Post Reply
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
E46 318i pulling badly to left under braking
14-07-2013, 08:41 PM
Post: #1
Guys, my bro in law's 318 is pulling badly to the left when braking.
It has 18" Style 193s, brand new tyres out on Thursday and wheel alignment is fine.
Any idea what the problem could beBangdesk
Current Rides
2006 E92 335i(196kw/439nm @ KAR 22/10/2016)
2003 VW Polo 1.6 Comfortline
EX Rides
2003 330i M 6 Spd
1997 VW Microbus 2.6i
2000 Corolla RSi 6 spd
1998 318i MS II
2000 200 STI
2000 540i A/T
2002 325i Sportspack
1998 Corolla RSi
1997 Corolla RSi
1999 VW GTI
1990 325i MEX
1993 Conquest RSi T/C 16
1992 GLI T/C 16
Find all posts by this user
14-07-2013, 08:49 PM
Post: #2
RE: E46 318i pulling badly to left under braking
How old are the brakes? Would a warped brake disc cause a shudder or make it pull to the side?
Current:
'14 F30 335i MSport Alpine White III, Coral Red, Sat Nav, iDrive touch, PDC + reverse cam, Harman Kardon, N55 222.4wkw | 413wnm STOCK
'16 F30 318i LCI Manual, Alpine White III, Black Leather
[Image: banner final_1261154562_8282635603.png]
Mods: Optic Blue Lamin-X fogs, VPS light shields, CF Splitters, Mirrors, Ducktail spoiler, Aluminium interior trim upgrades...
Retired BMWs:
'12 F30 320d
'12 F20 118i
'09 E90 LCI 320i M-Sport
'07 E90 320i Excl
'91 E30 325iS Evo I
14-07-2013, 09:03 PM
Post: #3
No brake shudder, just a fierce pull to the leftThumbdown
Current Rides
EX Rides
2003 330i M 6 Spd
1998 318i MS II
2000 200 STI
2000 540i A/T
1998 Corolla RSi
1997 Corolla RSi
1999 VW GTI
1990 325i MEX
1992 GLI T/C 16
14-07-2013, 09:06 PM
Post: #4
My guess is that your right pads are shot. Only the left ones are making contact, perhaps? Iono
/o(O)(O) \ (lllllllll)(lllllllll) / (O)(O)o\
My thread - sold
[Image: new forum sig_5527771133.jpg]
Click here to view the network of forums hosted by TheFanatics.co.za | Click here to find out more about advertising on our network of forums | Click here for a list of our current advertisers | Click here for the forum rules and guidelines | Click here and check your region for any past and upcoming events and get-togethers | Click here to find out how to gain ///Member status
[-] The following 2 users say Thank You to ChefDJ@TheFanatics for this post:
cOlDFuSiOn (07-14-2013), YUBEN@TheFanatics (07-15-2013)
Post: #5
(14-07-2013 08:49 PM)cOlDFuSiOn Wrote:  How old are the brakes? Would a warped brake disc cause a shudder or make it pull to the side?
+1 on the brakes
also don't be so hasty to rule out the wheel alignment, you say its 100%, but always good to double check, and whilst they double check the wheel alignment have them go over the suspension components as well to check for lose or worn items as well.
but generally if it rides straight and true, and vibration free, but only under hard braking veers off...its probably brakes
https://www.facebook.com/ralf.t.schulz
[-] The following 2 users say Thank You to Ralf* for this post:
14-07-2013, 09:07 PM
Post: #6
(14-07-2013 09:03 PM)YUBEN Wrote:  No brake shudder, just a fierce pull to the leftThumbdown
Wow that must be scary! It's gripping too hard on the left brake then?
Current:
Retired BMWs:
'12 F30 320d
'12 F20 118i
'07 E90 320i Excl
'91 E30 325iS Evo I
[-] The following 1 user says Thank You to cOlDFuSiOn for this post:
15-07-2013, 06:10 PM
Post: #7
Alignment was done last week when 4 new tyres were put.
There is no vibration while driving.
I drove it yesterday from Centurion to Loftus. The ride is still great, smooth, no irritating niggles. When I left the steering to see if it pulled it stayed straight.
I guess my bro needs to start with replacing front pads and see from thereThumbs
Thanks guys for the input
Current Rides
EX Rides
2003 330i M 6 Spd
1998 318i MS II
2000 200 STI
2000 540i A/T
1998 Corolla RSi
1997 Corolla RSi
1999 VW GTI
1990 325i MEX
1992 GLI T/C 16
16-07-2013, 05:44 PM
Post: #8
Its a Seized caliper...
Get a caliper seal kit from stealers and replace on both fronts, its just a set of rubber o rings that sit on the piston which moves in and out which build with dust and jam up..
E92 335i DCT
Current SA x35 Champ 400m @ 11.516 @ 203kmh
Backed up at MSA event!
Ex: E92 335i Step- Ex SA N54 Champ 400m @ 12.041 @ 195kmh
Thought I joined a car forum but all we ever talk about is alcohol, meth, and LSD....I'm sooo confused! Bangdesk
[-] The following 1 user says Thank You to Kish2604@TheFanatics for this post:
YUBEN@TheFanatics (07-17-2013)
16-07-2013, 07:45 PM
Post: #9
Interesting.
From my experience, I would say tyre tread pattern should also be considered, I use to have Yokohama A-Drive’s on my car and it reacted harshly to the contour of the road under braking.
I also have had issues with my front brake calipers and the symptom was a sharp jab through the steering wheel as you apply the brakes, I think there was some pulling during braking.
Then of course the wheel alignment should checked again, odd that it now pulls after the fitment of the wheels right??
[-] The following 1 user says Thank You to WaNaV8GoCart for this post:
17-07-2013, 07:28 AM
Post: #10
(16-07-2013 07:45 PM)hermanbriel Wrote:  Interesting.
It was pulling before the alignment was done which led me to beliee that the alignment was not out by that much as initially suspected.
Thanks Kish, will try that caliper kit as wellThumbs
Current Rides
EX Rides
2003 330i M 6 Spd
1998 318i MS II
2000 200 STI
2000 540i A/T
1998 Corolla RSi
1997 Corolla RSi
1999 VW GTI
1990 325i MEX
1992 GLI T/C 16
17-07-2013, 08:23 AM
Post: #11
does the car feel floaty, and follow the uneven road? if so....check out the lower control arms..happened to me
29-07-2013, 01:50 AM
Post: #12
Update on this? Was the caliper kit successfull?
E92 335i DCT
29-07-2013, 06:44 AM
Post: #13
I picked up an issue like this in the past with a faulty shock
[Image: 550i%20Low%20Res%20copy_zpsbt95wpmw.jpg]
Current:
2010 BMW F10 550i
BMW Goodbyes:
2005 BMW E90 330i Exclusive | 2002 BMW E46 330i Exclusive (Facelift) | 2006 BMW 550i MSport
29-07-2013, 07:03 AM
Post: #14
What about a wheel bearingBangdesk
Current Rides
EX Rides
2003 330i M 6 Spd
1998 318i MS II
2000 200 STI
2000 540i A/T
1998 Corolla RSi
1997 Corolla RSi
1999 VW GTI
1990 325i MEX
1992 GLI T/C 16
29-07-2013, 08:06 AM
Post: #15
(29-07-2013 07:03 AM)YUBEN Wrote:  What about a wheel bearingBangdesk
Hey, if you havent checked the alignment i would recommend doing so, as i had a situation where they guys had set my car perfectly within specs.., but for the facelift, when my car isnt( not the 5er). when using the right settings it made the difference, similarly when i had my 180i conquest, most the alignment guys would do the aligment using a tazz setup.
I dont think the alignment would cause such a sharp pull though, am also leaning towards the braking issue, Am sure a roadworthy place can check brake efficiency at the wheels at little or no cost?
No, no, he didn’t slam you, he didn’t bump you, he didn’t nudge you… he *rubbed* you. And rubbin, son, is racin’. – Harry Hogge, Days of Thunder
Current Rides
[Image: car_on_fire_zps312a906a.jpg]
[Image: 166384.png]
1996 200 Si Camry
Post Reply
User(s) browsing this thread:
1 Guest(s)
