Post Reply
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
e46 m3 strange noise
16-02-2017, 11:54 AM
Post: #1
hi guys its been a while ... im back in an ///m car ... driving a e46 m3 97 000km .
Done a few trips with the car .. now i notice when driving the car at very low speed and turning right or left theres rubbing or some sort of noise coming from the rear .. any experienced something like this ... spoke to 1 guy he says he had to replace centre shaft , cause the clutches on the slip diff might be broken .. SmashScreen SmashScreen
Find all posts by this user
16-02-2017, 12:01 PM
Post: #2
RE: e46 m3 strange noise
put the car on a lift and have a peek...
rather examine first before audible conclusions ... examine the necessary items
Subframe
Propshaft Coupling
Drive Shafts
Diff
make sure all bolts are tight and torqued up to spec
Etc...
then take it from there
16-02-2017, 12:30 PM
Post: #3
The LSD is known to groan on slow speed sharp turns.. replacing the fluid wiht the correct BMW fluid that includes a friction modifier solves this (assuming this is your problem).
2004 BMW 330i 6MT M-sport
Ex 2003.5 BMW M3 Coupe 6MT
Ex 2004 BMW 330i 6MT M-sport
16-02-2017, 12:31 PM
Post: #4
(16-02-2017 11:54 AM)MFD 187 Wrote:  hi guys its been a while ... im back in an ///m car ... driving a e46 m3 97 000km .
Its simply the clutches in the LS diff making that noise because the car is not used often.
Dont stress about it.
Some reckon an oil change might fix this, but sometimes it doesn't.
If you get the correct LS oil, WITH THE CORRECT FRICTION MODIFIERS, it might be a good thing to have the oil changed anyway.
Then after the oil change, drive slowly around in circles a few times. one way, then the other.
[Image: FordTappetcover1.jpg]
If everything seems under control, you're just not going fast enough - Mario Andretti
[-] The following 2 users say Thank You to Fordkoppie for this post:
johndoe (02-23-2017), MFD 187 (02-17-2017)
16-02-2017, 01:57 PM
Post: #5
Exactly what's been said above. Youll probably find the diff oil was changed but the incorrect oil could've been used. Get the oem oil from bmw with the Friction modifier (fm booster) and it should remidy itself.
Couple of slow speed 1st gear 360 turns both ways and it should be cured.
[-] The following 1 user says Thank You to Andy1GP@TheFanatics for this post:
16-02-2017, 09:17 PM
Post: #6
Done the same on mine, diff oil changed and the sound was gone.
Sent from my HUAWEI MT7-TL10 using Tapatalk
17-02-2017, 03:10 AM (This post was last modified: 17-02-2017 03:11 AM by Crash_Nemesis.)
Post: #7
Same as above. Replacing the Diff oil with the correct friction modifier will solve your problem. Well documented issue. Good luck and many happy miles
[-] The following 1 user says Thank You to Crash_Nemesis for this post:
17-02-2017, 03:33 PM
Post: #8
thanks guys ... will be taking in the car to bmw next week to have this done
appreciate thanks,, hope it helps ClapperTy
17-02-2017, 06:02 PM (This post was last modified: 17-02-2017 06:14 PM by AdiS.)
Post: #9
(17-02-2017 03:33 PM)MFD 187 Wrote:  thanks guys ... will be taking in the car to bmw next week to have this done
Just make sure they use the correct oil - the bottle has to say " + FM booster". Usually the parts guys at Bmw just want to use the ordinary oil because they don't know any better.
https://www.ecstuning.com/b-genuine-bmw-...222282583/
[-] The following 1 user says Thank You to AdiS for this post:
Crash_Nemesis (02-18-2017)
18-02-2017, 06:37 PM
Post: #10
Also think it might be the LSD
23-02-2017, 12:27 AM
Post: #11
Yip time to change that diff oil, mine did exactly the same, changed oil and gone with the noise.
Current: 2004 e46 ///M3, Half Car Half Amazing.... "the rod bearing whisperer"
Ex: 2006 S40 T5 Volvo
Ex: 2000 TaZz 1.6 4afe
Ex: Sonic Golf 1 + filter 401wkW
[Image: DSCF1268.jpg]
23-02-2017, 02:30 PM
Post: #12
I've noticed my E90 M3 doing the same
23-03-2017, 02:55 PM
Post: #13
Just a lilttle report , had the oil changed drove the car for few days .. the noise was gone ...parked car off for a week so and noise is back but not as bad as the last time Skit
[-] The following 1 user says Thank You to MFD 187 for this post:
Ahmedv007 (03-24-2017)
24-03-2017, 08:42 AM
Post: #14
Completely normal, clutches in the diff making that noise... I am not convinced you will get it away unless you drive the car often enough
[Image: f8152268-dead-4fd1-a35b-8a34448d09b2_zps105d541d.jpg]
Medusa... 2004 E46 M3 | Carbon Black
2013 Hyundai i20 1.4 glide | Blue - Current
2006 polo 1.4i comfortline | Black - Sold
1998 e36 M3 | Aegean Blue - Sold
1996 e36 328i individual | Santorini Blue - Sold
2005 citi golf 1.4 | White - Sold
27-03-2017, 08:26 PM
Post: #15
can I change the oil myself or experts?
28-03-2017, 07:18 AM
Post: #16
Its quite simple to change, did mine this weekend and the noise is gone
[Image: autox_zpsefa43770.jpg]
28-03-2017, 07:21 AM
Post: #17
(27-03-2017 08:26 PM)KPAKKIRI Wrote:  can I change the oil myself or experts?
YES
///M Coupe - 1 of: 206(RSA) / 1054(Globally)
[Image: 15f2k3c.jpg]
28-03-2017, 07:52 AM
Post: #18
Just make sure you drive in circles....Not doughnuts RoflRoflRoflRofl
[Image: Th3-Ic3Man_T8000.png]
Current:
His : 2007 Alpine White 335i Msports Pack
Her's : 2012 Audi A4 B8 1.8T Ambition
Ex:
2007 Audi A3 2.0 FSI
2007 Ford Focus ST
2008 Audi A3 2.0TFSI DSG
2010 Audi A4 1.8T Multitronic Attraction
2011 Audi A4 1.8T Multitronic Ambition
Post Reply
User(s) browsing this thread:
1 Guest(s)
