Post Reply
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Correct size Spacers?
17-02-2017, 01:38 PM
Post: #1
Hey guys...
Im getting a set of style 403's for the e90.
Its gonna have 225/40 up front and 255/35 at the rear.
First off- do i need spacers and if so what size???
And then where about in jhb can i get em from.
[Image: 2015-12-15 09.27.51_2235748791.png]
Find all posts by this user
17-02-2017, 02:08 PM
Post: #2
RE: Correct size Spacers?
As per the tire size.....that seems to be perfect (meaning no spacers required)
But then depending on how you would like the Mag to sit on the car....(Flush or slightly sticking out)
17-02-2017, 02:31 PM
Post: #3
the offsets are 47 vs 35 or something so based on that should be fine
current: BMW E92 M3 (bearings could be fcukd)
17-02-2017, 02:45 PM
Post: #4
Thanks a mill guys
Ty
18-02-2017, 02:53 PM (This post was last modified: 18-02-2017 02:53 PM by Rayzor.)
Post: #5
You gonna need spacers for that wheel, contact Firi or zahir from rennzport.
Sent from my Hisense F31 using Tapatalk
Also try Sean from axis
[Image: img-20160523-wa0020_199168482.jpg]
[-] The following 1 user says Thank You to Rayzor for this post:
michael.joseph (02-18-2017)
18-02-2017, 04:14 PM
Post: #6
You definitely going to need spacers for those rims....
First off here's the specs :
Sport 19" 403M Style Wheels
Front: 19x8 ET36
Rear: 19x8.5 ET47
The 403 come off the fseries, which don't accommodate very high offsets and aggressive rims. The e90s however can have a much wider track, especially at the rear.
The 403 in this case is only a 8.5j and has an ET of 47 which means it's gonna sit well into the rear wheel arch. The front won't be so bad. In order to make them sit flush, you may even need a 20mm spacer at the rear and 10mm upfront. However a 15mm could work at the rear as well.
Best thing to do would to fit the rims to the car and then measure the space between the edge of the tyre and the inner part of the fender lining.
Please feel free to PM myself or RENNZPORT, or forward an email to rennzport@live.co.za if you have any other queries.
You can visit our IG handle @rennzport to have a look at the new range of ST wheel spacers we offering.
Hope I've helped.
Sent from my SM-N910F using Tapatalk
[-] The following 3 users say Thank You to FiRi@Rennzport for this post:
michael.joseph (02-18-2017), Rayzor (02-18-2017), Rennzport (02-18-2017)
18-02-2017, 09:06 PM (This post was last modified: 18-02-2017 09:06 PM by michael.joseph.)
Post: #7
Shot Ray...
Thanks Firi... I'll get em fitted and come thru to u before going for balancing and alignment
Ty
[-] The following 1 user says Thank You to michael.joseph for this post:
Rayzor (02-19-2017)
20-02-2017, 08:43 AM
Post: #8
i apologise for the incorrect info..i worked on the offset but forgot to check the width of the wheel at the rear Hammerhead
20-02-2017, 02:17 PM
Post: #9
Firi is the E90 whisperer Rollsmile so I'd definitely go with his advice!
Post Reply
User(s) browsing this thread:
1 Guest(s)
