Sunroof fix - 540
13-07-2010, 10:56 AM
Post: #1
Sunroof fix - 540
Where can I take a 540 to get the sunroof fixed?
it stopped working only miking that grrrrr noise as if there are stripped gears in there. I know a sunroof fix can be expensive but I don't think it needs to be if you know the right ppl. PS I am in Centurion / Midrand |
13-07-2010, 11:05 AM
Post: #2
if its open try pressing ur key in the lock position and holding it so that it closes.
have u checked with a dealer what the cost is? have u by any chance found out what exactly is the problem?
13-07-2010, 11:29 AM
Post: #3
RE: Sunroof fix - 540
that is what i want to do............get info on what can be wrong and then get a R to get it fixed
it makes the same noise both ways (opening and closing) it is closed at the moment. |
31-07-2010, 05:33 AM
Post: #4
Got it sorter from Sunroof Boyz, and the came to myoffice to fix it there. Good service, good response. Good to have the S/R working again.
31-07-2010, 11:36 PM
Post: #5
SO what was wrong?
02-08-2010, 09:22 AM
Post: #6
| RE: Sunroof fix - 540 | |||
03-08-2010, 10:58 AM
Post: #7
tilt and lift bar at the back was bent and damaged, the replaced it
rubber gasket replacement fairly pricey about R1000 alignment and call out charges (they came out twice) all and all R3600 but its fixed now and enjoying every second of it. Sunroof Boyz they come to you, this was the best suited for me. 082 421 4090 Johan |
03-08-2010, 11:05 AM
Post: #8
R3600 for sunroof thats a bit pricey eish
but spring is around the corner and I miss my sunroof.Thanks for the info |
03-08-2010, 11:13 AM
Post: #9
yeah well it needed to be done,
what gets me is that they fit glass sunroofs for R5000 that is from scratch ! |
03-08-2010, 11:18 AM
Post: #10
Wonder what the interior looks like after that has been done. Well the dealership charge more or less that price if you want it to be an optional extra on a new cab... or is it R10K.
03-08-2010, 11:41 AM
Post: #11
well they do a very good job i must be honest and the 1st time they came out they said don't worry about the roof liner and don't try and clean it cause its gonna stain, got in the car and got a fright of my life seeing the dirty roof liner, i did as they said by not trying to clean is and drove a a car that looked like a mechanics car for 2 days
but they came back and fixed the roof and cleaned all the marks. happy with the immaculate service, bit grumpy about the price but would recommend them any day. This was all done Thursday and Friday night my ignition tumbler broke yeah ! NOT ! fing car cost me R3600 on Thursday and another R1500 yesterday to get the ignition and key fixed. (almost lost the chip that went into the key, but after a few beers |
03-08-2010, 11:53 AM
Post: #12
Yeah it really sucks when one thing packs up while you are still fixing another. Then i better start saving. But the last time i spoke to my mech he said i need to replace the mechanisim and it costs less that R1k from the slearship then he would have it fitted for me...
jus have to weigh my options.
06-08-2010, 10:19 AM
Post: #13
I have used Johan on a number of sunroofs - impeccable job...but don't stand there while he works - you will end up with 'ticker' problems
![]() The rear tilt bars on the E39's seem to be a common problem @ +/- R800 per side + any other components |
« Next Oldest | Next Newest »
Search
Member List
Invite A Member
Top Referrals
Calendar
Help
