19mm at the rear
Current Rides
2012 X1 2.0D MSport
1996 200 Si Camry
11-01-2017, 05:07 PM
Post: #34
Cry
[Image: Ci12.jpg]
[Image: Ci1.jpg]
Ahh swank one...
At least you know what's up and can fix.
How are the falken compared to the Toyo t1
And price wise?
Current: BMW 335i e92 7 Speed DCT Auto - Black Saphire
(Vargas 2+ Turbo, VTT inlets, K&N DCI, Rennzport CP+Tail BOV, jb4, BMS OCC, Wagner IC, n20 3.5bar sensor, ER Stage 3 LPFP, BMS Water Meth, Custom Backend Flash)
Current: BMW 320i e90 Sport = White
Cartel
Ex: BMW 320i e92 - Black Saphire
Ex: Audi TT Coupe 2.0 TFSI - Greenish Blue
Ex: VW Polo TDI - White
Ex: Mazda Astina 2.0 - Pearl Black
Ex: BMW 335i e90 - Sparkling Graphite
Ex: BMW 320i e90 pre facelift - Black Saphire
Ex: VW Golf 5 GTi - Red
Ex: Honda Civic Type R - Black
Ex: BMW 325i e36 - Red
15-01-2017, 04:24 PM
Post: #35
[Image: img-20170112-wa0004_3023785119.jpg]
[Image: img-20170112-wa0005_659775519.jpg]
Current Rides
2006 BMW X3 3.0D
15-01-2017, 04:25 PM
Post: #36
Thanks guys. The fenders were expertly rolled by Auto Lounge. I would highly recommend them for your fender rolling needsClapper
Current Rides
2006 BMW X3 3.0D
The following 2 users Like YUBEN's post:
Iry-gp, steffarmer5
10-10-2018, 11:09 AM
Post: #37
(10-01-2017 02:56 PM)Gizmo Wrote:  I bought a fender roller today so anyone who wants their fenders rolled can come to me.Chef
Bro, how much do you charge for fender bending ? my e46 scapes when i have people in it. i have 19"s 10Js on the car
Current:
His: 2002 BMW 330CI Convertible Black (Weekender) & 2014 Ford Figo Ambiente White (Daily)
Hers: 2018 Haval H1 - Orange
Fam: 2007 BMW X5 E70 3.5D XDrive Ice White
AUTO-Biography
BMW
2006 BMW 325i E90 M-Sport Sparkling Graphite **crying**
1999 BMW 328i(330i conversion) E46 Stahl Blau **crying**
1994 BMW 520i Yellow Mellow
VW
VW Caddy MK2 Grey - "Men Of Honour" Crew Bus
1995 Golf 3 Cabrio 2.0 MP9 (Karman Edition) Black
2004 Citi 1.4 Burgundy
2005 Golf 5 2.0 Comfortline Silver
1998 Microbus 2.2 Green
1999 Polo Playa 1.6i White
2001 Polo Playa 1.6i Red
1969 VW Beetle 1.3
Other
2005 Nissan Hardbody 3.3 v6 White
2004 Renault Megane 1.6 16v White
2005 Opel Corsa Light Silver grey
2004 Opel Corsa 1.6i Metalic Blue
1996 Land Rover Discovery 2 3.9 v8 Burgundy
10-10-2018, 12:23 PM
Post: #38
I don't think you're gonna get a response here. lol
10-10-2018, 01:05 PM
Post: #39
Gizmo disabled his PMBlueCryBlueCry
Current:
AUTO-Biography
BMW
VW
1969 VW Beetle 1.3
Other
10-10-2018, 01:18 PM
Post: #40
Come to The Wheel Shop - TWS......Ive been rolling fenders for years.....
The Wheel Shop
Shaheen @ The Wheel Shop
011 830-0210
076-796-3119
167 High St, Brixton, JHB
Robots after Garden City Clinic
Facebook Page: https://www.facebook.com/TheWheelShopTWS/
website: http://www.thewheelshop.co.za
email: thewheelshop@tiscali.co.za
[Image: $_20 (14)_3139111064.jpg]
Post Reply
User(s) browsing this thread:
1 Guest(s)
