maximus
What happened : Engine Overheated
While as I was driving into town to pick my mom up...driving like how I normally drive, now on the N1 I give it some beans and drove like a mad person for about 500m then I noticed the TEMP Gauge is pass the middle dial and is getting to the red side very quickly and also the dashboards showing "COOLANT TEMP" - so I was on the N1 heading into town (next to CTICC) and about 400m I stopped the car and checked what the hell was going on.
I suspect that its the waterpump as this thing still had the original stock (plastic) impeller...the viscous fan was working though.
What I looked at;
-There was a obvious leak under the bonnet where I parked and its the antifreeze/water
- I let it cooled down and opened the radiator cap and theres nothing
inside the expansion tank and when I filled it up again (now driving back) - there was steam coming out the bleed cap and it took me like 4l of water to fill up the expansion tank.
- I pressed the hoses leading in and out of the engine block and its "squishy" (like theres nothing in it)
So being in town, I needed to get back home (milnerton)...luckily enough there was a gentleman who said he owned a E34 520i before and he had the same problem...he advised me to leave the top radiator bleeder screw open and fill up the expansion tank (and check / fillup regularly as you are driving) /
There are no visible breakages that I can see.
What I looked at;
