X3 Transfer Case Problems
21-03-2011, 03:14 PM
(This post was last modified: 21-03-2011 03:26 PM by warrenturbo1.)
Post: #1
So after reading forums around the world on problematic / noisy transfer cases and hoping my car might have one built which might just last a little longer than average……my transfer have sadly started to echo the noise of a pricy repair.
Over the past moth I have made contact with various dealers across the country to try and find alternatives to the hefty R45k OEM replacement, with no luck. Not accepting this boulder of a charge I hit the internet and found an X3 owner in Germany who have experienced the same transfer case problems and who had his transfer case re-built at a company called ZF Germany. Luckily I found a local branch of ZF in Meddowdale / Germiston and got a quote for R14k to completely rebuild the case and replace the chain, two main bearings and new actuator. The guys at ZF SA recon it takes about 3-4 working days and their work is backed by a 1-year warranty. Enjoy ![]() _____ BMW X3 2.0d (E83) ______ |
21-03-2011, 03:21 PM
Post: #2
RE: X3 Transfer Case Problems
You are so lucky. Viva the Net; viva
21-03-2011, 03:27 PM
Post: #3
The following 1 user says Thank You to warrenturbo1 for this post:billbt (02-10-2013) |
Post: #4
For interest sake there bud.
Your transfer case was actually designed and built by ZF. So ZF is the OEM manufacturers. You can be sure that they will do a decent to spec job of it.... As your attorney, I advise you to take a hit out of the little brown bottle in my shaving kit. You won't need much, just a tiny taste. [
BMW's Present : E36,E46,E60,E83![]() Others Present : Mitsubishi L300, Ford Fiesta, Pontiac Trans-am, Nissan Sani, BMW's Past : E65,E34,E39 Others Past, way too many... |
21-03-2011, 03:39 PM
(This post was last modified: 21-03-2011 03:57 PM by warrenturbo1.)
Post: #5
31-03-2011, 09:57 AM
Post: #6
BTW….seeing that my transfer case is on its way out, I opted to buy new oil, just to see if that will make any difference and it’s a day / night difference. The TC no longer makes excessive noise when drive up a steep uphill. Also the clunking sound the TC makes on the rear wheels are gone.
Not sure how long this “Quick Fix†will last, but it might buy me a couple more months… ![]() _____ BMW X3 2.0d (E83) ______ |
31-03-2011, 02:49 PM
Post: #7
(31-03-2011 09:57 AM)warrenturbo1 Wrote: BTW….seeing that my transfer case is on its way out, I opted to buy new oil, just to see if that will make any difference and it’s a day / night difference. The TC no longer makes excessive noise when drive up a steep uphill. Also the clunking sound the TC makes on the rear wheels are gone.Thanks man you have done something i wanted to do. Did you buy the oil from BMW. R465 per litre of something. My X3 has a hum between 60km/h to 80km/h. Quite annoying. ![]() 07 335i (Current) JB4, AFE Intake,DPs,20" M5 Wheels, 12.9s ODI (2012) 08 X3 3.0D M-Sport (Current) 91 325iS Evo 1 Turbo (Sold) 92 325iS 2.9 Stroker + Twin Throttles (Sold) |
01-04-2011, 01:04 PM
Post: #8
Yes, I used the BMW brand oil as it is much better than the stuff avalible at Auto shops. Let me know if you need more help.
01-04-2011, 01:18 PM
Post: #9
Guys,
The Liqui Moly website has alternate specs available for your car. Simply visit the website, identify your car, and it will tell you what spec oil you need to use on a specific component. I still need to find a new dealer in gauteng though... As your attorney, I advise you to take a hit out of the little brown bottle in my shaving kit. You won't need much, just a tiny taste. [
01-04-2011, 09:07 PM
(This post was last modified: 01-04-2011 09:11 PM by Richard H.)
Post: #10
(01-04-2011 01:18 PM)zaleonardz Wrote: Guys, Used the liquimoly engine oil works very well. Nothing listed for transfer case and gearbox.Says that it uses lifelong oil bs. (31-03-2011 09:57 AM)warrenturbo1 Wrote: BTW….seeing that my transfer case is on its way out, I opted to buy new oil, just to see if that will make any difference and it’s a day / night difference. The TC no longer makes excessive noise when drive up a steep uphill. Also the clunking sound the TC makes on the rear wheels are gone. I also have that clunking sound. Will change it tommorrow! ![]() 07 335i (Current) JB4, AFE Intake,DPs,20" M5 Wheels, 12.9s ODI (2012) 08 X3 3.0D M-Sport (Current) 91 325iS Evo 1 Turbo (Sold) 92 325iS 2.9 Stroker + Twin Throttles (Sold) |
03-04-2011, 06:49 PM
Post: #11
Heres some pics...
![]() The old oil had a pretty bad, burnt, smell. ![]() Scary the amount of metal shavings in the oil. ![]() This is the oil which i used. ![]() _____ BMW X3 2.0d (E83) ______ |
03-04-2011, 07:08 PM
Post: #12
looks like metallic parts in the bottom...
Black Beauty....Z4 M Coupe, once U go Coupe you cant go back. ![]() 07 Polo Tdi - 96 kw + Revo = grunt 07 A4 Tdi - 125kw (stock) |
03-04-2011, 07:27 PM
Post: #13
Yip, a nice thick layer...
04-04-2011, 05:03 PM
Post: #14
(03-04-2011 07:27 PM)warrenturbo1 Wrote: Yip, a nice thick layer... Thanks for all the info. Oil will be here tommorrow
08-04-2011, 09:19 AM
Post: #15
Did you change your oil Richard H?
10-04-2011, 08:20 PM
Post: #16
(08-04-2011 09:19 AM)warrenturbo1 Wrote: Did you change your oil Richard H?Not yet, only on Wednesday. ![]() 07 335i (Current) JB4, AFE Intake,DPs,20" M5 Wheels, 12.9s ODI (2012) 08 X3 3.0D M-Sport (Current) 91 325iS Evo 1 Turbo (Sold) 92 325iS 2.9 Stroker + Twin Throttles (Sold) |
19-04-2011, 03:30 PM
Post: #17
Changed oil today.
How much does it take about 1L? Seem to be alot more in the transfer case!!! ![]() 07 335i (Current) JB4, AFE Intake,DPs,20" M5 Wheels, 12.9s ODI (2012) 08 X3 3.0D M-Sport (Current) 91 325iS Evo 1 Turbo (Sold) 92 325iS 2.9 Stroker + Twin Throttles (Sold) |
28-04-2011, 07:54 AM
Post: #18
The transfer casse only takes 700ML. Try not to overfill.
21-03-2013, 09:51 AM
Post: #19
Hi. My 2008 X3 3.0D auto needs a transmission fluid change. BMW quoted me around R340 a litre and I need about 7L! I figured I could get it cheaper elsewhere, so I asked them what type of oil is used. They said its a 'special' shell atf and I won't get it anywhereelse. I tried a few stores but they need specifics like dextron 2 or 6, etc. Which I don't know. All I know is that it needs to be synthetic.
Can anyone help? |
21-03-2013, 10:36 AM
Post: #20
Wont be a Dexron 2
Check on the liqui moly website they may have the right spec. As your attorney, I advise you to take a hit out of the little brown bottle in my shaving kit. You won't need much, just a tiny taste. [
« Next Oldest | Next Newest »
User(s) browsing this thread:
1 Guest(s)
1 Guest(s)
![[Image: X3Magic.jpg]](http://i1188.photobucket.com/albums/z417/warrenturbo1/X3Magic.jpg)
![[-]](images/thecure/collapse.gif)
![[Image: 1_zpsd9e9e891.jpg]](http://i1280.photobucket.com/albums/a492/bimmerfanatics/1_zpsd9e9e891.jpg)
![[Image: spazaBtn.png]](http://www.bmwfanatics.co.za/images/thecure/style/spazaBtn.png)
![[Image: DentDoctorSig2-3_zps0e0a83fb.jpg]](http://i665.photobucket.com/albums/vv18/zaleonardz/DentDoctorSig2-3_zps0e0a83fb.jpg)
![[Image: DSC00070.jpg]](http://i1188.photobucket.com/albums/z417/warrenturbo1/BMW%20X3/DSC00070.jpg)
![[Image: DSC00069.jpg]](http://i1188.photobucket.com/albums/z417/warrenturbo1/BMW%20X3/DSC00069.jpg)
![[Image: DSC00068.jpg]](http://i1188.photobucket.com/albums/z417/warrenturbo1/BMW%20X3/DSC00068.jpg)
![[Image: DSCF0611.jpg]](http://i1188.photobucket.com/albums/z417/warrenturbo1/BMW%20X3/DSCF0611.jpg)
![[Image: DSCF0609.jpg]](http://i1188.photobucket.com/albums/z417/warrenturbo1/BMW%20X3/DSCF0609.jpg)
![[Image: u4pg41zpsxksndjm3753.jpg]](http://photostand.co.za/images/u4pg41zpsxksndjm3753.jpg)
![[Image: IMG-20110403-00276.jpg]](http://i1188.photobucket.com/albums/z417/warrenturbo1/IMG-20110403-00276.jpg)
![[Image: IMG-20110403-00278.jpg]](http://i1188.photobucket.com/albums/z417/warrenturbo1/IMG-20110403-00278.jpg)
![[Image: IMG-20110403-00284.jpg]](http://i1188.photobucket.com/albums/z417/warrenturbo1/IMG-20110403-00284.jpg)
