Post Reply
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
E36 Clean Whining Sound
15-10-2012, 08:54 AM
Post: #1
Hi Guys,
Need some help,
Since Saterday I've noticed that on Idle and Acceleration my car makes a whining sound, almost as if there is a turbocharger connected.
If the car is in neutral, with the clutch pedal up, I hear the sound, the minute I press the clutch pedal to the floor the sound whines down and stops.
On acceleration the sounds pitch increases in conjunction with the revs of the car.
What could it be...Argh Just recently sorted out my power steering, shocks, tie-rod ends, bushes, this car is starting to work on my nerves...
Regards
[Image: BMWFanaticsSig600_zps429c924f.​jpg]
______________________________​______________________________​__
Current: Mercedes Benz CLK 320 Coupé
Find all posts by this user
15-10-2012, 10:56 AM
Post: #2
RE: E36 Clean Whining Sound
From what you say when pressing the clutch inn. I would say its the clutch release bearing.
But the progressive whine on accceleration indicates gearbox bearings.
Is it there in all gears, or just the first 2 or 3?
15-10-2012, 12:57 PM (This post was last modified: 15-10-2012 12:58 PM by 328ii.)
Post: #3
I had a high pitched whine on mine and replacing a 'dry' pulley helped
I replaced all 3 pulleys/tensioner as preventative maintenance
This done as extension to regular oil service
8?>
///M Clap
16-10-2012, 01:46 PM
Post: #4
The sound is most noticeable in 1st and 2nd gear,
Is a clutch release bearing expensive to replace? and how long can I drive the car for.
I've noticed nothing else, the car still has the same power, gear changes are still smooth and the clutch is still perfect.
Regards
16-10-2012, 09:10 PM
Post: #5
(15-10-2012 08:54 AM)LordPhoenix Wrote:  If the car is in neutral, with the clutch pedal up, I hear the sound, the minute I press the clutch pedal to the floor the sound whines down and stops.
Early this year my car was making the same noise, replaced the released bearing & that noise was still there. Problem is the idle gear, the bearing around it wears out & makes that sound. Its nothing too serious but that sound is irritating...
[Image: vdzhdja9uhv0ms9pn60e.jpg]
P1000 Wrote:Real men don't do motorplan
16-10-2012, 09:33 PM
Post: #6
I'm hearing the same sound in 1st and 2nd. In 3rd and up its a lot quieter but I can just still here it.
Regards
17-10-2012, 01:39 PM
Post: #7
if it is the release bearing. Gearbox has to come outCry
gearbox bearings (if it is) can be done same time as well.
If you have not done clutch and pressure plate in a looong while then do that as well- After that you wil be good to go for quite a few kilomtres.
But this is all forum diagnostics. It could just be a simple dry pully or sumtin.
Take it to a mackie to just have a look and give you a diagnosis.
What area you at?
Maybe the guys here can recommend someone.
18-10-2012, 10:49 AM
Post: #8
(17-10-2012 01:39 PM)Quickie Wrote:  if it is the release bearing. Gearbox has to come outCry
What area you at?
I'm in JHB, I'll PM Gizmo, and pop around when his available for a diagnosis,
Regards
13-02-2013, 12:51 AM
Post: #9
What area you at?
Sorry for reviving and old thread but did you ever resolve this issue my car is having the same problem and its driving me nuts, Im afraid its gonna cost me alot of money. Looking forward to hearing back from you.
13-02-2013, 09:15 PM
Post: #10
What area you at?
+1
And I also found it kind of quiets down in neutral when rev goes up between 2000 and 2500.
Evil inside
Current : Honda Ballade(Un-named thus far)
The Witch
Fanatic stickers
Become an ///M member
Ex:Opel Kadett(Stripes)Sold
E36 318i (The Witch) Sold
Hyosung Comet 650R (The Grok) Sold
Yahmaha R1 (Black Widow) Writen off
Post Reply
User(s) browsing this thread:
1 Guest(s)
