Post Reply
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
BMW E36 323i M52 ECU remap recommendations
26-06-2012, 09:09 AM
Post: #1
Warning BMW E36 323i M52 ECU remap recommendations
Hello all,
I’ve just relished that I made a huge mistake in my build. And therefore I think I’m responsible for the destruction of my own engine and past engines in the car.
I’ve upgraded the normal 323I (m52b25) engine to a more powerful (M52B28) engine. Upgraded the normal (323i branches to WILDCAT branches), and now want to upgrade the normal M52 intake manifold to M50B25 intake manifold.
Currently the car is very light on fuel (8.3L/100KM on the open road, 9.5L/100KM city driving & max 11L/100KM when driving like Schumacher) but the power never seemed to what a 328I must produce.
The mistake I made, I NEVER HAD THE ECU re-mapped!!!!!!!!!!! (Siemens MS4 1.0)
Suspect that the engine’s were running too lean…. Causing damage to the valves & piston rings.
Any recommendation on who can remap the car after I fit the new Manifold?
Find all posts by this user
26-06-2012, 09:13 AM
Post: #2
RE: BMW E36 323i M52 ECU remap recommendations
What area?
[Image: IMG-20120627-00224-1-1-1.jpg]
Current:
2006 BMW 550i M Sport
20" Rezax | Koni FSD | Powerflow exhaust | K & N air filter | CF Roundels | Matt black kidneys | LED interior upgrade | Promotec tuned
BMW Goodbyes:
2005 BMW E90 330i Exclusive | 2002 BMW E46 330i Exclusive (Facelift)
[Image: 134920.png]
26-06-2012, 09:23 AM
Post: #3
why don't you just get a 328i ECU?
You should be able to pick them up relatively cheap from a scrapyard and in comparisan to a remap, you'll have the Full Monty at the same price Idea
26-06-2012, 12:30 PM (This post was last modified: 26-06-2012 12:31 PM by 328ii.)
Post: #4
Quote:Any recommendation on who can remap the car after I fit the new Manifold?
i have the same question but will add reputable
another dme[ecu] might not solve ews issues..?
8?>
///M Clap
26-06-2012, 07:36 PM (This post was last modified: 26-06-2012 07:43 PM by bmw328.)
Post: #5
(26-06-2012 09:13 AM)abmi0000 Wrote:  What area?
Rustenburg, North West. But will travel to Johannesburg or Pretoria.
(26-06-2012 09:23 AM)Rolf@promotec Wrote:  why don't you just get a 328i ECU?
Issue is, Its not just about changing the ECU. ECU, ews and transponder key must all be changed. The complete harness & electronic systems came from a 323I import
27-06-2012, 12:10 AM
Post: #6
Whole set should cost about R2K , IMHO to rechip dyno etc will cost more .
27-06-2012, 05:52 AM (This post was last modified: 27-06-2012 05:54 AM by bmw328.)
Post: #7
(27-06-2012 12:10 AM)Raybimmer Wrote:  Whole set should cost about R2K , IMHO to rechip dyno etc will cost more .
Okay, I can do that. That will solve my power issue and save the next engine. LOL.
What about when i fit the M50 manifold? I did fit it before on my current ECU. Had NO power at bottom end and really had to drive it hard to get power out of it. Most threads i read so far say that u must remap the ecu?
27-06-2012, 06:09 AM
Post: #8
*ggg* don't play these games if you already know that you are going to have troubles!
A remap will not solve the problem of lack of power on the bottom end.... its the design of the intake manifold Thumbdown
27-06-2012, 07:23 AM
Post: #9
(27-06-2012 06:09 AM)Rolf@promotec Wrote:  *ggg* don't play these games if you already know that you are going to have troubles!
I am, merely pointing out that the ECU from the 328I (With 328I map) is not a bad idea, But I was thinking, what if I fit the M50B25 manifold as well for added power.
PS. Please note that It’s NOT the design of the M50 manifold that makes the 323/328I weak at bottom end (Otherwise the 325i wouldn’t have been only 1kw less than the 328i, secondly the 325I pulls from bottom right to high revs. PS I own a 1994 325i As well)
If someone TUNES the current ECU (NOTE that the 323i has the exact same ECU as the 328i only the map differs), the car will have to be dyno tuned & re-mapped according to that.
See links below of people who have fitted M50 manifold and solved the LACK of POWER with a TUNE. (OR REMAP of their ecu’s)
http://forums.bimmerforums.com/forum/sho...p?t=544874
http://www.pistonheads.com/gassing/topic...34829&nmt=
But Thanks anyway,
I would have to look around hard for a 328I ECU with ACS. Don’t really want to lose mine.
27-06-2012, 08:57 AM
Post: #10
Well I have a 325i non vanos and 328i and they differ but the 325i does like to be revved . The 328i , Audi A4 2.8 and the Merc C280 all had 142 Kw as it was a German power limit for taxes , over that and you paid a lot more that is why all three had the same power .
The M50 manifold ,good exhaust and a remap will work , the 328i then comes alive . This is also nice with a 3.15 diff , even down to a 3.46 you then have very good pull but hit the limiter in 5th !! ( My 325i has a 3.46 !!! )
29-06-2012, 07:08 PM
Post: #11
Take the car to Budler Motorsport, he will sort out your ECU woes.Thumbs
29-06-2012, 08:27 PM
Post: #12
+1 on Budler Motorsport.
Current: 2015 Black Dodge Journey 3.6 V6 R/T
2008 Silver Hyundai Accent 1.6 3dr
Previous: 2010 BMW 320D 6spd ,2010 Mazda 3 2.0 individual, 2007 BMW 323i 6spd, 1999 Nissan Sabre Gxi, 2006 Ford Focus Sportpack, 2000 Opel Corsa B, 1999 Nissan Sentra Gsi, 1996 Toyota Conquest
Post Reply
User(s) browsing this thread:
1 Guest(s)
