Post Reply
Thread Rating:
  • 1 Vote(s) - 1 Average
  • 1
  • 2
  • 3
  • 4
  • 5
X5 transmission failsafe program
05-09-2012, 06:16 PM
Post: #1
Hi guys,
So on my way from the airport back to centurion, the x showed transmission failsafe program, when i got home and did diagnostics it showed solonoid valve,
So my question is, wtf now? What do you suggests?
Any help would be appreciated.
Sent from my iPad using Tapatalk HD
Current Garage:
  • His: 17' Ford Ranger
  • Hers: 06' E65 750I Black
  • Toy: 17' Lotus 7 Track toy
Previous BMW Toys:
  • 06' E63 M6 Black | Decatted | Straight piped
  • 06' E46 M3 Silver Convertible
  • 05' E46 FL 330i 6SP Indv Motorsport Scarab Green, CDV Delete, 3.38 Diff
  • 03' E53 X5 4.6IS Titanium Grey
  • 00' E46 318i 2000 5SP Sahara Metallic Gold
Find all posts by this user
05-09-2012, 06:20 PM
Post: #2
RE: X5 transmission failsafe program
(05-09-2012 06:16 PM)Pho3niX90 Wrote:  Hi guys,
Check with alexander1 on the forum. He seems to be good with this type of stuff.
Good luck with the fix Thumbs
[Image: 550i%20Low%20Res%20copy_zpsbt95wpmw.jpg]
Current:
2010 BMW F10 550i
BMW Goodbyes:
2005 BMW E90 330i Exclusive | 2002 BMW E46 330i Exclusive (Facelift) | 2006 BMW 550i MSport
06-09-2012, 09:35 AM
Post: #3
Thanks man, going to ZF in the next hour, their ball park figure is 21K to fix the problem Sad
Current Garage:
Previous BMW Toys:
06-09-2012, 09:50 AM
Post: #4
Which X5 do you have, E53 or E70?
It would be interesting to know if it is a gearbox fault or a transfer case fault? The early X3's sometimes had a fault on the x-drive actuator or bearing wear inside the transfer case which can be expensive to fix. The X5's used a beefed-up transfer case.
Nothing comes at a higher price than that which is free.
[Image: bmw_heart_1010565897.jpg]
06-09-2012, 09:56 AM
Post: #5
Sorry to hear bud, all the best with the repairs
[Image: img-20160523-wa0020_199168482.jpg]
06-09-2012, 05:38 PM
Post: #6
(06-09-2012 09:50 AM)Blue Shirt Wrote:  Which X5 do you have, E53 or E70?
It's the E53 4.6IS 2003.
At the moment it's at ZF, all of the 6 Solenoid valves aren't functioning, so the mach said that it MIGHT be a loose wire or blown fuse, or might be the computer box, he will be looking over it tomorrow and will let me know.
I have read on the internet about bad grounding/ shorts that cause the limp mode as well, when reviewing the log file of the diagnostics I done last night, I saw these 2 new codes:
IKE ->
8D/50 - EGS signal line disturbed
BD/50 - Electronic braking-force distribution
I also read on another thread that broken ABS units also cause limp mode due to bad grounding??
Any thoughts.
Oh yeah, the 23K is basically a new transmission according to the mach.
Current Garage:
Previous BMW Toys:
10-09-2012, 11:10 AM (This post was last modified: 10-09-2012 11:24 AM by Pho3niX90.)
Post: #7
So I'm so pd off right now.
They said that the gearbox needs replacing due to the torque converter. But friday they said it could be the computer because all the solenoids aren't opening/closing, and that the computer box were under water.
I cant seem to find that user? Any other suggestions, any gr8 maks you know.
Current Garage:
Previous BMW Toys:
10-09-2012, 12:07 PM
Post: #8
With all 6 solenoids not working, that car is going nowhere
So that makes absolutely no sense.
If it was your EGS computer that went poof due to water, you would not have been able to read the error codes.
i smell a rodent...
I will be on the other side if anybody needs me Bluebiggrin
10-09-2012, 12:09 PM
Post: #9
(10-09-2012 12:07 PM)zaleonardz@DentDoctor Wrote:  With all 6 solenoids not working, that car is going nowhere
i smell a rodent...
It seems that it when it goes in trans failsafe, its only in 4th gear, it could still be driven from centurion to zf.
They are going to replace the 5 speed with a new 6 speed.
Current Garage:
Previous BMW Toys:
10-09-2012, 12:11 PM
Post: #10
What are they charging you for the box replacement ?
13-09-2012, 12:17 PM
Post: #11
Its 31K, fetching the car today
Sent from my BlackBerry 9900 using Tapatalk
Current Garage:
Previous BMW Toys:
13-09-2012, 12:52 PM
Post: #12
GL...hope it goes well Thumbs
2006 E90 320d Individual
13-09-2012, 05:09 PM
Post: #13
Replace the 5 speed with a 6 speed? That means quite a major electronic surgery. Let us know how it came out.
14-09-2012, 03:02 PM
Post: #14
(13-09-2012 05:09 PM)P1000 Wrote:  Replace the 5 speed with a 6 speed? That means quite a major electronic surgery. Let us know how it came out.
It makes sense what you are saying, I could have heard wrong :? Dono, but the X is driving like a dream again, just some sensors on the exhaust isn't working anymore, before I took it in all was working, tested with DIAG cable, now that's it's back it's giving me an error on the sensor before the cat, they claim that it's because the computer was buggy and didn't give me all errors before.
Current Garage:
Previous BMW Toys:
Post Reply
User(s) browsing this thread:
1 Guest(s)
