damon1 said:
Hi All-
Ok lets start by saying that i had the displeasure of owning two E90 323i ( 130Kw/2006 and the 140Kw/2007).And yes back then i was enthusiastic enough to want to do the same conversion.Almost all the companies i phoned were not familiar with the power difference and only one "Upsolute" claimed that they could convert the car to 325i power.
So off i went cash in hand to have the conversion done.They removed the ECU,read the file,sent it to Germany,UK or the moon to have it reprogrammed.Had the ECU installed and was promised 160Kw.Drove the car for a week and could not tell the difference.I then took the car to BOSCH to have it dyno tested and lo and behold the car was 3KW faster.Yes,you read right-just 3Kw-The moral of the Upsolute story is clear.Unless they reprogram and DYNO test your car in front of you,DONT trust their WORD.Oh and it was a mission to get back my refund.SOmetimes the mind belives ur going faster after someone "interferes" with the ECU.
OK now to the differences.THe E323i is unique to JAPAN,CANADA and u guessed it S.Africa.
The differences as as ffg.
1. Different ECU mapping - BTW - 325i has a higher RPM cut off as well(6500 vs 7000)
2. 325i two stage DISA intake manifold vs 323i single stage DISA
3. Intake manifold is smaller/narrower on the 323i than on the 325i.
Now while u may say that just by progamming the ECU u will get the power-Answer is NO- A 323i will run with a 325 till 90Kph-beyond that the extra breathing and mapping on the 325 will make it pull away-believe me i have tried and tested.Your best alternative to live with the 323i is to install a K&N as i did back in the day.It breathes alot better and wont crash your feelings when 4cylinder cars want to race you.
So in the interest of saving my sanity i have reverted to buying a E90 320d(130Kw) with a chip(170Kw/450nm)- It runs neck on neck with a E90 330i on the freeway and pulls away from it at the robot.I dont even race a 325i cos they dont keep up-The results of chipped diesels are just amazing.I have outran golf 5 GTI's that are chipped as well.
Hope this helps and saves you guys alot of painful searching from tuners who need to pasture in a 4x2 bull pen and for once stand in the same stench of "bullshit" that they pass off.
Hi
Just took delivery of my E90320d and like the look of your chip. Where and how much?
Hi All-
[/quote]
[/quote]
Hi
Still getting used to this.....
Read about your chipped 320d. Took delivery of my 320d two weeks ago.
Is this a piggy back system ? (motorplan)
