Loading
Post Reply
Thread Rating:
  • 0 Votes - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
F30 320i vs f30 328i
17-12-2012, 10:59 PM
Post: #1
What would be a better buy? Does the 320i and 328i have the same motor?
If one does software on the f30 320i would it be performing same as a 328i?
Find all posts by this user
18-12-2012, 09:35 AM
Post: #2
RE: F30 320i vs f30 328i
As far as i know, both have the same displacement.
I would go for a 320i with a software upgrade Thumbs
The 328i just isnt worth the extra money!
18-12-2012, 09:36 AM
Post: #3
From what I have heard, you cannot map a 320i to the same power outputs of the 328i, will be around 160kw (flywheel) on 320i.
BMW 320i Msport 2013
Ex BMW 335i e90 2009
Ex BMW 320d 2010
Ex Alfa Romeo Mito 2009
Ex Alfa Romeo GT Diesel 2006
Ex Polo 1.9tdi 2 door 2005
Ex Polo 2.0 2006
Ex Opel Astra 1.8 16v 1998
18-12-2012, 09:45 AM
Post: #4
You also need to look at the brakes, diff, gearbox, etc.
However, that engine definitely has some nice tuning potential that seems very close to the 328i. Thumbs
[Image: SIg2_zps7ce2cf3c.jpg]
BMW Software Specialists - NOTHING beats Experience! - We lead... just follow us!
Imola Red E46 M3 SMG
18-12-2012, 09:47 AM
Post: #5
Being a turbo'd engine, I'm sure that you could push 328i power out of the 320i, but there must be some hardware differences in the 328i that helps give it the edge.
[Image: DSC_1342copy-Copy.jpg]
2004 330i Manual - Sports Pack
[Image: 94253.png]
18-12-2012, 10:04 AM
Post: #6
Guys... the two engines are NOT the same even though it sounds like it at first glimps.
The F30 328i has a compression ratio of 10:1 as where the F30 320i has a compression ratio of 11:1
If one looks at the compression volume of both engines the difference is obvious: F30 320i: 49,9 cm³ but F30 328i: 53,7 cm³ which indicates that different pistons are used in the 328i
With an initial compression ratio of 11:1 on a turbo engine you can be sure that you are close to the knock line so I see VERY VERY little chance to gain much power through software!
Of course.... one needs to "play" with it a bit to see what actually goes Idea
BMW Software Specialists - NOTHING beats Experience! - We lead... just come with us!
[-] The following 1 user says Thank You to Promotec for this post:
325iSE_mams (12-24-2012)
18-12-2012, 10:12 AM
Post: #7
Are you saying the 328 has more software potential than the 320?
Glory Glory Man United
[Image: 320d_an5.gif]
[Image: 125150.png]
2012 F30 320d Melbourne Red (current) (more pics here!)
2007 E90 320d Black Sapphire (sold 26 April 2012)
18-12-2012, 10:13 AM
Post: #8
(18-12-2012 10:12 AM)petrivanzyl Wrote:  Are you saying the 328 has more software potential than the 320?
Definitively YES! Thumbs
18-12-2012, 11:08 AM
Post: #9
(18-12-2012 09:45 AM)msm@PromotecAuto Wrote:  You also need to look at the brakes, diff, gearbox, etc.
(18-12-2012 10:04 AM)Rolf@PromotecAuto Wrote:  With an initial compression ratio of 11:1 on a turbo engine you can be sure that you are close to the knock line so I see VERY VERY little chance to gain much power through software!
Ok, I'm confused... does it have decent tuning potential, or very little potential?
If it's good, it's good... if it's better, it's a ///M
[Image: F30Sign.jpg]
Current: 2012 F30 320i M Sportpack, AW, Xenon, PDC, black kidney grills, CF wrap roof & mirrors
18-12-2012, 11:19 AM (This post was last modified: 18-12-2012 11:25 AM by Promotec.)
Post: #10
The F30 320i is running very close to the max achievable power as it comes from the factory!
The high compression ratio of 11:1 prevents you from getting much closer to the knocking line.
IF one would attempt to gain loads of power one would have to reduce compression in order to raise boost (boost = power)
So the answer to your question is a simple "NO potential" or let me rather say not much potential....
... and let me add: you can certainly NOT convert a F30 320i to an 328i with a few easy and cheap steps! (BMW would be stupid to allow that)
18-12-2012, 11:37 AM
Post: #11
Do they even have the same size turbo...?
E90 335i (Stock for now)
VW Polo 1.6 (The daily runner)
Ex:
00' Sentra 200Sti
00' Primera 200Sti
[Image: IMG00026-20110814-1114.jpg]
18-12-2012, 12:08 PM
Post: #12
Ok, thats kind of sad if you want more power out of the car,
Im going to apply for my 320i m sport today....i drove it and although its not super fast its still good.
Its either the 320 or stick with my kia for now
18-12-2012, 12:15 PM (This post was last modified: 18-12-2012 12:44 PM by ///Shaun.)
Post: #13
(18-12-2012 11:19 AM)Rolf@PromotecAuto Wrote:  The F30 320i is running very close to the max achievable power as it comes from the factory
NOT !
@MSM you say different diffs , gearbox in f30 328i vs f30 320i. Please expand more on this. Lets see if google can help your explanations here.
I have a f30 MSport 320i added to my garage currently and a f30 MSport 335i on order. I chose both with M running gear and thats completely different motors but the ....lets see if google can help you here.
F30 320i and F30 328i have different turbos and different compressions and thats about it. Internals are the same !
/// Garage has Cruising, Family, Fast Beemerz
18-12-2012, 12:46 PM
Post: #14
(18-12-2012 12:15 PM)///Shaun@xcede Wrote:  F30 320i and F30 328i have different turbos and different compressions and thats about it. Internals are the same !
Shaun.... isn't that a bit contradicting?
18-12-2012, 12:49 PM (This post was last modified: 18-12-2012 01:03 PM by ///Shaun.)
Post: #15
Im sure you know what i meant. Typing from my phone. Will post up the complete specs between the motors when Im back.
Tuned f30 320i
http://www.f30post.com/forums/showthread.php?t=611684
18-12-2012, 03:36 PM
Post: #16
Thumbs
Getting interresting...
@Shaun... I see you signed tuned F30 320i... Did you do a tune on your car?
18-12-2012, 04:02 PM
Post: #17
(18-12-2012 03:36 PM)DeoJor Wrote:  @Shaun... I see you signed tuned F30 320i... Did you do a tune on your car?
Are you referring to his previous post? If so, that's not his sig, that's a second post which the system appended (since there weren't any posters after him at that point in time).
I recall him saying in his showroom thread that he wouldn't be tuning the 320i.
[Image: 94253.png]
18-12-2012, 04:07 PM
Post: #18
Flyfun oh ok, I see the linkup now
18-12-2012, 04:09 PM
Post: #19
I still need to see that with my own eyes.... Idea
18-12-2012, 05:25 PM
Post: #20
buy the 328i ,
drive it like a mapped 320i
& u got no motorplan issues Idea
[Image: 640d.jpg]
King of Diesel
Post Reply
User(s) browsing this thread:
1 Guest(s)
