Post Reply
Thread Rating:
  • 1 Vote(s) - 5 Average
  • 1
  • 2
  • 3
  • 4
  • 5
E46 3.2 M3 Wide Body Project
19-11-2016, 05:40 PM
Post: #81
RE: E46 3.2 M3 Wide Body Project
(19-11-2016 04:50 PM)Brucet Wrote:  Went for a seat fitting and to measure where the pedalbox should be today. Rear sub frame mounting points have also been reinforced.
Given your height which part of the boot you sitting in?
Bluebiggrin
The truth is incontrovertible, malice may attack it, ignorance may deride it, but in the end, there it is. ~ Winston Churchill
peterkarvelas@gmail.com
Find all posts by this user
19-11-2016, 05:48 PM
Post: #82
Crazylaugh
06-12-2016, 06:51 PM (This post was last modified: 06-12-2016 06:51 PM by born2boost.)
Post: #83
Properly done Bruce! Well done.
I took a shortcut and bought my brothers E46 M3 race car...
Now also busy with a few small changes to it...
[Image: c25e7131-93a0-479a-9eae-530269e37609_zpsaf5b8012.jpg]
///Mpowered
06-12-2016, 07:32 PM
Post: #84
(06-12-2016 06:51 PM)born2boost Wrote:  Properly done Bruce! Well done.
So...you eventually scratched the itchBluebiggrin
07-12-2016, 07:16 AM
Post: #85
About time. Will you be on track next year?
07-12-2016, 07:41 AM
Post: #86
Clapper
1994 BMW E36 ///M3 2-door
My Thread
08-12-2016, 05:00 PM
Post: #87
Hi Guys...
Sorry for the delayed reply
Yes I've finally scratched that itch...always wanted the S54 for track use and I figured its easier to buy a built car then to try and fit the engine to my E36.
I will definitely be on track next year...whether I will be racing or just time trailing I am not sure yet...time will tell I guess.
Looking forward to this new journey!
///Mpowered
15-12-2016, 06:35 AM
Post: #88
Test fitting and suspension setup before spray painting.
[Image: 80542a2_4637307981.jpg][Image: 15355638_10154858702111487_7391725884059...002745.jpg]
15-12-2016, 07:59 AM
Post: #89
Hey man looking good out of interest what did that cage cost you ?
E36 V8 Turbo Drift Missile Build in progress
http://www.bmwfanatics.co.za/showthread.php?tid=65639
15-12-2016, 08:45 AM
Post: #90
thank you. The cage was just over 50k as its chromemoly not the usual mild steel.
15-12-2016, 09:06 AM
Post: #91
Inlove
I have so much racecar envy, right now Rofl
15-12-2016, 12:04 PM
Post: #92
Very nice Bruce, what suspension will you be fitting? I like the top mounts!
This is going to be a very well built car by the looks of things so far!
///Mpowered
26-12-2016, 09:14 AM
Post: #93
All the welding and mock up has been done. We have even converted to a single wiper. Now to strip it down and spray it. Then the wide body kit.[Image: img_0155_5523021528.jpg][Image: img_0157_4465757808.jpg][Image: img_0158_7200108310.jpg][Image: img_0159_8307457631.jpg][Image: img_0160_7438277755.jpg][Image: img_0161_9471256928.jpg]
[-] The following 1 user says Thank You to Brucet for this post:
Gizmo@GARAGE46 (12-26-2016)
26-12-2016, 11:47 AM (This post was last modified: 26-12-2016 11:50 AM by Gizmo@GARAGE46.)
Post: #94
I see a custom pillow ball shifter there. Fencelook
Thought of building my own too as the AKG shifter is stupid expensive!
[-] The following 1 user says Thank You to Gizmo@GARAGE46 for this post:
Brucet (12-26-2016)
26-12-2016, 12:03 PM
Post: #95
This thing looks amazeballs and not even in paint yet !! I think we are all in envy at this stage can wait to see the end results. Keep it up.
Sent from my STV100-4 using Tapatalk
[-] The following 1 user says Thank You to Francoisjl for this post:
Brucet (12-26-2016)
20-01-2017, 06:33 AM (This post was last modified: 20-01-2017 06:39 AM by Brucet.)
Post: #96
Last bit of test fitting isbeing done with the rear brakes that have finally arrived. The disc on the floor is the standard e36 M3 brake disc t give you a comparison.
On Monday she goes in for spray painting and then in around a weeks time she will go in for the wide body kit which will take around 2 weeks to fit.
Its getting close now!! =)
[Image: 16174821_10154974760096487_8685614136202...657462.jpg]
(15-12-2016 12:04 PM)born2boost Wrote:  Very nice Bruce, what suspension will you be fitting? I like the top mounts!
Sorry B2B i dont think i answered you. I forget the name of the suspension but its a fairly decent setup. Will let you know.
[-] The following 2 users say Thank You to Brucet for this post:
AndreasSA (01-24-2017), Captain_Stealth (01-20-2017)
13-02-2017, 08:05 AM (This post was last modified: 13-02-2017 08:06 AM by Brucet.)
Post: #97
Been a slow start to the year but we are on the home stretch now.....Base coat/rust protection has been done. It is currently getting the wide body panels and carbon fiber roof etc fitted.
[Image: 16683967_10155039912811487_2842582051710...286491.jpg][Image: 16681840_10155039912931487_4688371947539...007260.jpg][Image: 16711688_10155039913126487_2370461901665...410733.jpg][Image: 16711526_10155039913261487_6145737294082...522993.jpg]
Dewald Basson (02-14-2017), Gordvisr (02-16-2017)
16-02-2017, 02:24 PM
Post: #98
coming along nicely
Current :
2009 BMW 125i
1994 Kadett 200iS
1974 Beetle
EX :
1995 BMW 328i
16-02-2017, 10:40 PM
Post: #99
When is the turbo coming
16-02-2017, 10:53 PM
Post: #100
(16-02-2017 10:40 PM)Captain_Stealth Wrote:  When is the turbo coming
You and your turbo questions Hammerhead
Post Reply
User(s) browsing this thread:
1 Guest(s)
