Hard to believe its been 18 months since the last update on the showroom threads and some of the updates will be duplicated between threads, so please bear with me.. Time really has flown by and it has been a massive period of change for me personally, from a new job, to a new home in another province and the biggest blessing of all, a new addition to the family.. Not another car, as many may think but rather a baby boy that is already taking up all my time and attention (rightly so!).
Had a fantastic run with the car as it did duty over the entire festive period and into Q1. Experienced my first spot of trouble with the car some 8k km later toward the end of March 2021, had just started up the car and was on my way to fuel up when I got a warnings on the speedo and it felt almost as though the handbrake was binding (had a quadfecta of lights). Switched the car off and on again, the error disappeared and then reappeared some 5km later, at which point I was almost at my late friend’s workshop (they have closed down now), had the codes read and it pointed to a few things, transfer case, handbrake and wheel speed sensor. Decided to leave the car there for troubleshooting, it turned out to be a front left and rear right wheel speed sensor and I decided to just go ahead and replace all 4 at the same time with OEM. Once done, all the other codes disappeared and it was happy motoring for a while.
Had a stone chip on the windscreen from a prior trip to Jhb and it had gotten worse so decided to have it changed with an OEM one and had the guys come out and do mobile fitment at some point In June. Was pretty happy to have a spotless windscreen again and glad I pushed the insurer to go OEM, they always want to fit generic ones to save costs and cite the age of the vehicle as a driving factor.
I then booked the car in at Supertech for a brake fluid flush a month later and they were having a special on wipers, so I took advantage of that at the same time. As part of their service package, they read the codes and the car threw up an EGR code. I was told I could leave it there for a new cooler at the princely sum of R15k, which I declined. Took the car over to a new workshop now that the BMWorkshop had closed its doors and had the EGR removed and cleaned to see if it would fix the error. Thankfully it was just soot that had clogged the EGR and this was cleaned, at the same time I replaced the swirl flaps with a new unit from BMW as the old ones had massive amounts of play. Rounded the visit out with a stage 0 software tune from Xcede just to switch off the EGR to prevent further issues with the system. I will likely do stage 1 if I do XHP as I will not tune the ECU without doing the corresponding TCU software, personal preference. Looked like an X3 kinda day..
A few weeks later, I had seen that one of the rear taillights were not lighting up and did some research into it. I have seen many F25’s with taillights that don’t work and was prompted to do some homework. Turns out the Valeo LED drivers are known to fail after a while and some people replace the entire light as BMW does not sell them separately. I enquired with a forumite that managed to supply the boards and fit them at another workshop in Durban, decided it would be prudent to do all 4 for a considerable saving over the agent’s solution for 1. The replacements were actually a bit brighter than the OEM ones and it comes with a decent warranty, so was happy with the outcome.
Used the car in October to come view my now property and the car didn’t skip a beat since consuming funds a few months prior. Fast forward to March 2022 and the car made its mileage milestone of 100k km. Treated the car to an oil service at BMW and then proceeded to change all filters for good measure. Just before the relocation to Jhb some months later, I got a warning for rear brakes being due in a few k – opted to have them done as a matter of safety since the family would be with me in the car on the trip up. Just before we left, had the car cleaned and took some mandatory Blak shots for the last time.
Upon moving to Jhb I had wanted to do the Transfer Case and diff oils at ZF as part of the 100k service regime, I made a booking at ZF and tried to procure the diff oil but was unlucky in terms of timing. Decided to just do the TC oil for now and will complete the diff oils when I take the car back to ZF for another gearbox oil change. I also wanted to have the DP done and made arrangements with Xcede as part of the special they had, got this completed at PowerPipes and couldn’t be happier. Workmanship and service is streets ahead of anything I’ve seen prior (lets not forget my previous experience with the useless operation that is Roadmaster). DP has made the car a bit louder as you hear the turbo much more and there's no cat to kill some of the noise but it's fun.. Also gave me some performance gains according to the butt dyno, car definitely feels sprightlier.
Sadly, my place only has a double garage and in line with estate rules and regulations, I had to settle for a custom length, waterproof shade-net carport (really wanted an enclosed aluminum set up). It does the job nicely and surprisingly the car stays clean for ages.
That brings the X3 showroom thread up to date and for now, no plans to do anything more than necessary maintenance.. Thanks for following.
