BMW i8 Race Car Build
Captain_Stealth
tman said:
A lot of people (haters) will tell you dont build what you can buy. Quite frankly they are all just jealous.
If you have the imagination, and a decent budget anything is possible!
A i8 v10 twin turbo would be a dream build! Please make a build thread and resort back with an update.
Exactly well put
Marco-Swanepoel
Nikhil said:
Anybody who things a stock 2JZ will hold a 1000hp reliably is delusional, they suffer from oil pump, timing chain and main bearing failures when driven hard in stock form. If it was a 600hp setup and below it would be cost effective but the above is still an issue. If you chat to guys that run them on track cars they will give you real insight into It not the YouTuber who did a swap and does 5km a month and a top end pull with it. furthermore theres a reason why you dont see 2Js in circuit track cars locally as they need to be fully built to be reliable at that power level and the same can be said for pretty much any other engine that will be tracked at a 1000hp The above setup that you looking to do has it's own set of complexities using a fully electric car. You most likely better off taking a compact v6 putting it into a tube chassis and then dropping the i8 shell over it. This exercise whatever route you go will be expensive as f***.
In a nut shell that's the build "[font=Tahoma, Verdana, Arial, sans-serif]taking a compact v6 putting it into a tube chassis and then dropping the i8 shell over it"
[/font]
Marco-Swanepoel
TurboLlew said:
Buy this
https://www.autotrader.co.za/car-for-sale/mclaren/570/570/25167968
It will be cheaper - a few guys can itemise the costs you might run into
AC Schnitzer tried to fit a B58 instead of the 'helper' 1.5 motor and I don't think they ever came right.
Again I say, reliable is relative at these power levels. 'Reliable' on a 3000hp build might mean it makes it down the strip twice to run a time and back it up.
Accident damaged i8 needs a PROPER inspection - chances are high there are cracks in the carbon tub or mounting points for the subframes.
 We done an inspection it only have front suspension damage the tube is still perfect
The only 2000hp plus motor I'll go for is the VR38 so many videos and blog on these motors doing multiple runs without any problems build it for 2000hp and detune it to 1500hp something in that range
Your problem is going to be packaging and cooling - not power. You're going to need things like:
new extended subframe
the motor itself (V8TT or V10 both are shoehorned into very large engine bays and still suffer with cooling even in front)
body panels for the new shape of the car that you are going to need (Look at Henessy Venom as an example)
a transaxle that somehow works with this setup (Look at how the F355/F360 setups look), At the very least custom drive shafts
removing ALL the electric stuff,
Somehow getting all your stuff working inside considering what modern BMW electronics and coding is like (or running your R100K ECU).
Totally custom suspension front and rear
Totally custom cooling
Then you want to twin turbo it in the case of the V10?
Why don't you buy a Radical? or KTM X-Bow or McLaren or something like that?
What cars do you have that you feel like you need 1000hp in a very light car?
Marco-Swanepoel
That's why I started this thread I'd like to know what kinda power can these V10s make reliable and the costs
It seems the S63tu motor might be the best option as guys are still developing upgrade for it as the V10 no-one is doing much for it anymore
Pure Turbo's stage 2 tuebo upgrades are hitting the 900hp mark
OK... here is an example from the 4C forum. They took a 4C and were supposed to 'drop' a Lambo motor in.
Literally the only thing they managed to use was the tub. Not even the front.
All custom engineering.
And this is a VERY simple car compared to an i8
Kyle
I assume you got your inspiration from YouTube? Seems like a new trend amongst automotive YouTubers to buy accident damaged supercars and swap a crazy 1000HP engine in there, problem is... Very few of them *actually* work... However...
Anything is possible if you have the resources...
http://www.speedhunters.com/2020/05/this-is-what-they-mean-by-built-not-bought/
IMO the i8 is not a great base to start with in terms of being engine swap friendly, especially because of the complex electrical system. You would basically have to strip out everything and start from a bare shell if you actually want it to work and not just start and make noise at a car show like the crazy YouTube (B is for Build) cars.
Marco-Swanepoel said:
TurboLlew said:
Buy this
https://www.bimmerboost.com/content...I-GTX3076R-Gen-II-and-GTX3582R-Gen-II-options
Marco-Swanepoel
TurboLlew said:
Buy this
That's an great suggestion! Pure Turbo upgrades are also doing great work on the S63tu motor
Nick
Do you want all that power to go in a straight line?
If its a track car you want, id rather get a GT2RS or a GT3, that car has more to offer than most "drivers" can handle.
Seems to be hillclimb - not drag
Marco-Swanepoel
Inspiration was actually from Quintin's AMG powered Lotus
I would definitely strip the whole i8, drop all the electronics and start with an bare shell. Lots of guys doing V6 twin Turbo swops with the lotus and MR2 it's really not that complicated.
My biggest debate is
Do I build an 1000hp BMW road car
Or I build an 2000hp Nissan race car
Kyle
The biggest problem I see is trying to fit anything in this subframe...
Marco-Swanepoel
It's actually very simple you remove the rear subframes and build a new one around the motor you use same as all the Lotus guys do
You'd have to extend the rear to accommodate the new motor length but, it rather do this then cut into the carbon tub
So motor wise you're in for
Used S63TU - R200K (they are all advertised for more locally)
Build on the S63TU - R100-150K
Turbo upgrade - R200K (Weistec setup)
MOTEC - R90K
This is before you have fitted anything you're already past R600K
That is stuff you know the price of
Then there is:
Gearbox: a Hewland sequential box is around 25K GBP which is about R585K at current rates. It goes up from there...clutch, custom fabrication to get it to fit etc. No off the shelf gearbox from BMW is going to work (I don't think)... even then a DCT Box might be 100-150K and then you spend another 100K on clutch and basket upgrades and then another amount of money for a tunable controller of some kind. Even if you got one for half price, that is a chunk of change
The custom work on the aforementioned Subframes, drive shafts etc - that Alfa build is an example.
ALL the custom engineering work just getting it to fit - do you have someone who you would be able to get to take on work like this? Or can you perhaps do it yourself?
ALL the custom body work for the front and the back - I honestly wouldn't even know where to start in terms of getting this done in SA?
Suspension + wheels & tyres - gets VERY expensive for your kind of use case
Cooling?
Oil system?
Brakes (R40-50K front only is a starting point for things like AP Racing)
Tuning for engine and gearbox - no idea
Then the cost of the i8 itself - I dunno what that is, but even at R500K, I would be amazed if it still made sense. Then regarding balance, why do you feel this will be better than either the McLaren I posted or the Porsche GT3 RS (or hell GT2 RS if you have that desire for power) and spending time tuning it for your driving style and prepping for events.
I don't think using a V10 is going to be any different (if anything it would be more money). Using a 6 presents the same challenges especially getting it past 1000hp
I don't know what you could reclaim from sale of i8 parts.
Woodies
Hell yeah!! I’m sure it ain’t going to easy, but if it works out it will be amazing!
Proper i8! Proper BMW sports car. Even just a NA v10 screaming in an i8 would be amazing. Whatever happens, I really hope to follow a build thread for this project
Nikhil
The amount of fabrication required is giving me anxiety lol, if you keen on going with this I would transplant an M50d engine into this thing, the 6 cylinder diesels are reliable as hell and with some software trickery, water meth and upgraded turbos 400wkw and over 1000nm of torque will shunt you through a hill climb very nicely and it will be super reliable
