Review after a few hundred kilometres of driving...
First, to close off the lousy lock post above. The TVL Lock is scheduled to be fitted on Tuesday. Unfortunately, these locks have gone up in value significantly (probably due to worsening exchange rate and there being very high demand for these locks in SA). Drop me a DM if you want details. The price is a bit eyewatering...
So after driving the car a bit on mixed roads, here are my views:
Interior:
Driver comfort, especially after fitting the leather seats, is decent. The lack of a centre armrest and no padding on the door (hard plastic) for your elbow does make long distance trips a bit uncomfortable. But, nothing too serious. Be warned though that the front seats are not made for larger/wider folks, since they lack side support and the base is a bit narrow. For my size, it is fine but some friends complained and preferred the rear seats. The Suzuki Brezza is more comfortable overall.
The rear passenger legroom and headroom are great. The car can easily accommodate 4 passengers of 1.8m height. The middle rear seat is not for adults over long distances - it is just too narrow and the transmission tunnel interferes with legroom.
The boot space is a joke. Very small. However, the rear seats do fold flat (and can be made totally flat by lifting up the seat bases). With the seats down, this turns into a little van that can accommodate large loads (I heard of someone who fitted a washing machine in there!).
As mentioned earlier, plastics are hard and cheap looking. However, everything seems well put together - no rattles/squeaks even after some gravel road driving at speed. Some local motoring reviews did note that some pieces of trim popped out, but this has not happened to me (still early days though).
The doors, boot and bonnet are heavy and close with a thunk. While this is good, they sometimes need a heavier than normal slam to shut properly. Interestingly, if you try to arm the alarm system with one of the doors not properly closed, the car will hoot twice to warn you. The rubber seals on the doors are thick and seem to be attached firmly - a good sign for dusty gravel road travels.
Tech:
The 6 speaker audio system is really great at this price point (it has 2 tweeters, you can control the mid levels and it has a driver seat focused DSP). Granted, no touch screen or Android Auto unlike its competitors, but sound quality is impressive. I am no audiophile, but the system sounds better than the system on my Porsche Cayman S. Also, no speaker rattles at higher volumes. Bluetooth phone calls and audio streaming are standard. The only negative is that radio reception on some FM stations is not great.
The lights are simple halogens, but there is height control on the beams (not something you see in a base model crossover in this segment). I guess because the car rides high, or maybe because it was built for 3rd world roads in mind, illumination is excellent - nice wide and deep light range. Also (
apologies for another Porsche comparison), these lights are better than the xenons on my Cayman in night time driving.
A nice touch is that the park lights stay on for about 20 seconds when you lock or unlock the car in the dark.
Standard fit ESC and TC, as well as 6 airbags, are all welcome at this end of the market.
The aircon and heater are very powerful and do not impact engine performance at all.
Drive:
The 1.5 litre 3 cylinder, naturally aspirated, motor punches out 91kw and 150Nm. Mated to a 6 speed torque converter box, the results are a mixed bag...
The motor sounds terrible when revved - sounds like an old, buzzy vacuum cleaner. Fortunately, the buzz is hidden somewhat by the excellent (for the price) sound system and there are no vibrations that enter the main cabin from this engine. At higher speeds, when cruising in 6th, the motor quietens down significantly - sounds very civilized actually and all you really hear is some minor road noise.
Overtaking, if planned correctly, is relatively effortless and, if you can ignore the buzziness, the pick-up from the motor (and responsiveness from the gearbox) is pretty decent. However, on an upward stretch of highway at 140kmh with a load onboard, do not expect any appreciable forward momentum when planting the throttle to overtake above that speed - that 150Nm is not enough to stretch the laws of physics.
There is no tip shift or paddles for the gearbox (just PRNDL), so you need to adjust your driving style to not feel like you are fighting the engine and gearbox. Some SA reviewers found this box and motor combination to be a pain, which is understandable if you only have a short time to assess the car. The trick (
at least, how I see it) is to use the throttle to get the gearbox to play nicely with the engine. To get decent momentum while on the go, squeeze the pedal gently at first and then increase the pressure quickly, but measuredly, to get the motor to rev up and the box to not hold the gear too aggressively. If you plant the throttle too fast (i.e. kick down), you get too much lag before the car moves and the box jumps down 2 gears and sends the revs skyrocketing and out of the optimum torque/power band.
With the measured approach above, you can get good speed and responsiveness. I easily kept up with traffic and performed nippy overtaking moves on the highway. If you plan accordingly and play to the engine and gerabox's strengths, this car is rewarding to drive.
The handling is decent - it feels solid on the road, even though it is a narrow and tall vehicle. You can feel the Fiesta DNA somewhere in its handling traits - it is not a bother to drive at sane speeds through mild twisties. The brakes also feel really good for a rear drum setup (I guess the Goodyear Assurance 205/60 R16s also had a role to play) and I had no issues on a wet highway drive at night.
The ride on gravel is good, but feels a bit firm (I guess the trade off is the batter handling above) but nothing to really complain about. There is a hill descent control which acts like a low range for steep hills.
Closing comments
I have no buyer's remorse on this purchase. It has met my expectations (and exceeded some) at this price point. This write up is meant to show potential buyers what is out there in this class of car. I will wait a while before giving another update/review of this length - next update probably later this year.
Pictures and commentary below.
Water bottle for size reference
Yes, that is no optical illusion. The boot is that small
Cool looking rear door hinges sideways, but it means that reverse parking is not a good idea in a shopping mall
6 speed gearbox is good if you learn how to treat it with this engine. Glad this is not a CVT or a 4 speed
Aftermarket leather seats help lift the mood of the cabin and feels much better than the standard issue grey cloth seats, which were poorly padded anyway
Instrumentation is neat, clear and gives you all what you really need. Glad to see a proper temperature gauge in this class of car. The middle screen below is configurable to show you all the trip computer data.
Basic, but well designed sound system at this price point that punches above its weight
Height control on headlamps is pretty nifty in this segment. Rear fog light included.
Yes, that is a small cubby/glovebox. Pen and cellphone holder as reference
